I am trying to get video data from IMX274 with using CSI2. But when I execute gstreamer command, nvcamera-daemon stopped working.
Here is dmesg about the error:
[ 208.677281] nvcamera-daemon[2496]: unhandled level 2 translation fault (11) at 0x00000000, esr 0x92000006
[ 208.687073] pgd = ffffffc05b047000
[ 208.690502] [00000000] *pgd=0000000153af0003, *pud=0000000153af0003, *pmd=0000000000000000
[ 208.700575] CPU: 2 PID: 2496 Comm: nvcamera-daemon Not tainted 4.4.38-tegra #29
[ 208.707975] Hardware name: jetson_tx1 (DT)
[ 208.712075] task: ffffffc0f2d10000 ti: ffffffc0d4094000 task.ti: ffffffc0d4094000
[ 208.719698] PC is at 0x403038
[ 208.722746] LR is at 0x403034
[ 208.725785] pc : [<0000000000403038>] lr : [<0000000000403034>] pstate: 60000000
[ 208.733243] sp : 0000007f885d7290
[ 208.736627] x29: 0000007f885db9d0 x28: 0000000000000000
[ 208.741964] x27: 0000000000000001 x26: 0000007f885db300
[ 208.747423] x25: 0000000000404000 x24: 0000000000000334
[ 208.752828] x23: 0000007f885d9300 x22: 0000007f885d8300
[ 208.758231] x21: 0000007f885d9244 x20: 0000007f885d7310
[ 208.763623] x19: 0000007f885d9930 x18: 0000000000000014
[ 208.769050] x17: 0000007f89e0efb0 x16: 0000007f89b61540
[ 208.774439] x15: 0000007f8a7f6000 x14: 7265766972446172
[ 208.779831] x13: 656d61432f697061 x12: 2f637273206d6f72
[ 208.785236] x11: 6620676e69746167 x10: 61706f7270282020
[ 208.790630] x9 : 3a726574656d6172 x8 : 0000000000000040
[ 208.796051] x7 : 0000007f80d2bc60 x6 : 0000000000000001
[ 208.801441] x5 : 0000000000000000 x4 : 0000007f80000b10
[ 208.806895] x3 : 0000000000000000 x2 : 0000000000000001
[ 208.812222] x1 : 0000000000000000 x0 : 0000000000000000
[ 208.819033] Library at 0x403038: 0x400000 /usr/sbin/nvcamera-daemon
[ 208.825294] Library at 0x403034: 0x400000 /usr/sbin/nvcamera-daemon
[ 208.831552] vdso base = 0x7f8a7f5000
Here is my device tree sources:
tegra210-camera-imx274-a00.dtsi:
* Copyright (c) 2016-2017, NVIDIA CORPORATION. All rights reserved.
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 2 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful, but WITHOUT
* ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
* FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for
* more details.
* You should have received a copy of the GNU General Public License
* along with this program. If not, see <http://www.gnu.org/licenses/>.
#include <dt-bindings/media/camera.h>
#include <dt-bindings/platform/t210/t210.h>
host1x {
vi {
num-channels = <1>;
ports {
#address-cells = <1>;
#size-cells = <0>;
port@0 {
liimx274_vi_in0: endpoint {
csi-port = <2>;
bus-width = <4>;
remote-endpoint = <&liimx274_csi_out0>;
nvcsi {
num-channels = <1>;
#size-cells = <0>;
channel@0 {
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
liimx274_csi_in0: endpoint@0 {
csi-port = <2>;
bus-width = <4>;
remote-endpoint = <&liimx274_imx274_out0>;
port@1 {
reg = <1>;
liimx274_csi_out0: endpoint@1 {
remote-endpoint = <&liimx274_vi_in0>;
i2c@546c0000 {
tca9546@70 {
i2c@1 {
imx274_a@1a {
compatible = "nvidia,imx274";
/* I2C device address */
reg = <0x1a>;
/* Physical dimensions of sensor */
physical_w = "3.674";
physical_h = "2.738";
/* Define any required hw resources needed by driver */
/* ie. clocks, io pins, power sources */
avdd-reg = "vana";
iovdd-reg = "vif";
dvdd-reg = "vdig";
/* Defines number of frames to be dropped by driver internally after applying */
/* sensor crop settings. Some sensors send corrupt frames after applying */
/* crop co-ordinates */
/*post_crop_frame_drop = "0";*/
/* if true, delay gain setting by one frame to be in sync with exposure */
delayed_gain = "true";
* A modeX node is required to support v4l2 driver
* implementation with NVIDIA camera software stack
* mclk_khz = "";
* Standard MIPI driving clock, typically 24MHz
* num_lanes = "";
* Number of lane channels sensor is programmed to output
* tegra_sinterface = "";
* The base tegra serial interface lanes are connected to
* discontinuous_clk = "";
* The sensor is programmed to use a discontinuous clock on MIPI lanes
* dpcm_enable = "true";
* The sensor is programmed to use a DPCM modes
* cil_settletime = "";
* MIPI lane settle time value.
* A "0" value attempts to autocalibrate based on mclk_multiplier
* active_w = "";
* Pixel active region width
* active_h = "";
* Pixel active region height
* pixel_t = "";
* The sensor readout pixel pattern
* readout_orientation = "0";
* Based on camera module orientation.
* Only change readout_orientation if you specifically
* Program a different readout order for this mode
* line_length = "";
* Pixel line length (width) for sensor mode.
* This is used to calibrate features in our camera stack.
* mclk_multiplier = "";
* Multiplier to MCLK to help time hardware capture sequence
* TODO: Assign to PLL_Multiplier as well until fixed in core
* pix_clk_hz = "";
* Sensor pixel clock used for calculations like exposure and framerate
* inherent_gain = "";
* Gain obtained inherently from mode (ie. pixel binning)
* min_gain_val = ""; (floor to 6 decimal places)
* max_gain_val = ""; (floor to 6 decimal places)
* Gain limits for mode
* min_exp_time = ""; (ceil to integer)
* max_exp_time = ""; (ceil to integer)
* Exposure Time limits for mode (us)
* min_hdr_ratio = "";
* max_hdr_ratio = "";
* HDR Ratio limits for mode
* min_framerate = "";
* max_framerate = "";
* Framerate limits for mode (fps)
* embedded_metadata_height = "";
* Sensor embedded metadata height in units of rows.
* If sensor does not support embedded metadata value should be 0.
mode0 { // IMX274_MODE_3840X2160
mclk_khz = "24000";
num_lanes = "4";
tegra_sinterface = "serial_c";
discontinuous_clk = "yes";
dpcm_enable = "false";
cil_settletime = "0";
active_w = "3840";
active_h = "2160";
pixel_t = "bayer_rggb";
readout_orientation = "90";
line_length = "4208";
inherent_gain = "1";
mclk_multiplier = "24";
pix_clk_hz = "576000000";
min_gain_val = "1.0";
max_gain_val = "22.2";
min_hdr_ratio = "1";
max_hdr_ratio = "1";
min_framerate = "1.5";
max_framerate = "30";
min_exp_time = "44";
max_exp_time = "666637";
mode1 { // IMX274_MODE_1920X1080
mclk_khz = "24000";
num_lanes = "4";
active_w = "1920";
active_h = "1080";
line_length = "4160";
max_framerate = "60";
min_exp_time = "58";
max_exp_time = "184611";
embedded_metadata_height = "1";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
liimx274_imx274_out0: endpoint {
status = "okay";
csi-port = <2>;
bus-width = <4>;
remote-endpoint = <&liimx274_csi_in0>;
lens_imx274@A6V26 {
min_focus_distance = "0.0";
hyper_focal = "0.0";
focal_length = "5.00";
f_number = "2.0";
aperture = "2.2";
tegra-camera-platform {
compatible = "nvidia, tegra-camera-platform";
* Physical settings to calculate max ISO BW
* num_csi_lanes = <>;
* Total number of CSI lanes when all cameras are active
* max_lane_speed = <>;
* Max lane speed in Kbit/s
* min_bits_per_pixel = <>;
* Min bits per pixel
* vi_peak_byte_per_pixel = <>;
* Max byte per pixel for the VI ISO case
* vi_bw_margin_pct = <>;
* Vi bandwidth margin in percentage
* max_pixel_rate = <>;
* Max pixel rate in Kpixel/s for the ISP ISO case
* isp_peak_byte_per_pixel = <>;
* Max byte per pixel for the ISP ISO case
* isp_bw_margin_pct = <>;
* Isp bandwidth margin in percentage
num_csi_lanes = <4>;
max_lane_speed = <1500000>;
min_bits_per_pixel = <10>;
vi_peak_byte_per_pixel = <2>;
vi_bw_margin_pct = <25>;
max_pixel_rate = <750000>;
isp_peak_byte_per_pixel = <5>;
isp_bw_margin_pct = <25>;
* The general guideline for naming badge_info contains 3 parts, and is as follows,
* The first part is the camera_board_id for the module; if the module is in a FFD
* platform, then use the platform name for this part.
* The second part contains the position of the module, ex. "rear" or "front".
* The third part contains the last 6 characters of a part number which is found
* in the module's specsheet from the vender.
modules {
module0 {
badge = "imx274_bottom_A6V26";
position = "bottom";
orientation = "1";
drivernode0 {
/* Declare PCL support driver (classically known as guid) */
pcl_id = "v4l2_sensor";
/* Driver v4l2 device name */
devname = "imx274 30-001a";
/* Declare the device-tree hierarchy to driver instance */
proc-device-tree = "/proc/device-tree/host1x/i2c@546c0000/tca9546@70/i2c@0/imx274_a@1a";
drivernode1 {
pcl_id = "v4l2_lens";
proc-device-tree = "/proc/device-tree/lens_imx274@A6V26/";
tegra210-jetson-cv-camera-imx274-a00.dtsi:
* Copyright (c) 2017, NVIDIA CORPORATION. All rights reserved.
* more details.
#include "tegra210-camera-imx274-a00.dtsi"
//#define CAM0_RST_L TEGRA_GPIO(S, 4)
#define CAM0_PWDN TEGRA_GPIO(S, 7)
#define CAMERA_I2C_MUX_BUS(x) (0x1E + x)
/* camera control gpio definitions */
host1x {
i2c@546c0000 {
tca9546@70 {
compatible = "nxp,pca9546";
reg = <0x70>;
#size-cells = <0>;
skip_mux_detect = "yes";
vcc-supply = <&en_vdd_cam>;
vcc_lp = "vcc";
force_bus_start = <CAMERA_I2C_MUX_BUS(0)>;
i2c@1 {
reg = <1>;
i2c-mux,deselect-on-exit;
#size-cells = <0>;
pca9570_a@24 {
compatible = "nvidia,pca9570";
reg = <0x24>;
channel = "a";
drive_ic = "DRV8838";
imx274_a@1a {
clocks = <&tegra_car TEGRA210_CLK_CLK_OUT_3>;
clock-names = "clk_out_3";
clock-frequency = <24000000>;
mclk = "clk_out_3";
reset-gpios = <&gpio CAM0_PWDN GPIO_ACTIVE_HIGH>;
vana-supply = <&en_vdd_cam_hv_2v8>;
vif-supply = <&en_vdd_cam>;
vdig-supply = <&en_vdd_cam_1v2>;
tegra210-jetson-cv-camera-modules.dtsi:
* the Free Software Foundation; version 2 of the License.
* more details.
#include "tegra210-jetson-cv-camera-imx274-a00.dtsi"
#include "tegra210-jetson-cv-camera-imx185-a00.dtsi"
#include "tegra210-jetson-cv-camera-e3333-a00.dtsi"
#include "tegra210-jetson-cv-camera-e3326-a00.dtsi"
#include "tegra210-jetson-cv-camera-e3323-a00.dtsi"
#define CAM1_RST_L TEGRA_GPIO(S, 5)
#define CAM1_PWDN TEGRA_GPIO(T, 0)
/* set camera gpio direction to output */
gpio: gpio@6000d000 {
camera-control-output-low {
gpio-hog;
output-low;
gpios = <CAM0_RST_L 0 CAM0_PWDN 0
CAM1_RST_L 0 CAM1_PWDN 0>;
label = "cam0-rst", "cam0-pwdn",
"cam1-rst", "cam1-pwdn";
/* all cameras are disabled by default */
host1x {
vi_base: vi {
ports {
vi_port0: port@0 {
reg = <0>;
status = "okay";
vi_in0: endpoint {
status = "okay";
vi_port1: port@1 {
reg = <1>;
status = "disabled";
vi_in1: endpoint {
vi_port2: port@2 {
reg = <2>;
vi_in2: endpoint {
vi_port3: port@3 {
reg = <3>;
vi_in3: endpoint {
vi_port4: port@4 {
reg = <4>;
vi_in4: endpoint {
vi_port5: port@5 {
reg = <5>;
vi_in5: endpoint {
csi_base: nvcsi {
csi_chan0: channel@0 {
reg = <0>;
status = "okay";
ports {
csi_chan0_port0: port@0 {
status = "okay";
status = "okay";
csi_chan0_port1: port@1 {
status = "okay";
status = "okay";
csi_chan1: channel@1 {
reg = <1>;
ports {
csi_chan1_port0: port@0 {
csi_in1: endpoint@2 {
csi_chan1_port1: port@1 {
csi_out1: endpoint@3 {
csi_chan2: channel@2 {
reg = <2>;
ports {
csi_chan2_port0: port@0 {
csi_in2: endpoint@4 {
csi_chan2_port1: port@1 {
csi_out2: endpoint@5 {
csi_chan3: channel@3 {
reg = <3>;
ports {
csi_chan3_port0: port@0 {
csi_in3: endpoint@6 {
csi_chan3_port1: port@1 {
csi_out3: endpoint@7 {
csi_chan4: channel@4 {
reg = <4>;
ports {
csi_chan4_port0: port@0 {
csi_in4: endpoint@8 {
csi_chan4_port1: port@1 {
csi_out4: endpoint@9 {
csi_chan5: channel@5 {
reg = <5>;
ports {
csi_chan5_port0: port@0 {
csi_in5: endpoint@10 {
csi_chan5_port1: port@1 {
csi_out5: endpoint@11 {
i2c@546c0000 {
e3326_cam0: ov5693_c@36 {
e3323_cam0: ov23850_a@10 {
e3323_vcm0: lc898212@72 {
cam_tca6408_21: tca6408@21 {
cam_tca9548_77: tca9548@77 {
i2c@0 {
e3333_cam0: ov5693_a@36 {
i2c@1 {
e3333_cam1: ov5693_b@36 {
i2c@2 {
e3333_cam2: ov5693_c@36 {
i2c@3 {
e3333_cam3: ov5693_d@36 {
i2c@4 {
e3333_cam4: ov5693_e@36 {
i2c@5 {
e3333_cam5: ov5693_f@36 {
default {
gpio-output-low = <0 1 2 3 4 5 6 7>;
tca9546_70: tca9546@70 {
status = "okay";
i2c@1 {
imx185_cam0: imx185_a@1a {
imx274_cam0: imx274_a@1a {
status = "okay";
i2c@7000c000 {
e3323_cam1: ov23850_c@36 {
e3323_vcm1: lc898212@72 {
tcp: tegra-camera-platform {
isp_peak_byte_per_pixel = <2>;
modules {
cam_module0: module0 {
status = "okay";
cam_module0_drivernode0: drivernode0 {
status = "okay";
cam_module0_drivernode1: drivernode1 {
status = "okay";
cam_module1: module1 {
cam_module1_drivernode0: drivernode0 {
cam_module1_drivernode1: drivernode1 {
cam_module2: module2 {
cam_module2_drivernode0: drivernode0 {
cam_module2_drivernode1: drivernode1 {
cam_module3: module3 {
cam_module3_drivernode0: drivernode0 {
cam_module3_drivernode1: drivernode1 {
cam_module4: module4 {
cam_module4_drivernode0: drivernode0 {
cam_module4_drivernode1: drivernode1 {
cam_module5: module5 {
cam_module5_drivernode0: drivernode0 {
cam_module5_drivernode1: drivernode1 {
Note:
I changed i2c settings as you can see in the device tree, and after that I checked the i2c lines and this configuration seems correct. And imx274 probe and vi probe finished successfully, so I can see video0 in /dev directory.
So, Do you have any idea what is the problem ?
What does nvcamera-daemon say in the error code?
Thanks,
Şükrü.
