IMX334 CSI Camera interface with Jetson orin NX
I am new to Jetson Orion NX. Below is my setup details,
Baord : Jetson Orion NX
SDK: Jetpack 6.2
Camera : IMX334
The first trial with Arducam IMX477 was successful at 4K, 30fps.
The second trail with sensor IMX334 is unsuccessful,
  1. I have used Public_Source IMX334 V4L2 Driver and compiled with the same SDK with the help of the kernel customization procedure
  2. Created dts and dtsi files. Compiled to dtso. copied to /boot/dts
  3. Inserted compiled module IMX334.ko by insmod
  4. After insmod and restart, I have observed the module is used by “0”. Veryfied dmesg, nothing with imx334
  5. I have modified the driver according to Nvidia native driver with reference to imx185 and imx274. Same result
  6. Initially, i am checking for the Clock generation (24MHz ) and the basic i2c communication. No luck
  7. I have attached the driver source and dts files, Let me know the basic tests ( How i can loop back the Mclk signal and I2c communication)
  8. I have verified voltages on the board Avdd, IOvdd and core properly
    tegra234-p3737-camera-imx334-overlay.zip (5.7 KB)
    imx334_mode_tbls.zip (10.1 KB)
I think you posted on the wrong forum. Try the Orin NX forum: Jetson Orin NX - NVIDIA Developer Forums
