IMX728 on CSI‑C fails to start with sample_camera (no deserializer detected / sipl status 10)
Summary
We are evaluating IMX728 cameras with the DriveWorks SDK on DRIVE Thor using the sample_camera application on DriveOS 7.0.3.
When the camera is connected to the CSI-C interface, sample_camera fails during initialization with either of the following errors:
DW_INVALID_ARGUMENT: CameraMaster: no deserializer detected, cannot initialize NvSIPL.
or
DW_UNEXPECTED_EVENT: CameraMaster::resume failed with sipl status 10
However, with the same hardware setup, nvsipl_camera works correctly and displays video as expected.
We understand that the camera module we are currently using does not exactly match an officially supported NVIDIA camera configuration.
  • Officially supported camera: BF8S103G-100-00
  • Camera currently in use: BF8S103G-100-01
Even with that limitation in mind, we would like to confirm whether CSI-C is expected to work with IMX728 in the DriveWorks SDK, and if so, what the correct configuration should be.
Environment
  • Platform: NVIDIA DRIVE Thor (P3960)
  • Software:
  • DRIVE OS 7.0.3
  • DriveWorks SDK 7.0.3
  • Camera configuration: Smartlead BF8S103G-100-01
  • Connection:
  • Interface: CSI-C
  • 4 x IMX728 cameras connected
Application Used
We tested the DriveWorks sample_camera sample located under:
/usr/local/driveworks/samples/src/sensors/camera/camera
Rig Parameter Configuration
The following parameter string was used in the rig file:
camera-name=R0SIM728S3RU2120NB2,
interface=csi-c,
deserializer=MAX96792A_Fusa_nv,
disable-custintf=1,
skip-eeprom=1,
CPHY-mode=1,
link=0,
output-format=raw+processed,
async-record=1,
file-buffer-size=16777216,
format=mp4,
nito-file=/usr/share/camera/R0SIM728S3RU2120NB2.nito
Rig file used:
rig_IMX728x1.json
Observed Error in sample_camera
When we run sample_camera with the above configuration, we get the following error:
[26-04-2026 23:46:51] Driveworks exception thrown: DW_INVALID_ARGUMENT: CameraMaster: no deserializer detected, cannot initialize NvSIPL.
Related log file:
CSI-C_link=0_Faile.txt
Verification with nvsipl_camera
Using the same hardware configuration, we confirmed that the camera works correctly with nvsipl_camera and video is displayed as expected.
Command used:
./nvsipl_camera \
--platform-config "R0SIM728S3RU2120NB2_5Des_CPHY_x2" \
--link-enable-masks "0x0000 0x11 0x0000 0x0000 0x0000" \
--showfps -d 1
Behavior When the Deserializer Parameter Is Removed
If we remove the following parameter from the rig:
DriveWorks then fails with the following log:
[26-04-2026 23:55:58] CameraMaster: master init failed with status = 10
[26-04-2026 23:55:58] Driveworks exception thrown: DW_UNEXPECTED_EVENT: CameraMaster::resume failed with sipl status 10
Related log file:
CSI-C_link=0_Faile__no_deserializer.txt
Status on Other CSI Interfaces
Based on the deserializer names documented here:
we confirmed that IMX728 works correctly with the DriveWorks SDK on the following interfaces:
  • CSI-GH
  • CSI-EF
  • CSI-D
  • CSI-AB
The issue occurs only when using CSI-C.
Questions
  1. Is CSI-C supported for IMX728 when using the DriveWorks SDK on DRIVE Thor?
  2. If CSI-C is supported, what is the correct deserializer name or rig configuration for this interface?
  3. Is it expected that nvsipl_camera works, while DriveWorks sample_camera fails with SIPL status 10?
  4. If CSI-C can be used with IMX728 in the DriveWorks SDK, are there any additional requirements or platform-config constraints that must be satisfied?
CSI-C_link=0_Faile__no_deserializer.txt|attachment (25.5 KB)
rig_IMX728x1.json.txt (1.2 KB)
CSI-C_link=0_Faile.txt|attachment (8.8 KB)
Let me check on this and get back to you.
Dear @Natsuha_Shishido ,
Could you connect camera on csi-ab, csi-c port and run nvsipl_camera with verbose flag and share nvsipl_camera and syslog for both cases?
Dear @SivaRamaKrishnaNV
csi-ab
./nvsipl_camera --platform-config “R0SIM728S3RU2120NB2_5Des_CPHY_x4” --link-enable-masks “0x1111 0x00 0x0000 0x0000 0x0000” --showfps -d 1 -v 4
csi-c
./nvsipl_camera --platform-config “R0SIM728S3RU2120NB2_5Des_CPHY_x2” --link-enable-masks “0x0000 0x11 0x0000 0x0000 0x0000” --showfps -d 1 -v 4
IMX728__csi-ab__link=0-3 -v 4.log|attachment (1.2 MB)
IMX728__csi-c__link=0-1 -v 4.log|attachment (689.7 KB)
Could you please share the /var/log/syslog for both cases. Clear the syslog file before running each command to ensure only application related info is logged.
Understood.
I got the log again.
IMX728__csi-c__link=0-1 -v 4 1.log|attachment (689.7 KB)
syslog_csi-ab.txt (530.2 KB)
syslog_csi-c.txt (311.3 KB)
IMX728__csi-ab__link=0-3 -v 4 1.log|attachment (1.2 MB)
Could you try with deserializer=MAX96792A in gmsl parameters. I notice deserializer value as MAX96792A when dumping platform configuration in /var/log/syslog with nvsipl_camera in verbose mode . CSI-C supports only 2 IMX728 cameras .
Did you get chance to test? Could you please provide any feedback here?
I’m back from vacation.
i will try.
Adding deserializer=MAX96792A as a parameter, it worked properly. thank you very much.
