Valeo 120° Camera with Sony IMX728 Sensor on Drive AGX Thor?
DRIVE OS Version: 7.0.3
Issue Description: We are currently trying to get our Valeo Cameras with Sony IMX728 sensor running on Nvidia Drive AGX Thor with DriveOS 7.0.3 via nvsipl_camera sample. Unfortunately it seems we got the connection right, but in the log it shows that our IMX728 revision is not supported by the Camera configuration. It says we have a 0x34 revision instead of 0x31. Is there any way to get a working configuration for our revision on Thor?
./nvsipl_camera --platform-config “R0SIM728S3RU2120NB2_5Des_CPHY_x4” --link-enable-masks “0x0000 0x0000 0x0000 0x1000 0x0000” -d 1
Pipeline: 13 ISP Output: 0 is using YUV 420 SEMI-PLANAR UINT8 BL REC_709ER
Pipeline: 13 ISP Output: 1 is using YUV 420 SEMI-PLANAR UINT8 BL REC_709ER
Pipeline: 13 ISP Output: 2 is using YUV 420 SEMI-PLANAR UINT8 BL REC_709ER
MAX96712: Revision 5 detected
MAX96712 Link 3: PHY optimization was enabled
MAX96717: Revision 6 detected!
Unsupported IMX728 revision 0x34 detected! Supported revisions are:
IMX728 Rev 0x31
nvsipl_camera: ERROR: NvSIPLCamera Init failed
nvsipl_camera: ERROR: Master initialization failed. status: 2
nvsipl_camera: ERROR: GetSyncObj failed. status: 10
nvsipl_camera: ERROR: Compositor: UnregisterNvSciSyncObjs failed
R0SIM728S3RU2120NB2_5Des_CPHY_x4 is for smart lead IMX728 camera and supported sensors are listed at DRIVE Ecosystem Thor Vendor | NVIDIA Developer
For the Valeo 120 degree camera, this command should probably work for you with a camera plugged into the first pin of the first port:
sudo ./nvsipl_camera -c V1SIM728MPRU4120HD1_MAX96724_CPHY_x4 --link-enable-masks "0x0000 0x0000 0x1000" --disableAuth --num-disp 1
Dear @adas.developer ,
Could you please provide an update to this topic?
Hi, sorry for the late reply. It finally worked with this configuration. Thanks for the hint! Is it normal that when only one camera is connected to A0 (green cable), the monitor shows 3 times the same image in the bottom right corner? Can you also display it only once in fullscreen with this sample?
Could you share the used commands and output display?
Could you please provide any update for this topic?
The issues I had are fixed. Thanks!
