Greetings! I haveencountered the problem of I2C read and write register failure when configuring the serializer. Considering that the serializer I am using has an 8-bit address, and NvMedia provides the DevBlkCDII2CPgmrWriteUint8 method using a16-bit address, is there a way to read and write an 8-bit address?
heath98
1
kayccc
2
Which platform you’re using?
If youre using Jetson platform, please opne your issue at Latest Autonomous Machines/Jetson & Embedded Systems topics - NVIDIA Developer Forums
Related topics
| Gmsl1 max9296: i2c read/write registers OK max9271: i2c read/write registers KO | 3 | 1428 | January 10, 2022 | |
| DevBlkCDIDeviceWrite write failed | 6 | 824 | July 8, 2021 | |
| [L4T28.1 TX1]VI-I2C read/write fail for some register addresses | 5 | 657 | September 13, 2017 | |
| Camera Module I2C Transaction Nvsipl Camera | 1 | 459 | December 14, 2023 | |
| I2c write reg failed! | 4 | 854 | August 16, 2022 | |
| Can jetson NX application layer I2C read 8-bit? | 0 | 489 | May 23, 2022 | |
| I2C setting change during Jetson TX2 operation | 5 | 603 | December 16, 2020 | |
| Custom sensor device driver i2c issue in Jetson TX2 | 5 | 1127 | October 15, 2020 | |
| I2c tool reads sensor error | 3 | 1926 | January 16, 2019 | |
| The Parallel to CSI-2 bridge TC358748 driver , I2C read 16bit reg issue | 2 | 1156 | June 6, 2018 |
