Inject NVDS_ANALYTICS in running pipeline
Hello all,
I have a running pipeline for object detection where I use the component nvds_analytics to count objects in a certain region.
My question here is, am I able to modify the ROI of this analytics while the pipeline is running?
Or do I need to stop the pipeline, change the config file with the new ROI and then start again the pipeline?
• DeepStream Version
• TensorRT Version
please refer to this topic.
why do you need to modify the ROI dynamically? did you try the solution above? Thank you!
