How to use Gst-nvdsanalytics plugin correctly?
1,I was using Gst-nvdsanalytics plugin when I learned that it can set ROI, but my current requirement is that this ROI is dynamic.
With my own speed, the coordinates of this ROI should be changed according to a certain algorithm. I want to know, does the plugin Gst-nvdsanalytics plugin support dynamic setting of parameters?
If it doesn’t, do I need to keep updating the pipeline and then update the plugin’s parameters? This doesn’t seem reasonable, how can I solve it?
There is no update from you for a period, assuming this is not an issue anymore. Hence we are closing this topic. If need further support, please open a new one.
No.
No. The pipeline should be stopped and restarted with updated configuration files.
No, it is not reasonable. You may need to implement your own analytics plugin.
