Hi I want to install cdc_acm in jetson nano having jetpack 4.6.1 (Ubuntu 18.04). I cannot find cdc_acm.ko I tried the approach mentioned by Jetsonhacks but it is for a different version of kernel and doesn’t work for me. Can you please let me know how to solve this issue thank you.
What do you see from this:
zcat /proc/config.gz | grep -i acm
Also, what do you see from “uname -r”?
Hi @linuxdev for zcat /proc/config.gz | grep -i acm I get the following output
# CONFIG_FB_MACMODES is not set
CONFIG_USB_ACM=m
CONFIG_USB_F_ACM=y
CONFIG_USB_CONFIGFS_ACM=y
For uname -r this is the response
4.9.337-tegra
I have set up a udev rule as SUBSYSTEM=="USB", ATTRS{idVendor} =="2ca3", MODE ="0666" and my lsusb output is
Bus 002 Device 002: ID 0bda:0411 Realtek Semiconductor Corp.
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 006: ID 7392:a611 Edimax Technology Co., Ltd
Bus 001 Device 005: ID 413c:2514 Dell Computer Corp.
Bus 001 Device 004: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Bus 001 Device 003: ID 2ca3:001f
Bus 001 Device 002: ID 0bda:5411 Realtek Semiconductor Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
When I do disconnect the drone,
dmesg --follow
and reconnect I get the following output
[ 349.087895] usb 1-2.1: New USB device found, idVendor=2ca3, idProduct=001f
[ 349.087901] usb 1-2.1: New USB device strings: Mfr=2, Product=3, SerialNumber=4
[ 349.087904] usb 1-2.1: Product: DJI
[ 349.087908] usb 1-2.1: Manufacturer: DJI
[ 349.087911] usb 1-2.1: SerialNumber: 0123456789ABCDEF
[ 349.091439] rndis_host 1-2.1:1.0 usb0: register 'rndis_host' at usb-70090000.xusb-2.1, RNDIS device, 82:46:74:d6:7b:49
[ 349.095336] usb-storage 1-2.1:1.2: USB Mass Storage device detected
[ 349.108812] scsi host0: usb-storage 1-2.1:1.2
[ 349.234816] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 350.131502] scsi 0:0:0:0: Direct-Access DJI File-CD Gadget 0310 PQ: 0 ANSI: 2
[ 350.141519] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 350.147526] scsi 0:0:0:1: Direct-Access DJI File-CD Gadget 0310 PQ: 0 ANSI: 2
[ 350.149838] scsi 0:0:0:2: Direct-Access DJI File-CD Gadget 0310 PQ: 0 ANSI: 2
[ 350.151755] sd 0:0:0:1: [sdb] Attached SCSI removable disk
[ 350.152363] sd 0:0:0:2: [sdc] 31108096 512-byte logical blocks: (15.9 GB/14.8 GiB)
[ 350.152537] sd 0:0:0:2: [sdc] Write Protect is off
[ 350.152541] sd 0:0:0:2: [sdc] Mode Sense: 03 00 00 00
[ 350.152731] sd 0:0:0:2: [sdc] No Caching mode page found
[ 350.152735] sd 0:0:0:2: [sdc] Assuming drive cache: write through
[ 350.161176] sdc:
[ 350.170323] sd 0:0:0:2: [sdc] Attached SCSI removable disk
[ 350.453000] FAT-fs (sdc): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
Also for this command sudo lsusb -d 2ca3:001f -vvv I get the following output
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 0 (Defined at Interface level)
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x2ca3
idProduct 0x001f
bcdDevice ff.ff
iManufacturer 2 DJI
iProduct 3 DJI
iSerial 4 0123456789ABCDEF
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 187
bNumInterfaces 6
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xc0
Self Powered
MaxPower 0mA
Interface Association:
bLength 8
bDescriptorType 11
bFirstInterface 0
bInterfaceCount 2
bFunctionClass 224 Wireless
bFunctionSubClass 1 Radio Frequency
bFunctionProtocol 3 RNDIS
iFunction 7 RNDIS
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 224 Wireless
bInterfaceSubClass 1 Radio Frequency
bInterfaceProtocol 3 RNDIS
iInterface 5 RNDIS Communications Control
** UNRECOGNIZED: 05 24 00 10 01
** UNRECOGNIZED: 05 24 01 00 01
** UNRECOGNIZED: 04 24 02 00
** UNRECOGNIZED: 05 24 06 00 01
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0008 1x 8 bytes
bInterval 9
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 10 CDC Data
bInterfaceSubClass 0 Unused
bInterfaceProtocol 0
iInterface 6 RNDIS Ethernet Data
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0200 1x 512 bytes
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x08 EP 8 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 8 Mass Storage
bInterfaceSubClass 6 SCSI
bInterfaceProtocol 80 Bulk-Only
iInterface 1 Mass Storage
bLength 7
bDescriptorType 5
bEndpointAddress 0x83 EP 3 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x09 EP 9 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 3
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 255 Vendor Specific Class
bInterfaceSubClass 67
bInterfaceProtocol 1
iInterface 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x84 EP 4 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x0a EP 10 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 8
bDescriptorType 11
bFirstInterface 4
bInterfaceCount 2
bFunctionClass 2 Communications
bFunctionSubClass 2 Abstract (modem)
bFunctionProtocol 1 AT-commands (v.25ter)
iFunction 10 CDC Serial
bLength 9
bDescriptorType 4
bInterfaceNumber 4
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 2 Communications
bInterfaceSubClass 2 Abstract (modem)
bInterfaceProtocol 1 AT-commands (v.25ter)
iInterface 8 CDC Abstract Control Model (ACM)
CDC Header:
bcdCDC 1.10
CDC Call Management:
bmCapabilities 0x00
bDataInterface 5
CDC ACM:
bmCapabilities 0x02
line coding and serial state
CDC Union:
bMasterInterface 4
bSlaveInterface 5
bLength 7
bDescriptorType 5
bEndpointAddress 0x86 EP 6 IN
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x000a 1x 10 bytes
bInterval 9
bLength 9
bDescriptorType 4
bInterfaceNumber 5
bAlternateSetting 0
bNumEndpoints 2
iInterface 9 CDC ACM Data
bLength 7
bDescriptorType 5
bEndpointAddress 0x85 EP 5 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x0b EP 11 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
Device Qualifier (for other device speed):
bLength 10
bDescriptorType 6
bcdUSB 2.00
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
Device Status: 0x0003
Self Powered
Remote Wakeup Enabled
I am not sure if the rule is being used properly and the device is getting mapped to any tty* .
For usb-devices it outputs
T: Bus=01 Lev=02 Prnt=02 Port=00 Cnt=01 Dev#= 3 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=2ca3 ProdID=001f Rev=ff.ff
S: Manufacturer=DJI
S: Product=DJI
S: SerialNumber=0123456789ABCDEF
C: #Ifs= 6 Cfg#= 1 Atr=c0 MxPwr=0mA
I: If#= 0 Alt= 0 #EPs= 1 Cls=e0(wlcon) Sub=01 Prot=03 Driver=rndis_host
I: If#= 1 Alt= 0 #EPs= 2 Cls=0a(data ) Sub=00 Prot=00 Driver=rndis_host
I: If#= 2 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=usb-storage
I: If#= 3 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=43 Prot=01 Driver=(none)
I: If#= 4 Alt= 0 #EPs= 1 Cls=02(commc) Sub=02 Prot=01 Driver=(none)
I: If#= 5 Alt= 0 #EPs= 2 Cls=0a(data ) Sub=00 Prot=00 Driver=(none)
I am not sure why If#=3, 4 and 5 are not loaded.
This means you already have the ACM driver:
CONFIG_USB_ACM=m
CONFIG_USB_F_ACM=y
The two which are “=y” are directly compiled into the kernel, so they always exist, cannot be unloaded, and will never have a module to find. The “=m” one will have a module. What do you see from:
cd /lib/modules/$(uname -r)/kernel
find . -iname '*acm*'
modprobe cdc-acm
lsmod | grep -i 'acm'
Also, what do you see from:
dmesg | grep -i 'acm'
Now I have this question for you: What was the purpose of the udev rule, and have you created this or edited this? What is the history of working on udev triggers? Does some software you have require renaming the serial port?
Hi @linuxdev I was able to make the cdc_acm.ko based on your earlier suggestion for another question and the repo by JetsonHacks GitHub - jetsonhacks/jetson-linux-build: Tools to build the Linux kernel and modules on board Jetson Developer Kits. I changed their getKernelSources.sh to download the right source files for 4.6.5 and their example build-module.sh to build cdc_acm.ko. After that it is working now.
Udev rule is actually given by the drone manufacturer DJI. I am using it as per their instruction.
Glad it worked out. udev itself is quite useful for manufacturers; it allows them to use standard generic drivers, but still rename their USB device to something just for them after they identify their specific device.
