What should I choose between ‘Device accesses Internet via router/switch.’ and ‘Device a accesses Internet via host machine through setting up a new DHCP server configuration on host.’
There is no extra router, and the router is far from the PC.
I would be grateful if you could let me know what choice I should make.
what if I can not install the ‘Jetpack3.1’ with WiFi?
I already told you that I’m using L4T 28.1 version in my first post.
I want to install jetpack 3.1 version.
My Host PC is wire internet. but TX2 use wifi.
What should I choose between ‘Device accesses Internet via router/switch.’ and ‘Device a accesses Internet via host machine through setting up a new DHCP server configuration on host.’ ?
Sorry about that. Then back to my first comment, is your PC able to ping your tegra device IP?
Normally, we use ‘Device accesses Internet via router/switch.’
I know what your concern is. But I think it is fine to just select “Device accesses Internet via router/switch”
You should face one error after “Device accesses Internet via router/switch”. Please ignore this one and re-open jetpack again. Choose only what you want to install except flashing board. Then enter the wifi ip when jetpack asks your prompt of ip.
Finished Flashing OS
Determining the IP address of target...
192.168.0.xxx
Waiting 30 seconds to make sure target is fully up
Host 192.168.0.105 not found in /home/jc/.ssh/known_hosts
/home/jc
Identity added: /home/jc/.ssh/id_rsa (/home/jc/.ssh/id_rsa)
scp -F /dev/null -o PubkeyAuthentication=no -o ConnectTimeout=30 -o StrictHostKeyChecking=no
/home/jc./ssh/id_rsa.pub nvidia@192.168.0.xxx:/home/nvidia/tmp.pub
host 192.168.0.105 port 22: Connection timed out
This would be from a private subnet issued by a router, and without the router, not able to access the real internet. Another computer connected to the same router could find this valid.
The “175.209.49.xxx” address is on a different subnet. Direct communications between two subnets is not normally possible unless you have a gateway to traverse the two subnets. Unless you have an expensive high end router, then the router won’t have this ability…if you do have such a router, then it would need to be explicitly told to do this.
