I’ve already installed PGI Fortran/C/C++ server on my cluster, and I can compile my file when I was in the master node.
However, when I used ssh to come to other slave node, I cannot compile my code there, the error message is: LICENSE MANAGER PROBLEM: Failed to checkout license, how can I fix this problem and compile on every slave node?
I was using local installation when I went through the procedure, is this the reason?
BTW, is there any way to uninstall PGI?
Please help me on this, thanks.
Hi CFDLab,
This will depend upon what type of license you have. A Workstation license only allows for compilation on a single system (i.e. Node-locked). For multiple systems such as a cluster, you need a Server or Cluster Development Kit (CDK) license.
In either case, please send a note to PGI Customer Support (license@pgroup.com) since they will have access to your account. Please include your PGI PIN number. The PIN number can be found in your PGI license.dat file (typically located in the root PGI directory, i.e. /opt/pgi). Search for the 6 digit number listed after the “VENDOR_STRING=”.
Hi, Mat,
Thanks for your answer, now I’m going to download PGI CDK and reinstall it in my cluster, but there are some problems occurred when I try to fill the list.
For the question: How many sockets per cluster node?
My cluster now include one master node and five slave nodes, the spec. of each slave node is Intel Core i7 990X with 6 cores and 12 threads, how should I fill the list with those spec. since I don’t know how to calculate the sockets per node.
In addition, currently I have PGI Server in my system, since I am going to install PGI CDK instead, how to uninstall the original one in my system, thanks.
Hi CFDLab,
Sorry, I’m not clear what you mean here. Which list?
A socket is where the CPU chip is placed on the motherboard. So in other words, how many Core i7 990X chips are in each node?
You don’t need to since the compilers are the same between the Server and CDK. The CDK just gives you more pre-built cluster libraries and unlocks additional features in the compilers. The CDK install will simply replace what’s already there.
Though, if you do really want to remove everything first, “rm -rf $PGI” will do it.
Hi, Mat,
Very thanks for your help, I will try to install the CDK compiler, thanks.
Hi, Mat
Previously I was downloading the PGI Server Fortran/C/C++ 2011 Release and use the trial license from this website, is this the reason that I use a trial license so that users can only compile their code in the master node instead of both master and slaver nodes? Thanks.
Hi CFDLab,
A trial license is node locked. So yes, this would be why it only worked on the head node.
