Install pynuitrack on Jetson orin AgX
HI,
I tried to install pynuitrack on Jetson Orin Agx board. Initially, I tried using pip installation with .whl files fro arm64, which are provided in nuitrack-sdk/PythonNuitrack-beta at v0.37.16 · 3DiVi/nuitrack-sdk · GitHub but it did not work. When I import it core is dumped.
then i build the library from the source code available at GitHub - silasalves/pynuitrack: Python wrapper for NuiTrack skeleton tracking library. it working, but the source code is too old. It does not support the latest functions.
How do I install the latest versions of PyNuitrack on Jetson orin AgX. I cannot find the latest source codes.
Please note that i have installed Nuitrack SDK and it is working well. i used this GitHub - 3DiVi/nuitrack-sdk at v0.35.6
Moved to Jetson AGX Orin forum
David.
thanks @dhart . looking for some directions
It looks like the package doesn’t have a prebuilt for the Jetson environment.
Have you tried to build it from the source to see if it works?
Thansk.
Thank you for the suggestion. But this source code is 6 years old, which does not have the latest functions on it. By the way, I have installed the latest pynuitrack version. It requires Python 3.8.8. Otherwise it does not work.
