Hello
I already reviewed this forum and saw couple of similar problems but sadly no solution helped me so far, thus I would like to ask for help.
I can not install driver on fresh installation of CentOS 7. I’ve tried various versions with various installation options: 450.66, 460.67, 470.94 with very similar results like this:
ERROR: Unable to load the 'nvidia-drm' kernel module.
ERROR: Installation has failed. Please see the file '/var/log/nvidia-installer.log' for details. You may find suggestions on fixing installation problems
I also tried kmod-nvidia from elrepo - resulted as black screen at loading OS. I’ve blacklisted nouveau driver:
[root@localhost log]# lshw -numeric -C display
*-display UNCLAIMED
description: VGA compatible controller
product: NVIDIA Corporation [10DE:2520]
vendor: NVIDIA Corporation [10DE]
physical id: 0
bus info: pci@0000:01:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller bus_master cap_list
configuration: latency=0
resources: iomemory:600-5ff iomemory:620-61f memory:5d000000-5dffffff memory:6000000000-61ffffffff memory:6200000000-6201ffffff ioport:4000(size=128) memory:5e080000-5e0fffff
*-display UNCLAIMED
product: Intel Corporation [8086:9A60]
vendor: Intel Corporation [8086]
physical id: 2
bus info: pci@0000:00:02.0
version: 01
width: 64 bits
clock: 33MHz
capabilities: pciexpress msi pm vga_controller bus_master cap_list
resources: iomemory:620-61f iomemory:400-3ff memory:6202000000-6202ffffff memory:4000000000-400fffffff ioport:5000(size=64)
I’ve tried to investigate and found disturbing messages in system logs:
Jan 7 13:44:12 localhost kernel: NVRM: Can't find an IRQ for your NVIDIA card!
Jan 7 13:44:12 localhost kernel: NVRM: Please check your BIOS settings.
Jan 7 13:44:12 localhost kernel: NVRM: [Plug & Play OS] should be set to NO
Jan 7 13:44:12 localhost kernel: NVRM: [Assign IRQ to VGA] should be set to YES
Jan 7 13:44:12 localhost kernel: nvidia: probe of 0000:01:00.0 failed with error -1
Jan 7 13:44:12 localhost kernel: NVRM: The NVIDIA probe routine failed for 1 device(s).
Jan 7 13:44:12 localhost kernel: NVRM: None of the NVIDIA devices were initialized.
but I do not have such options (Plug & Play OS/Assign IRQ to VGA) in my BIOS. My Acer Nitro (AN517-54-718T) laptop has GeForce RTX3060. nvidia-bug-report in attachment.
I will appreciate your help!
Regards
Marcin
nvidia-bug-report.log (284.9 KB)
