I have an Single Board Computer with onboard display port(DP) with provision of XMC slot. Mounting a XMC frame grabber which has NVIDIA graphics(Quadro Pascal) and a display port, installing NVIDIA driver routes the display of SBC over GPGPU(frame grabber DP). There is a consistent issue of the display not coming up from frame grabber DP most of the times, though SBC boots successfully. The NVIDIA driver used comes along CUDA toolkit 10.2. Is there a provision to not use frame grabber DP and use SBC onboard DP?
