I have followed theses instructions Building Blender/Linux/Ubuntu - Blender Developer Wiki
upon setting up the build environment i had skip opencolorio openimageio and llvm
./blender/build_files/build_environment/install_deps.sh --skip-ocio --skip-oiio --skip-llvm
Now i need to configure those things i skipped to install cycles renderer.
How do i configure opencolorio openimageio and llvm for this l4t aarch64 setup?
I would imagine you could add those packages (and their dev version) and then recompile…haven’t tried.
I do see the existence of packages “libopenimageio” (and “libopenimageio-dev”), plus “openimageio-tools”. Similar for “libopencolorio”, “libopencolorio-dev”, and “opencolorio-tools”. There are also some python bindings packages…blender tends to rely on python, so perhaps those too are needed. Additionally, there are packages “llvm” and “llvm-dev” plus python related versions…it isn’t quite as clear though as there are many versions available for llvm.
Note: Don’t know which repositories these are in, I have all of them uncommented in “/etc/apt/sources.list”.
git cloned each skipped package then continued with the cmake build. sudo apt-get install of separate tools and dev packages will not make a difference when installing. i am currently running blender.
