Hello.
Suppose that I’ve an AMD GPU or an NVIDIA GPU that isn’t CUDA capable. Which driver I need to install for compiling/running in the emulated mode?
thanks.
Hello.
thanks.
Hello.
thanks.
No special driver is required as far as I know, but you need a historic CUDA version up to 3.0 that still supports device emulation.
A better idea would probably be to use ocelot, which works with current CUDA versions and comes a lot closer to how the code would be executed on a GPU.
It’s clear tera. Thanks.
I’m wondering why NVidia decided discontinue the support for emulated mode natively?
I too…
I too…
