DaveYYY
3
What L4T version do you use?
If your GUI means SDK Manager, and you are using 35.4.1 (JetPack 5.1.2), then the issue is here:
If you want to use flashing scripts instead, flash.sh does not support flashing into NVMe, and you have to use initrd flash instead:
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c ./tools/kernel_flash/flash_l4t_external.xml --showlogs --network usb0 jetson-agx-xavier-devkit nvme0n1p1
