Laptop Acer V 15 Nitro VN7-571G 12 GB GeForce GTX 850M
OS: Kali Linux 2016.1 Rolling Installed on HDD
output:
uname -a
Linux kali 4.5.0-kali1-amd64 #1 SMP Debian 4.5.5-1kali1 (2016-06-06) x86_64 GNU/Linux
output :lspci -v | egrep -i ‘vga|3d|nvidia’ | grep -i ‘nvidia’ output
03:00.0 3D controller: NVIDIA Corporation GM107M [GeForce GTX 850M] (rev ff) (prog-if ff)
Kernel modules: nvidia
I have a problem running the drivers for my Nvidia,I found the online tutorial on this page wheresmykeyboard.com and step by step I used the instructions contained therein.
First error i got after command lsmod | grep -i ‘vga_switcheroo’ I ignored it and went further,
I ran ./Downloads/cuda_7.5.18linux.run --override compiler and this is what I got.
Do you accept the previously read EULA? (accept/decline/quit): accept
You are attempting to install on an unsupported configuration. Do you wish to continue? ((y)es/(n)o) [ default is no ]: y
Install NVIDIA Accelerated Graphics Driver for Linux-x86_64 352.39? ((y)es/(n)o/(q)uit): y
Do you want to install the OpenGL libraries? ((y)es/(n)o/(q)uit) [ default is yes ]: y
Install the CUDA 7.5 Toolkit? ((y)es/(n)o/(q)uit): y
Enter Toolkit Location [ default is /usr/local/cuda-7.5 ]:
Do you want to install a symbolic link at /usr/local/cuda? ((y)es/(n)o/(q)uit): y
Install the CUDA 7.5 Samples? ((y)es/(n)o/(q)uit): y
Enter CUDA Samples Location [ default is /root ]:
Installing the NVIDIA display driver…
The driver installation has failed due to an unknown error. Please consult the driver installation log located at /var/log/nvidia-installer.log.
= Summary =
Driver: Installation Failed
Toolkit: Installation skipped
Samples: Installation skipped
Logfile is /tmp/cuda_install_4388.log this is output:
sing more to view the EULA.
Verifying archive integrity… OK
Uncompressing NVIDIA Accelerated Graphics Driver for Linux-x86_64 352.39…
WARNING: You do not appear to have an NVIDIA GPU supported by the 352.39
NVIDIA Linux graphics driver installed in this system. For
further details, please see the appendix SUPPORTED NVIDIA GRAPHICS
CHIPS in the README available on the Linux driver download page at
www.nvidia.com.
ERROR: The installation was canceled due to the availability or presence of
an alternate driver installation. Please see
/var/log/nvidia-installer.log for more details.
Welcome to the NVIDIA Software Installer for Unix/Linux
Detected 4 CPUs online; setting concurrency level to 4.
License accepted by command line option.
Installing NVIDIA driver version 352.39.
The NVIDIA driver appears to have been installed previously using a
different installer. To prevent potential conflicts, it is recommended
either to update the existing installation using the same mechanism by
which it was originally installed, or to uninstall the existing
installation before installing this driver.
Please review the message provided by the maintainer of this alternate
installation method and decide how to proceed:
Please use the Debian packages instead of the .run file.
(Answer: Abort installation)
= Summary =
This is output from /var/log/nvidia-installer.log.
nvidia-installer log file ‘/var/log/nvidia-installer.log’
creation time: Sun Jun 19 19:50:31 2016
installer version: 352.39
PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/opt/VirtualGL/bin:/usr/local/cuda-7.5/bin
nvidia-installer command line:
./nvidia-installer
–ui=none
–no-questions
–accept-license
–disable-nouveau
–dkms
Using built-in stream user interface
→ Detected 4 CPUs online; setting concurrency level to 4.
WARNING: You do not appear to have an NVIDIA GPU supported by the 352.39 NVIDIA Linux graphics driver installed in this system. For further details, please see the appendix SUPPORTED NVIDIA GRAPHICS CHIPS in the README available on the Linux driver download page at www.nvidia.com.
→ License accepted by command line option.
→ Installing NVIDIA driver version 352.39.
→ The NVIDIA driver appears to have been installed previously using a different installer. To prevent potential conflicts, it is recommended either to update the existing installation using the same mechanism by which it was originally installed, or to uninstall the existing installation before installing this driver.
Please review the message provided by the maintainer of this alternate installation method and decide how to proceed:
ERROR: The installation was canceled due to the availability or presence of an alternate driver installation. Please see /var/log/nvidia-installer.log for more details.
I don’t know exactly what i did wrong but defonetly somthing goes wrong.
if someone has an idea how to fix it I would be very grateful.
