Installing SDK Manager On Jetson Nano has unmet dependencies
I want to use my Jetson Nano as the Host to re-flash a Jetson AGX Orin. Is this possible?
Jetson Nano specs:
NVIDIA NVIDIA Jetson Nano Developer Kit
L4T 32.7.3 [ JetPack 4.6.3 ]
Ubuntu 18.04.6 LTS
Kernel Version: 4.9.299-tegra
CUDA 10.2.300
CUDA Architecture: 5.3
OpenCV version: 4.1.1
OpenCV Cuda: NO
CUDNN: 8.2.1.32
TensorRT: 8.2.1.9
Vision Works: 1.6.0.501
VPI: 1.2.3
Vulcan: 1.2.114
In the process of installing SDK Manger I get a few unmet dependencies:
Any ideas how to correct this issue?
steven@development-jetson:~/Downloads$ sudo apt install ./sdkmanager_1.9.2-10899_amd64.deb
[sudo] password for steven:
Reading package lists… Done
Building dependency tree
Reading state information… Done
Note, selecting ‘sdkmanager:amd64’ instead of ‘./sdkmanager_1.9.2-10899_amd64.deb’
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
sdkmanager:amd64 : Depends: libgconf-2-4:amd64 but it is not installable
Depends: libcanberra-gtk-module:amd64 but it is not installable
Depends: locales:amd64 but it is not installable
E: Unable to correct problems, you have held broken packages.
Nope, It’s impossible.
Only x86 Linux PC(not even VM) to be the host to flash Jetson devices.
@Mt.Hiker Would you mind volunteering the manufacturer/model# of the system you use? Would help me.
x86 Linux PC? Anything around you!
In my case, I use very old model HP laptop to flash Jetson.
Ubuntu 18.04 is running on it.
