Instation OS Failed
Installation failed
The installer encountered an unrecoverable error.
A desktop session will now be run
so that you may investigate the problem
or try installing again!
We having issue we need our Jetson nano work to able to train and run our AI use for our thesis but we have done everything….
gain.
You need to use sdkmanager to flash the board from another x86 Ubuntu host PC.
Using sdcard won’t really flash or install anything there.
Thanks we already procced to next step but there is another problem SD CARD cant detect in our sdkmanager in our obuntu machine pls help us!
Ok… I guess you need to read this post that I filed a while ago because the board you are using there is probably not a NV devkit.
