I have a Waveshare Jetson-IO-Base-A board with a Jetson Nano P3448-1801348. I tried installation on Ubuntu using both SDK Manager and SD card. Initially, I successfully installed using SDK Manager and Jetson Nano booted up fine. However, on subsequent attempts, I encountered the error shown in the attached photo. The Jetson screen flickers, and SDK Manager freezes at 99.5% every time. I followed Nvidia’s recommended steps for installation but got no results when installing to the SD card. When consulting AI forums, sugge
stions pointed towards a potential issue with EMMC, despite the product being only a week old and barely used. I am now attempting the installation for the second time.
Did this happen during flashing or after flashing?
Get the complete log:
There are several mistake in this post which reveals you don’t know what product you are using now
It is a Waveshare custom board which cannot be directly got flashed by sdkmanager. I didn’t mean the flash would fail or you cannot boot up. The problem is interfaces on a custom board may not work properly.
For example, that sdcard slot is added by the vendor and it will 100% not work when you flashed this board with any software provided by NVIDIA directly. -
You should go to Waveshare’s website and follow their steps so that you can enable the interfaces
This issue has nothing to do with emmc. It is just (1) as I mentioned above.
You have to understand the difference of a emmc module and sdcard module. Your case is obviously a emmc module which cannot run with sdcard image.
Jetson Nano SDMMC3 enable - #11 by WayneWWW
Untitled 1.pdf (94.0 KB)
Hello . I tried to re-install with SDK manager via Ubuntu, but it still remains at 99.50. I left the notes of Jetson while opening from the steps in the site you sent to the attachment as a document. When the system tried to open, Jetson wrote the username and asked for the password, but I could not do anything. Thank you for your interest
I am no longer interested in that project, I left the project.
kayccc via NVIDIA Developer Forums <notifications@nvidia.discoursemail.com>, 14 Ağu 2024 Çar, 06:54 tarihinde şunu yazdı:
