I am using Intel Realsense Camera D455 with Jetson Orin Nano developer kit to run the Isaac ROS Visual SLAM libraries. The camera is working perfectly on my Ubuntu PC where ROS 2 runs on it. But with jetson, it keeps on getting disconnected again and again, so it is not able to detect realsense camera. It shows for a few minutes on the realsense viewer but then disconnects. And even for Vslam, when I run the camera node, it shows me no realsense detected. What is the issue here because my all downloads are correct as per the documentation, and I also updated the firmware version for Intel real sense. How to proceed? Thank you.
