Intel Realsense camera D455 is not working with pyrealsense2 on orin dev kit
Description
Intel RealSense camera D455 is connected to Jetson AGX Orin 64 GB dev kit and is detected with Terminal command: lsusb | grep Intel
But I am getting an error with pyrealsense2 library and error: No realsense device is detected
Environment
Operating System + Version: Ubuntu 22.04.5 LTS
Python Version (if applicable): Python 3.10
Jetpack Version: 6.1
I checked intel github page: https://dev.intelrealsense.com/docs/nvidia-jetson-tx2-installation and followed debian installation block. But when I open realsense-viewer, the application is not able to detect the D455 camera module. Could someone support me with this issue ?
I have also installed pyrealsense2 library from PyPI using pip3. Even with pip3, I observed same issue that system is not able to detect realsense camera. But in all the cases, I could find camera detected message through Terminal.
Moving to Jetson Forum.
Please refer to:
Jetson AGX Orin FAQ
Q: How to run realsense camera on Orin devices?
Hey. You can close this ticket. The problem is solved. Thank you.
