Which TensorRT version do you use?
We test your model with TensorRT v8.0 from JetPack 4.6.
[02/25/2022-00:00:24] [E] Error[9]: [graphShapeAnalyzer.cpp::throwIfError::1306] Error Code 9: Internal Error (Mul_650: broadcast dimensions must be conformable
[02/25/2022-00:00:24] [E] [TRT] ModelImporter.cpp:720: While parsing node number 650 [Mul -> "1310"]:
[02/25/2022-00:00:24] [E] [TRT] ModelImporter.cpp:721: --- Begin node ---
[02/25/2022-00:00:24] [E] [TRT] ModelImporter.cpp:722: input: "1307"
input: "2405"
output: "1310"
op_type: "Mul"
[02/25/2022-00:00:24] [E] [TRT] ModelImporter.cpp:723: --- End node ---
[02/25/2022-00:00:24] [E] [TRT] ModelImporter.cpp:726: ERROR: ModelImporter.cpp:179 In function parseGraph:
[6] Invalid Node - Mul_650
The error indicates an invalid broadcast axis from the mul layer.
Would you mind double-checking if all the layers within your model are supported by the TensorRT?
