I’m trying to setup a Jetson Nano, I want to use an old version with CUDA 10.0 and cuDNN 7.x due I need to use Darknet (and Darknet is too slow with CUDA 10.2 and cuDNN 8) so I’m trying to use Jetpack 4.3 or older.
The problems is with Internet connection, it isimposible connect to Internet via Ethernet or WiFi. If I plug the Ethernet whire nothing happens. If I use a wifi dongle the Jetson detects it (with lsusb command) but it is impossible stablish a connection. If I write “ifconfig” wlan0 doesn’t appears.
Currently the Jetson Nano is running Jetpack 4.3. I tried older version and always happens the same. Also, I tried with JetPack 4.4 and Wifi works well (but I don’t want this version of CUDA and cuDNN).
FYI: I tried this wifi dongle in another Jetson Nano with L4T 32.1 and works well.
Please, help me to stablish the connection using wifi dongle.
