were those all identical Orin platforms? please check your target since you’ve assign board info in the command-line.
how about have device connected, by running this in online mode.
please see-also Topic 229129 for sample command-line to massflash Jetson devices.
thanks
OK, let me try. This interruption is accidental. Is it certain that the current version does not support mashflash as described in this topic? We still want to use it offline, thank you!
it looks like I/O errors. had you format the sd card as ext4 before running this?
are you try to use SD card image to boot-up Orin devkit development board?
Hello, the SD card is not used in the mashflash, and the USB connection is directly used in the machine flushing process. Where is the SD card used? How to use SD card?
we have tested this locally,
we’re able to perform initrd_flash on Orin DevKit with ROOTFS_AB enabled.
for example, $ sudo BOARDID=3701 FAB=500 BOARDSKU=0000 BOARDREV=J.0 ROOTFS_AB=1 ./tools/kernel_flash/l4t_initrd_flash.sh --no-flash --massflash 1 jetson-agx-orin-devkit mmcblk0p1 $ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --flash-only --massflash 1
could you please refer to above commands, update the board info accordingly to test again.
besides,
may I know what’s your host environment setups,
please also share the failure rate since you mentioned this happened sometimes,
thanks
Please look at my log file. I think the problem is caused by tar unpacking. Is it possible that the USB is unstable? If the machine fails to be rebooted, it cannot be rebooted even if the USB of the device is re plugged or the host is restarted.
Sorry, I don’t quite understand what specific settings you mean by the host environment settings. I will encounter this problem in both ubuntu18.04 and ubuntu22
thanks!
which topic? r35.1 release note it’s talking about massfuse…
please refer to our test results in comment #12. we’re able to perform initrd_flash to create massflash blobs for Orin DevKit with ROOTFS_AB enabled.
