Mass flash failure
I’m trying to use the mass flash method for flashing Ubuntu on the AGX Orin Devkit.
I’ve tried with an AGX Orin 32GB and a AGX Orin 64GB simultaneously and got ‘Maybe timeout in USB write’ for the 32GB. Could need a different USB cable so I put that aside for now, and tried from scratch (unpacking BSP, Ubuntu rootfs, create mfi package) with 1 AGX Orin 64GB Devkit only. sudo ./tools/kernel_flash/l4t_initrd_flash.sh --no-flash --network usb0 --massflash 5 jetson-agx-orin-devkit mmcblk0p1 exists fine, no problems, but when trying to flash this single AGX Orin 64GB I’m getting:
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --flash-only --network usb0 --massflash 5 --showlogs
[sudo] password for acotsach:
/home/acotsach/work/simplehttp/36_3/agx64/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash_internal.sh --network usb0 --usb-instance 1-9 --device-instance 0 --flash-only --network usb0 jetson-agx-orin-devkit mmcblk0p1
Start flashing device: 1-9, rcm instance: 0, PID: 33574
Log will be saved to Linux_for_Tegra/initrdlog/flash_1-9_0_20240911-160208.log
Flash complete (WITH FAILURES)
exportfs: duplicated export entries:
exportfs: 	127.0.0.1:/home/acotsach/work/simplehttp/36_3/agx64/Linux_for_Tegra/tools/kernel_flash/tmp
exportfs: Failed to stat /home/acotsach/work/simplehttp/36_3/agx64/Linux_for_Tegra/tools/kernel_flash/tmp: No such file or directory
and the full log is:
cat initrdlog/flash_1-9_0_20240911-160208.log
Export list for localhost:
/home/acotsach/work/simplehttp/36_3/agx64/Linux_for_Tegra/tools/kernel_flash/tmp 127.0.0.1
*  Step 1: Build the flashing environment    *
Create flash environment 0
/home/acotsach/work/simplehttp/36_3/agx64/Linux_for_Tegra/bootloader /home/acotsach/work/simplehttp/36_3/agx64/Linux_for_Tegra
Finish creating flash environment 0.
*  Step 2: Boot the device with flash initrd image *
/home/acotsach/work/simplehttp/36_3/agx64/Linux_for_Tegra/temp_initrdflash/bootloader0 /home/acotsach/work/simplehttp/36_3/agx64/Linux_for_Tegra
./tegraflash.py --bl uefi_jetson_with_dtb_sigheader.bin.encrypt --bct br_bct_BR.bct --securedev  --bldtb tegra234-p3737-0000+p3701-0005-nv.dtb --applet rcm_2_encrypt.rcm --applet_softfuse rcm_1_encrypt.rcm --cmd "rcmboot"  --cfg secureflash.xml --chip 0x23 --mb1_bct mb1_bct_MB1_sigheader.bct.encrypt --mem_bct mem_rcm_sigheader.bct.encrypt --mb1_cold_boot_bct mb1_cold_boot_bct_MB1_sigheader.bct.encrypt --mb1_bin mb1_t234_prod_aligned_sigheader.bin.encrypt --psc_bl1_bin psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --mem_bct_cold_boot mem_coldboot_sigheader.bct.encrypt  --bins "psc_fw pscfw_t234_prod_sigheader.bin.encrypt; mts_mce mce_flash_o10_cr_prod_sigheader.bin.encrypt; tsec_fw tsec_t234_sigheader.bin.encrypt; mb2_applet applet_t234_sigheader.bin.encrypt; mb2_bootloader mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt; xusb_fw xusb_t234_prod_sigheader.bin.encrypt; pva_fw nvpva_020_sigheader.fw.encrypt; dce_fw display-t234-dce_sigheader.bin.encrypt; nvdec nvdec_t234_prod_sigheader.fw.encrypt; bpmp_fw bpmp_t234-TE990M-A1_prod_sigheader.bin.encrypt; bpmp_fw_dtb tegra234-bpmp-3701-0005-3737-0000_with_odm_sigheader.dtb.encrypt; rce_fw camera-rtcpu-t234-rce_sigheader.img.encrypt; ape_fw adsp-fw_sigheader.bin.encrypt; spe_fw spe_t234_sigheader.bin.encrypt; tos tos-optee_t234_sigheader.img.encrypt; eks eks_t234_sigheader.img.encrypt; kernel boot0.img; kernel_dtb tegra234-p3737-0000+p3701-0005-nv.dtb"    --bct_backup  --instance 1-9
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
 Entering RCM boot
[   0.0450 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from --mb1_bin
[   0.0450 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from --psc_bl1_bin
[   0.0450 ] rcm boot with presigned binaries
[   0.0455 ] tegrarcm_v2 --instance 1-9 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[   0.0459 ] BR_CID: 0x80012344705DD31F7C0000000AFE81C0
[   0.0545 ] Sending bct_br
[   0.0628 ] Sending mb1
[   0.0633 ] Sending psc_bl1
[   0.0746 ] Sending bct_mb1
[   0.0811 ] Generating blob for T23x
[   0.0827 ] tegrahost_v2 --chip 0x23 0 --generateblob blob.xml blob.bin
[   0.0830 ] The number of images in blob is 19
[   0.0834 ] blobsize is 96569966
[   0.0836 ] Added binary blob_uefi_jetson_with_dtb_sigheader.bin.encrypt of size 3657792
[   0.1344 ] Added binary blob_pscfw_t234_prod_sigheader.bin.encrypt of size 310768
[   0.1354 ] Added binary blob_mce_flash_o10_cr_prod_sigheader.bin.encrypt of size 187120
[   0.1365 ] Added binary blob_tsec_t234_sigheader.bin.encrypt of size 176128
[   0.1378 ] Added binary blob_applet_t234_sigheader.bin.encrypt of size 279616
[   0.1391 ] Not supported type: mb2_applet
[   0.1399 ] Added binary blob_mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt of size 439968
[   0.1411 ] Added binary blob_xusb_t234_prod_sigheader.bin.encrypt of size 164864
[   0.1418 ] Added binary blob_nvpva_020_sigheader.fw.encrypt of size 2164640
[   0.1424 ] Added binary blob_display-t234-dce_sigheader.bin.encrypt of size 12070528
[   0.1515 ] Added binary blob_nvdec_t234_prod_sigheader.fw.encrypt of size 294912
[   0.1542 ] Added binary blob_bpmp_t234-TE990M-A1_prod_sigheader.bin.encrypt of size 1027008
[   0.1551 ] Added binary blob_tegra234-bpmp-3701-0005-3737-0000_with_odm_sigheader.dtb.encrypt of size 264960
[   0.1558 ] Added binary blob_camera-rtcpu-t234-rce_sigheader.img.encrypt of size 458096
[   0.1564 ] Added binary blob_adsp-fw_sigheader.bin.encrypt of size 414976
[   0.1569 ] Added binary blob_spe_t234_sigheader.bin.encrypt of size 270336
[   0.1574 ] Added binary blob_tos-optee_t234_sigheader.img.encrypt of size 1633344
[   0.1579 ] Added binary blob_eks_t234_sigheader.img.encrypt of size 9232
[   0.1584 ] Added binary blob_boot0.img of size 72495104
[   0.2184 ] Added binary blob_tegra234-p3737-0000+p3701-0005-nv.dtb of size 249470
[   0.3643 ] tegrarcm_v2 --instance 1-9 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
[   0.3653 ] BL: version 1.4.0.2-t234-54845784-08a4de08 last_boot_error: 0
[   0.3744 ] Sending bct_mem
[   0.3892 ] Sending blob
[   4.0982 ] RCM-boot started
*  Step 3: Start the flashing process *
Cleaning up...
I’ve followed the steps exactly as in Flashing Support — NVIDIA Jetson Linux Developer Guide 1 documentation . Any idea how I can get past this error?
Also, is it possible to use initrd massflash for a 32GB AGX and 64GB mix or do they have to be 32GB or 64GB only? I’m using the online method when creating the mfi package.
Hi AlexCo,
For Jetpack 6.0GA (R36.3.0), please use internal instead of mmcblk0p1 here.
Please use another terminal to run the commands.
You have to check the board spec to confirm if they are in the same compatible spec. As my understanding, they have different SKU so that you have create their own mfi package.
Thanks @KevinFFF , I’ve switched terminals, restarted the computer, also started with a new flashing setup from BSP archive to rootfs unpacking and issuing apply_binaries.sh. I’m still getting the error with duplicated export entries and the board won’t flash.
Interestingly, the failure is always reporting 127.0.0.1:/home/acotsach/work/simplehttp/36_3/agx64/Linux_for_Tegra/tools/kernel_flash/tmp even if I’m using a totally new and different path from where I trigger flashing. This path must have been saved somewhere on my PC and is being re-used since when I created the mfi package perhaps? I can’t find it anywhere in my env though
Is there any error when you were generating the mfi package?
Have you also tried to run them on another Ubuntu host PC?
