The installation failed on trying to install on a 910m. Yes it is an oldie… but I thought it might be supported since it is apparently is in the kepler architecture (as below).
https://nvidia.custhelp.com/app/answers/detail/a_id/4780/~/list-of-kepler-series-geforce-notebook-gpus
And the installation docs mentions:
“Note: CUDA on WSL 2 is enabled on GPUs starting with the Kepler architecture; however, we recommend running CUDA on WSL 2 on Turing or newer architectures.”
Thanks in advance for the reply
Check out: Support Plan for Kepler-series GeForce GPUs for notebooks
However:
“Binary compatibility within one GPU generation can be guaranteed under certain conditions because they share the basic instruction set. This is the case between two GPU versions that do not show functional differences at all (for instance when one version is a scaled down version of the other)”
Source: CUDA Compiler Driver NVCC Reference Guide
