Is there a supported fuel gauge and power monitor for TX1 plus battery?
In your application note: “NVIDIA JETSON TX1 MODULE BATTERY AND CHARGER DESIGN GUIDELINES” you show a dedicated i2c bus used to connect a slave battery gauge and slave power monitor to the TX1. So since the TX1 is the master what parts are supported here? Are there parts that have software support so we can get this battery data all the way back in the linux os?
Jetson TX1 leaves connector J27 on carrier board as the charger interface, I2C_PM is used to communicate with fuel gauge and power monitor which customer chose. Customer need to program by self to get the battery data base on battery/gauge/monitor vendor’s guide.
