I’m developing a carrier board for JTX1 which should be equipped with a LiPo battery and internal charger.
I’ve tried to fine any info in TRM, OEM_Product_DesignGuide, but failed.
Schematic contains some pins, but there is no descriptions, scenarios, states for them. No any relations with Ubuntu…
Please let me know where I can find a description and guideline for making a charge controller compatible with JTX1?
What minimal required signals such controller should have?
What are working scenarios?
JTX1 doesn’t include charging function. So to implement charging on JTX1, a board with charging management IC on is needed, and it can use header J27 for charger control.
NV does not have reference platform nor software implementation in L4T BSP. You are free to select proper components and implement your software.
Here are some pins’ description:
CHARGER_PRSNT# - Active low indication that the AC power is present on the charger IC
CHARGING# - Interrupt from the charger IC to the module, if charger has output interrupt pin.
BATLOW# - Active Low Interrupt from the fuel gauge to indicate that the battery voltage is low.
BATTERY_OC# - Interrupt form power monitor to the module, If battery has output over-current event.
SMBus is based on I2C PHY, it might work to use I2C as SMBus, but not verified.
I have no much experience of SMBus, but do know it is almost same with I2C on PHY, and as you can see in the doc you post, no need to add level shifter because the pull-up voltage could be set to same. I2C is more popular on mobile/embedded related platform, SMBus is rarely used in those fields as far as i know.
In general you are right, but SMBus uses different signal limits and thresholds. It means, it can work with I2C in some particular cases but not in general.
The smart battery standard uses SMBus. TI (most popular) charger controller too. Intersil controller - I2C…
Ok. We will develop it anyway. Every time we hope to save time using your advice, but…
