Is there a way to disable ubuntu GUI? I almost do not use its GUI, I was wondering if there is a way to disable it (not uninstall, in case I will need it for future) . i.e., pretty much like respberry’s respbian, just use startx to start up guo when I do need it.
I haven’t tried this on a TX2 yet, but see if this works:
sudo systemctl disable lightdm.service
sudo systemctl stop lightdm.service
sudo chmod -x /usr/sbin/lightdm
hitech
March 25, 2017, 11:06pm
#3
If you want to just stop the GUI for just one session then you can do something like this.
Click
Ctrl + Alt + F1
at
Login
and after you login,
sudo service lightdm stop
does work on TX2, memory usage reduced to 400MB after stopping it. Thanks!
Ctrl + Alt + F1
Also works but seems that it doesnot release resource (xorg is still running on backend)
sperok
April 1, 2017, 4:33pm
#5
If you never want the GUI then sudo systemctl set-default multi-user.target will result in booting to the command prompt instead of the desktop.
The systemd way to stop “lightdm.service” from starting on boot on Ubuntu 16.04 on the TX2 is
$ sudo systemctl stop lightdm.service
$ sudo systemctl mask lightdm.service
Re-enable it to start at boot with
$ sudo systemctl unmask lightdm.service
Changing the systemd “target” won’t affect it (as suggested by @sperok ), nor will “systemctl disable” (as suggested by @linuxdev )
400MB? Not good enough! ;-) Here’s the output from TX2 with no GUI and some custom daemons running in the background (main app is down):
root@tx2:/usr/src/read_temp# free
total used free shared buff/cache available
Mem: 8043188 137816 7670824 12896 234548 7824588
Swap: 0 0 0
-albertr
Has anyone succeeded to boot the TX2 into command line ?
aes368
September 23, 2018, 3:10am
#9
I was able to stop it from running on boot by running
and commenting out the line that reads
service lightdm restart
in
/etc/systemd/nvfb.sh
