I can’t display the DP screen after compiling and burning according to the file,
The LOG file is as follows
ORIN_BOOT.log (362.4 KB)
ORIN_FLASH.log (66.8 KB)
Is there any EMMC IMAGE burning file from Orin factory??
I want to burn back the factory version and compare it with my own compiled version
Each Jetson module ships with no software pre-installed; you attach it to a carrier board designed or procured for your end product, and flash it with the software image you’ve developed.
No factory image?
My compiled version cannot display the DP screen, can you help to find the reason?
Burning is successful but “system configuration” cannot be set because DP is not displayed
But the factory version can display the DP screen normally
[ 16.404263] Please complete system configuration setup on the serial port provided by Jetson’s USB device mode connection. e.g. /dev/ttyACMx where x can 0, 1, 2 etc.
You can try to flash with the JetPack 5.0 DP SW.
See JetPack SDK | NVIDIA Developer
The factory image is the sdkmanager. Follow @kayccc 's instructions first.
Also, my suggestion is do not trust anything pre-installed on your jetson devices. Always flash sdkmanager in the first time you use it.
This screen stopped for more than an hour… how to fix it
Configure the automatic setup to manual.
After the burning is successful, the DP screen can be displayed
Compare the KERNEL LOG to find the biggest differences
I have this error in the version I compiled
nvgpu: Unknown symbol nvlink_shutdown (err -2)
nvgpu: Unknown symbol nvlink_register_link (err -2)
nvgpu: Unknown symbol nvlink_unregister_device (err -2)
nvgpu: Unknown symbol nvlink_unregister_link (err -2)
systemd[1]: Started Journal Service.
nvgpu: Unknown symbol nvlink_enumerate (err -2)
nvgpu: Unknown symbol nvlink_transition_intranode_conn_off_to_safe (err -2)
nvgpu: Unknown symbol nvlink_register_device (err -2)
nvgpu: Unknown symbol nvlink_train_intranode_conn_safe_to_hs (err -2)
systemd-journald[305]: Received client request to flush runtime journal.
using random self ethernet address
using random host ethernet address
nvidia: loading out-of-tree module taints kernel.
What does “the version I compiled” mean? You build the kernel?
YES
I download public_sources.tbz2…
rebuild kernel
But this version DP cannot be displayed and there will be nvgpu: Unknown symbol nvlink_shutdown (err -2) error
Did you also rebuild the kernel modules but not only the image?
Replace nvgpu.ko and it can be displayed normally
system
Closed
June 1, 2022, 3:16am
15
