Isaac Compute Odometry Node Improperly calculating odometry
I’m currently trying to control a custom robot using the nav2 stack.
The robot is a simple two-wheeled differential drive robot which has a closable jaw in the center. I have also added a rotation lidar to it.
I am controlling the robot using the action graph shown below
I have published all the necessary transforms to navigate with lidar. The transform tree for the robot is shown below.
frames_2023-03-28_16.40.14.pdf (24.4 KB)
My problem is the following. Whenever I attempt to send a navigation goal for the robot to move towards, the Isaac Compute Odometry Node begins to randomly change the position values it outputs, causing the odom frame to jump around the map randomly. This causes all child frames to jump around as well, making it so the robot cannot navigate to the goal.
After digging in a bit further, I realized this error would appear at the moment the odom frame jumped to a new position.: Extrapolation Error looking up target frame: Lookup would require extrapolation into the future. Requested time 1680033860.806143 but the latest data is at time 4407.011896, when looking up transform from frame [odom] to frame [map]
I’m unsure why this is happening as I’m using the same Read Simulation Time Graph node for all published transforms.
Why is the odometry graph node jumping all over the place? Any help is appreciated.
Hi @juan17 - Someone from our team will review and answer your question.
Thank you! If more information is needed to understand the problem, please let me know. I’m more than happy to give it.
I want to check something first: can you print out the output of the simulation time node, is it advancing as you would expect?
(and by printing out, I mean there should be a “to string” node and “print text” node, string those together and check what comes out of the console tab on the bottom. you may need to adjust the log level in the print text node to make it easier to read)
Of course
Here is a snippet of the output from the Read Simulation Time node:
2023-03-30 18:02:37 [16,149,276ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3294.73
2023-03-30 18:02:37 [16,149,311ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3294.77
2023-03-30 18:02:37 [16,149,347ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3294.8
2023-03-30 18:02:37 [16,149,384ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3294.83
2023-03-30 18:02:37 [16,149,421ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3294.87
2023-03-30 18:02:37 [16,149,458ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3294.9
2023-03-30 18:02:37 [16,149,494ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3294.93
2023-03-30 18:02:37 [16,149,530ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3294.97
2023-03-30 18:02:37 [16,149,567ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3295
2023-03-30 18:02:37 [16,149,605ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3295.03
2023-03-30 18:02:37 [16,149,642ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3295.07
2023-03-30 18:02:37 [16,149,678ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3295.1
2023-03-30 18:02:37 [16,149,714ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3295.13
2023-03-30 18:02:37 [16,149,751ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3295.17
2023-03-30 18:02:37 [16,149,787ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3295.2
2023-03-30 18:02:37 [16,149,824ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3295.23
2023-03-30 18:02:37 [16,149,860ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3295.27
2023-03-30 18:02:37 [16,149,897ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3295.3
2023-03-30 18:02:37 [16,149,935ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3295.33
2023-03-30 18:02:37 [16,149,971ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3295.37
2023-03-30 18:02:38 [16,150,009ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3295.4
2023-03-30 18:02:38 [16,150,044ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3295.43
2023-03-30 18:02:38 [16,150,080ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3295.47
2023-03-30 18:02:38 [16,150,118ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3295.5
2023-03-30 18:02:38 [16,150,154ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3295.53
2023-03-30 18:02:38 [16,150,191ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3295.57
2023-03-30 18:02:38 [16,150,227ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3295.6
2023-03-30 18:02:38 [16,150,263ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3295.63
2023-03-30 18:02:38 [16,150,300ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3295.67
2023-03-30 18:02:38 [16,150,337ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3295.7
2023-03-30 18:02:38 [16,150,374ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3295.73
2023-03-30 18:02:38 [16,150,410ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3295.77
2023-03-30 18:02:38 [16,150,446ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3295.8
2023-03-30 18:02:38 [16,150,483ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3295.83
2023-03-30 18:02:38 [16,150,520ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3295.87
2023-03-30 18:02:38 [16,150,558ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3295.9
2023-03-30 18:02:38 [16,150,593ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3295.93
2023-03-30 18:02:38 [16,150,630ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3295.97
2023-03-30 18:02:38 [16,150,667ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3296
2023-03-30 18:02:38 [16,150,704ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3296.03
2023-03-30 18:02:38 [16,150,741ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3296.07
2023-03-30 18:02:38 [16,150,777ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3296.1
2023-03-30 18:02:38 [16,150,813ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3296.13
2023-03-30 18:02:38 [16,150,850ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3296.17
2023-03-30 18:02:38 [16,150,887ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3296.2
2023-03-30 18:02:38 [16,150,924ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3296.23
2023-03-30 18:02:38 [16,150,959ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3296.27
2023-03-30 18:02:39 [16,150,996ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3296.3
2023-03-30 18:02:39 [16,151,033ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3296.33
2023-03-30 18:02:39 [16,151,070ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3296.37
2023-03-30 18:02:39 [16,151,107ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3296.4
2023-03-30 18:02:39 [16,151,143ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3296.43
2023-03-30 18:02:39 [16,151,179ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3296.47
2023-03-30 18:02:39 [16,151,217ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3296.5
2023-03-30 18:02:39 [16,151,253ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3296.53
2023-03-30 18:02:39 [16,151,290ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3296.57
2023-03-30 18:02:39 [16,151,326ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3296.6
2023-03-30 18:02:39 [16,151,362ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3296.63
2023-03-30 18:02:39 [16,151,399ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3296.67
2023-03-30 18:02:39 [16,151,436ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3296.7
2023-03-30 18:02:39 [16,151,473ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3296.73
2023-03-30 18:02:39 [16,151,509ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3296.77
2023-03-30 18:02:39 [16,151,545ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3296.8
2023-03-30 18:02:39 [16,151,582ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3296.83
2023-03-30 18:02:39 [16,151,619ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3296.87
2023-03-30 18:02:39 [16,151,656ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3296.9
2023-03-30 18:02:39 [16,151,693ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3296.93
2023-03-30 18:02:39 [16,151,729ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3296.97
2023-03-30 18:02:39 [16,151,767ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3297
2023-03-30 18:02:39 [16,151,803ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3297.03
2023-03-30 18:02:39 [16,151,840ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3297.07
2023-03-30 18:02:39 [16,151,876ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3297.1
2023-03-30 18:02:39 [16,151,912ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3297.13
2023-03-30 18:02:39 [16,151,949ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3297.17
2023-03-30 18:02:40 [16,151,986ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3297.2
2023-03-30 18:02:40 [16,152,023ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3297.23
2023-03-30 18:02:40 [16,152,058ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3297.27
2023-03-30 18:02:40 [16,152,096ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3297.3
2023-03-30 18:02:40 [16,152,133ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3297.33
2023-03-30 18:02:40 [16,152,169ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3297.37
2023-03-30 18:02:40 [16,152,207ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3297.4
2023-03-30 18:02:40 [16,152,243ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3297.43
2023-03-30 18:02:40 [16,152,279ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3297.47
2023-03-30 18:02:40 [16,152,317ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3297.5
2023-03-30 18:02:40 [16,152,353ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3297.53
2023-03-30 18:02:40 [16,152,390ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3297.57
2023-03-30 18:02:40 [16,152,426ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3297.6
2023-03-30 18:02:40 [16,152,462ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3297.63
2023-03-30 18:02:40 [16,152,499ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3297.67
2023-03-30 18:02:40 [16,152,537ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3297.7
2023-03-30 18:02:40 [16,152,574ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3297.73
2023-03-30 18:02:40 [16,152,609ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3297.77
2023-03-30 18:02:40 [16,152,645ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3297.8
2023-03-30 18:02:40 [16,152,682ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3297.83
2023-03-30 18:02:40 [16,152,719ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3297.87
2023-03-30 18:02:40 [16,152,756ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3297.9
2023-03-30 18:02:40 [16,152,792ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3297.93
2023-03-30 18:02:40 [16,152,829ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3297.97
2023-03-30 18:02:40 [16,152,866ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3298
2023-03-30 18:02:40 [16,152,903ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3298.03
2023-03-30 18:02:40 [16,152,939ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3298.07
2023-03-30 18:02:40 [16,152,976ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3298.1
2023-03-30 18:02:41 [16,153,012ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3298.13
2023-03-30 18:02:41 [16,153,049ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3298.17
2023-03-30 18:02:41 [16,153,086ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3298.2
2023-03-30 18:02:41 [16,153,123ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3298.23
2023-03-30 18:02:41 [16,153,158ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3298.27
2023-03-30 18:02:41 [16,153,195ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3298.3
2023-03-30 18:02:41 [16,153,232ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3298.33
2023-03-30 18:02:41 [16,153,269ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3298.37
2023-03-30 18:02:41 [16,153,306ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3298.4
2023-03-30 18:02:41 [16,153,342ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3298.43
2023-03-30 18:02:41 [16,153,379ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3298.47
2023-03-30 18:02:41 [16,153,417ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3298.5
2023-03-30 18:02:41 [16,153,454ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3298.53
2023-03-30 18:02:41 [16,153,490ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3298.57
2023-03-30 18:02:41 [16,153,527ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3298.6
2023-03-30 18:02:41 [16,153,564ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3298.63
2023-03-30 18:02:41 [16,153,601ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3298.67
2023-03-30 18:02:41 [16,153,638ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3298.7
2023-03-30 18:02:41 [16,153,674ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3298.73
2023-03-30 18:02:41 [16,153,709ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3298.77
2023-03-30 18:02:41 [16,153,746ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3298.8
2023-03-30 18:02:41 [16,153,783ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3298.83
2023-03-30 18:02:41 [16,153,820ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3298.87
2023-03-30 18:02:41 [16,153,855ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3298.9
2023-03-30 18:02:41 [16,153,892ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3298.93
2023-03-30 18:02:41 [16,153,928ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3298.97
2023-03-30 18:02:41 [16,153,966ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3299
2023-03-30 18:02:42 [16,154,002ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3299.03
2023-03-30 18:02:42 [16,154,037ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3299.07
2023-03-30 18:02:42 [16,154,073ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3299.1
2023-03-30 18:02:42 [16,154,110ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3299.13
2023-03-30 18:02:42 [16,154,147ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3299.17
2023-03-30 18:02:42 [16,154,184ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3299.2
2023-03-30 18:02:42 [16,154,220ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3299.23
2023-03-30 18:02:42 [16,154,257ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3299.27
2023-03-30 18:02:42 [16,154,295ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3299.3
2023-03-30 18:02:42 [16,154,332ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3299.33
2023-03-30 18:02:42 [16,154,368ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3299.37
2023-03-30 18:02:42 [16,154,404ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3299.4
2023-03-30 18:02:42 [16,154,442ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3299.43
2023-03-30 18:02:42 [16,154,478ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3299.47
2023-03-30 18:02:42 [16,154,517ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3299.5
2023-03-30 18:02:42 [16,154,553ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3299.53
2023-03-30 18:02:42 [16,154,591ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3299.57
2023-03-30 18:02:42 [16,154,628ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3299.6
2023-03-30 18:02:42 [16,154,665ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3299.63
2023-03-30 18:02:42 [16,154,701ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3299.67
2023-03-30 18:02:42 [16,154,737ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3299.7
2023-03-30 18:02:42 [16,154,773ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3299.73
2023-03-30 18:02:42 [16,154,810ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3299.77
2023-03-30 18:02:42 [16,154,846ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3299.8
2023-03-30 18:02:42 [16,154,883ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3299.83
2023-03-30 18:02:42 [16,154,918ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3299.87
2023-03-30 18:02:42 [16,154,956ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3299.9
2023-03-30 18:02:43 [16,154,992ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3299.93
2023-03-30 18:02:43 [16,155,029ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3299.97
2023-03-30 18:02:43 [16,155,066ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3300
2023-03-30 18:02:43 [16,155,102ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3300.03
2023-03-30 18:02:43 [16,155,139ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3300.07
2023-03-30 18:02:43 [16,155,177ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3300.1
2023-03-30 18:02:43 [16,155,214ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3300.13
2023-03-30 18:02:43 [16,155,251ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3300.17
2023-03-30 18:02:43 [16,155,289ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3300.2
2023-03-30 18:02:43 [16,155,326ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3300.23
2023-03-30 18:02:43 [16,155,363ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3300.27
2023-03-30 18:02:43 [16,155,401ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3300.3
2023-03-30 18:02:43 [16,155,437ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3300.33
2023-03-30 18:02:43 [16,155,474ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3300.37
2023-03-30 18:02:43 [16,155,512ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3300.4
2023-03-30 18:02:43 [16,155,548ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3300.43
2023-03-30 18:02:43 [16,155,584ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3300.47
2023-03-30 18:02:43 [16,155,622ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3300.5
2023-03-30 18:02:43 [16,155,659ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3300.53
2023-03-30 18:02:43 [16,155,695ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3300.57
2023-03-30 18:02:43 [16,155,732ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3300.6
2023-03-30 18:02:43 [16,155,770ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3300.63
2023-03-30 18:02:43 [16,155,806ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3300.67
2023-03-30 18:02:43 [16,155,844ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3300.7
2023-03-30 18:02:43 [16,155,879ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3300.73
2023-03-30 18:02:43 [16,155,915ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3300.77
2023-03-30 18:02:43 [16,155,954ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3300.8
2023-03-30 18:02:44 [16,155,991ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3300.83
2023-03-30 18:02:44 [16,156,028ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3300.87
2023-03-30 18:02:44 [16,156,064ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3300.9
2023-03-30 18:02:44 [16,156,101ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3300.93
2023-03-30 18:02:44 [16,156,138ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3300.97
2023-03-30 18:02:44 [16,156,176ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3301
2023-03-30 18:02:44 [16,156,212ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3301.03
2023-03-30 18:02:44 [16,156,249ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3301.07
2023-03-30 18:02:44 [16,156,287ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3301.1
2023-03-30 18:02:44 [16,156,324ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3301.13
2023-03-30 18:02:44 [16,156,360ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3301.17
2023-03-30 18:03:10 [16,182,054ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3301.17
2023-03-30 18:03:10 [16,182,095ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3301.2
2023-03-30 18:03:10 [16,182,140ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3301.23
2023-03-30 18:03:10 [16,182,178ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3301.27
2023-03-30 18:03:10 [16,182,218ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3301.3
2023-03-30 18:03:10 [16,182,259ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3301.33
2023-03-30 18:03:10 [16,182,299ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3301.37
2023-03-30 18:03:10 [16,182,341ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3301.4
2023-03-30 18:03:10 [16,182,382ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3301.43
2023-03-30 18:03:10 [16,182,422ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3301.47
2023-03-30 18:03:10 [16,182,464ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3301.5
2023-03-30 18:03:10 [16,182,506ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3301.53
2023-03-30 18:03:10 [16,182,546ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3301.57
2023-03-30 18:03:10 [16,182,585ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3301.6
2023-03-30 18:03:10 [16,182,623ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3301.63
2023-03-30 18:03:10 [16,182,660ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3301.67
2023-03-30 18:03:10 [16,182,696ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3301.7
2023-03-30 18:03:10 [16,182,734ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3301.73
2023-03-30 18:03:10 [16,182,771ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3301.77
2023-03-30 18:03:10 [16,182,808ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3301.8
2023-03-30 18:03:10 [16,182,845ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3301.83
2023-03-30 18:03:10 [16,182,881ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3301.87
2023-03-30 18:03:10 [16,182,918ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3301.9
2023-03-30 18:03:10 [16,182,955ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3301.93
2023-03-30 18:03:11 [16,182,991ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3301.97
2023-03-30 18:03:11 [16,183,028ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3302
2023-03-30 18:03:11 [16,183,063ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3302.03
2023-03-30 18:03:11 [16,183,101ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3302.07
2023-03-30 18:03:11 [16,183,138ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3302.1
2023-03-30 18:03:11 [16,183,176ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3302.13
2023-03-30 18:03:11 [16,183,212ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3302.17
2023-03-30 18:03:11 [16,183,248ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3302.2
2023-03-30 18:03:11 [16,183,285ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3302.23
2023-03-30 18:03:11 [16,183,322ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3302.27
2023-03-30 18:03:11 [16,183,359ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3302.3
2023-03-30 18:03:11 [16,183,395ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3302.33
2023-03-30 18:03:11 [16,183,430ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3302.37
2023-03-30 18:03:11 [16,183,467ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3302.4
2023-03-30 18:03:11 [16,183,504ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3302.43
2023-03-30 18:03:11 [16,183,541ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3302.47
2023-03-30 18:03:11 [16,183,577ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3302.5
2023-03-30 18:03:11 [16,183,612ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3302.53
2023-03-30 18:03:11 [16,183,649ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3302.57
2023-03-30 18:03:11 [16,183,686ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3302.6
2023-03-30 18:03:11 [16,183,722ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3302.63
2023-03-30 18:03:11 [16,183,759ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3302.67
2023-03-30 18:03:11 [16,183,798ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3302.7
2023-03-30 18:03:11 [16,183,838ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3302.73
2023-03-30 18:03:11 [16,183,879ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3302.77
2023-03-30 18:03:11 [16,183,920ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3302.8
2023-03-30 18:03:11 [16,183,970ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3302.83
2023-03-30 18:03:12 [16,184,025ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3302.87
2023-03-30 18:03:12 [16,184,074ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3302.9
2023-03-30 18:03:12 [16,184,123ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3302.93
2023-03-30 18:03:12 [16,184,169ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3302.97
2023-03-30 18:03:12 [16,184,210ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3303
2023-03-30 18:03:12 [16,184,250ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3303.03
2023-03-30 18:03:12 [16,184,290ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3303.07
2023-03-30 18:03:12 [16,184,333ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3303.1
2023-03-30 18:03:12 [16,184,374ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3303.13
2023-03-30 18:03:12 [16,184,413ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3303.17
2023-03-30 18:03:12 [16,184,456ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3303.2
2023-03-30 18:03:12 [16,184,497ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3303.23
2023-03-30 18:03:12 [16,184,538ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3303.27
2023-03-30 18:03:12 [16,184,576ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3303.3
2023-03-30 18:03:12 [16,184,615ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3303.33
2023-03-30 18:03:12 [16,184,655ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3303.37
2023-03-30 18:03:12 [16,184,703ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3303.4
2023-03-30 18:03:12 [16,184,756ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3303.43
2023-03-30 18:03:12 [16,184,806ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3303.47
2023-03-30 18:03:12 [16,184,844ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3303.5
2023-03-30 18:03:12 [16,184,884ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3303.53
2023-03-30 18:03:12 [16,184,924ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3303.57
2023-03-30 18:03:12 [16,184,965ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3303.6
2023-03-30 18:03:13 [16,185,001ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3303.63
2023-03-30 18:03:13 [16,185,042ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3303.67
2023-03-30 18:03:13 [16,185,083ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3303.7
2023-03-30 18:03:13 [16,185,122ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3303.73
2023-03-30 18:03:13 [16,185,161ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3303.77
2023-03-30 18:03:13 [16,185,202ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3303.8
2023-03-30 18:03:13 [16,185,241ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3303.83
2023-03-30 18:03:13 [16,185,281ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3303.87
2023-03-30 18:03:13 [16,185,324ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3303.9
2023-03-30 18:03:13 [16,185,362ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3303.93
2023-03-30 18:03:13 [16,185,402ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3303.97
2023-03-30 18:03:13 [16,185,443ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3304
2023-03-30 18:03:13 [16,185,482ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3304.03
2023-03-30 18:03:13 [16,185,521ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3304.07
2023-03-30 18:03:13 [16,185,564ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3304.1
2023-03-30 18:03:13 [16,185,602ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3304.13
2023-03-30 18:03:13 [16,185,642ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3304.17
2023-03-30 18:03:13 [16,185,684ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3304.2
2023-03-30 18:03:13 [16,185,723ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3304.23
2023-03-30 18:03:13 [16,185,762ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3304.27
2023-03-30 18:03:13 [16,185,803ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3304.3
2023-03-30 18:03:13 [16,185,843ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3304.33
2023-03-30 18:03:13 [16,185,883ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3304.37
2023-03-30 18:03:13 [16,185,924ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3304.4
2023-03-30 18:03:13 [16,185,964ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3304.43
2023-03-30 18:03:14 [16,186,004ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3304.47
2023-03-30 18:03:14 [16,186,046ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3304.5
2023-03-30 18:03:14 [16,186,086ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3304.53
2023-03-30 18:03:14 [16,186,127ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3304.57
2023-03-30 18:03:14 [16,186,168ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3304.6
2023-03-30 18:03:14 [16,186,207ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3304.63
2023-03-30 18:03:14 [16,186,248ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3304.67
2023-03-30 18:03:14 [16,186,289ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3304.7
2023-03-30 18:03:14 [16,186,328ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3304.73
2023-03-30 18:03:14 [16,186,367ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3304.77
2023-03-30 18:03:14 [16,186,409ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3304.8
2023-03-30 18:03:14 [16,186,448ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3304.83
2023-03-30 18:03:14 [16,186,488ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3304.87
2023-03-30 18:03:14 [16,186,529ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3304.9
2023-03-30 18:03:14 [16,186,569ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3304.93
2023-03-30 18:03:14 [16,186,609ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3304.97
2023-03-30 18:03:14 [16,186,650ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3305
2023-03-30 18:03:14 [16,186,690ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3305.03
2023-03-30 18:03:14 [16,186,727ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3305.07
2023-03-30 18:03:14 [16,186,768ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3305.1
2023-03-30 18:03:14 [16,186,809ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3305.13
2023-03-30 18:03:14 [16,186,848ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3305.17
2023-03-30 18:03:14 [16,186,888ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3305.2
2023-03-30 18:03:14 [16,186,929ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3305.23
2023-03-30 18:03:14 [16,186,969ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3305.27
2023-03-30 18:03:15 [16,187,009ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3305.3
2023-03-30 18:03:15 [16,187,049ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3305.33
2023-03-30 18:03:15 [16,187,089ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3305.37
2023-03-30 18:03:15 [16,187,130ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3305.4
2023-03-30 18:03:15 [16,187,171ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3305.43
2023-03-30 18:03:15 [16,187,209ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3305.47
2023-03-30 18:03:15 [16,187,249ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3305.5
2023-03-30 18:03:15 [16,187,289ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3305.53
2023-03-30 18:03:15 [16,187,329ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3305.57
2023-03-30 18:03:15 [16,187,370ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3305.6
2023-03-30 18:03:15 [16,187,411ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3305.63
2023-03-30 18:03:15 [16,187,450ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3305.67
2023-03-30 18:03:15 [16,187,490ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3305.7
2023-03-30 18:03:15 [16,187,532ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3305.73
2023-03-30 18:03:15 [16,187,571ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3305.77
2023-03-30 18:03:15 [16,187,611ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3305.8
2023-03-30 18:03:15 [16,187,652ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3305.83
2023-03-30 18:03:15 [16,187,693ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3305.87
2023-03-30 18:03:15 [16,187,732ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3305.9
2023-03-30 18:03:15 [16,187,773ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3305.93
2023-03-30 18:03:15 [16,187,814ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3305.97
2023-03-30 18:03:15 [16,187,853ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3306
2023-03-30 18:03:15 [16,187,892ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3306.03
2023-03-30 18:03:15 [16,187,933ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3306.07
2023-03-30 18:03:15 [16,187,973ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3306.1
2023-03-30 18:03:16 [16,188,011ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3306.13
2023-03-30 18:03:16 [16,188,053ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3306.17
2023-03-30 18:03:16 [16,188,094ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3306.2
2023-03-30 18:03:16 [16,188,131ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3306.23
2023-03-30 18:03:16 [16,188,172ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3306.27
2023-03-30 18:03:16 [16,188,214ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3306.3
2023-03-30 18:03:16 [16,188,252ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3306.33
2023-03-30 18:03:16 [16,188,292ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3306.37
2023-03-30 18:03:16 [16,188,333ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3306.4
2023-03-30 18:03:16 [16,188,372ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3306.43
2023-03-30 18:03:16 [16,188,414ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3306.47
2023-03-30 18:03:16 [16,188,455ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3306.5
2023-03-30 18:03:16 [16,188,494ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3306.53
2023-03-30 18:03:16 [16,188,535ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3306.57
2023-03-30 18:03:16 [16,188,578ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3306.6
2023-03-30 18:03:16 [16,188,615ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3306.63
2023-03-30 18:03:16 [16,188,656ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3306.67
2023-03-30 18:03:16 [16,188,697ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3306.7
2023-03-30 18:03:16 [16,188,734ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3306.73
2023-03-30 18:03:16 [16,188,775ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3306.77
2023-03-30 18:03:16 [16,188,816ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3306.8
2023-03-30 18:03:16 [16,188,856ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3306.83
2023-03-30 18:03:16 [16,188,897ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3306.87
2023-03-30 18:03:16 [16,188,939ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3306.9
2023-03-30 18:03:16 [16,188,976ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3306.93
2023-03-30 18:03:17 [16,189,016ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3306.97
2023-03-30 18:03:17 [16,189,058ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3307
2023-03-30 18:03:17 [16,189,097ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3307.03
2023-03-30 18:03:17 [16,189,138ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3307.07
2023-03-30 18:03:17 [16,189,180ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3307.1
2023-03-30 18:03:17 [16,189,219ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3307.13
2023-03-30 18:03:17 [16,189,259ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3307.17
2023-03-30 18:03:17 [16,189,301ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3307.2
2023-03-30 18:03:17 [16,189,340ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3307.23
2023-03-30 18:03:17 [16,189,381ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3307.27
2023-03-30 18:03:17 [16,189,422ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3307.3
2023-03-30 18:03:17 [16,189,461ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3307.33
2023-03-30 18:03:17 [16,189,502ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3307.37
2023-03-30 18:03:17 [16,189,544ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3307.4
2023-03-30 18:03:17 [16,189,581ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3307.43
2023-03-30 18:03:17 [16,189,622ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3307.47
2023-03-30 18:03:17 [16,189,665ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3307.5
2023-03-30 18:03:17 [16,189,702ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3307.53
2023-03-30 18:03:17 [16,189,743ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3307.57
2023-03-30 18:03:17 [16,189,785ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3307.6
2023-03-30 18:03:17 [16,189,823ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3307.63
2023-03-30 18:03:17 [16,189,864ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3307.67
2023-03-30 18:03:17 [16,189,905ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3307.7
2023-03-30 18:03:17 [16,189,943ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3307.73
2023-03-30 18:03:18 [16,189,983ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3307.77
2023-03-30 18:03:18 [16,190,025ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3307.8
2023-03-30 18:03:18 [16,190,063ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3307.83
2023-03-30 18:03:18 [16,190,104ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3307.87
2023-03-30 18:03:18 [16,190,145ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3307.9
2023-03-30 18:03:18 [16,190,183ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3307.93
2023-03-30 18:03:18 [16,190,224ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3307.97
2023-03-30 18:03:18 [16,190,266ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3308
2023-03-30 18:03:18 [16,190,304ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3308.03
2023-03-30 18:03:18 [16,190,343ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3308.07
2023-03-30 18:03:18 [16,190,385ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3308.1
2023-03-30 18:03:18 [16,190,425ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3308.13
2023-03-30 18:03:18 [16,190,464ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3308.17
2023-03-30 18:03:18 [16,190,505ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3308.2
2023-03-30 18:03:18 [16,190,546ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3308.23
2023-03-30 18:03:18 [16,190,585ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3308.27
2023-03-30 18:03:18 [16,190,626ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3308.3
2023-03-30 18:03:18 [16,190,666ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3308.33
2023-03-30 18:03:18 [16,190,706ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3308.37
2023-03-30 18:03:18 [16,190,749ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3308.4
2023-03-30 18:03:18 [16,190,789ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3308.43
2023-03-30 18:03:18 [16,190,829ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3308.47
2023-03-30 18:03:18 [16,190,870ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3308.5
2023-03-30 18:03:18 [16,190,909ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3308.53
2023-03-30 18:03:18 [16,190,948ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3308.57
2023-03-30 18:03:19 [16,190,990ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3308.6
2023-03-30 18:03:19 [16,191,029ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3308.63
2023-03-30 18:03:19 [16,191,069ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3308.67
2023-03-30 18:03:19 [16,191,111ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3308.7
2023-03-30 18:03:19 [16,191,150ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3308.73
2023-03-30 18:03:19 [16,191,191ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3308.77
2023-03-30 18:03:19 [16,191,232ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3308.8
2023-03-30 18:03:19 [16,191,272ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3308.83
2023-03-30 18:03:19 [16,191,312ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3308.87
2023-03-30 18:03:19 [16,191,354ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3308.9
2023-03-30 18:03:19 [16,191,394ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3308.93
2023-03-30 18:03:19 [16,191,434ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3308.97
2023-03-30 18:03:19 [16,191,476ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3309
2023-03-30 18:03:19 [16,191,514ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3309.03
2023-03-30 18:03:19 [16,191,555ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3309.07
2023-03-30 18:03:19 [16,191,596ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3309.1
2023-03-30 18:03:19 [16,191,634ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3309.13
2023-03-30 18:03:19 [16,191,674ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3309.17
2023-03-30 18:03:19 [16,191,715ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3309.2
2023-03-30 18:03:19 [16,191,756ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3309.23
2023-03-30 18:03:19 [16,191,796ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3309.27
2023-03-30 18:03:19 [16,191,839ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3309.3
2023-03-30 18:03:19 [16,191,878ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3309.33
2023-03-30 18:03:19 [16,191,918ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3309.37
2023-03-30 18:03:19 [16,191,961ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3309.4
2023-03-30 18:03:20 [16,191,999ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3309.43
2023-03-30 18:03:20 [16,192,038ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3309.47
2023-03-30 18:03:20 [16,192,079ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3309.5
2023-03-30 18:03:20 [16,192,119ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3309.53
2023-03-30 18:03:20 [16,192,158ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3309.57
2023-03-30 18:03:20 [16,192,200ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3309.6
2023-03-30 18:03:20 [16,192,241ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3309.63
2023-03-30 18:03:20 [16,192,282ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3309.67
2023-03-30 18:03:20 [16,192,323ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3309.7
2023-03-30 18:03:20 [16,192,362ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3309.73
2023-03-30 18:03:20 [16,192,402ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3309.77
2023-03-30 18:03:20 [16,192,443ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3309.8
2023-03-30 18:03:20 [16,192,482ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3309.83
2023-03-30 18:03:20 [16,192,521ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3309.87
2023-03-30 18:03:20 [16,192,562ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3309.9
2023-03-30 18:03:20 [16,192,601ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3309.93
2023-03-30 18:03:20 [16,192,640ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3309.97
2023-03-30 18:03:20 [16,192,680ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3310
2023-03-30 18:03:20 [16,192,720ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3310.03
2023-03-30 18:03:20 [16,192,759ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3310.07
2023-03-30 18:03:20 [16,192,800ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3310.1
2023-03-30 18:03:20 [16,192,839ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3310.13
2023-03-30 18:03:20 [16,192,878ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3310.17
2023-03-30 18:03:20 [16,192,920ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3310.2
2023-03-30 18:03:20 [16,192,958ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3310.23
2023-03-30 18:03:21 [16,192,998ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3310.27
2023-03-30 18:03:21 [16,193,039ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3310.3
2023-03-30 18:03:21 [16,193,079ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3310.33
2023-03-30 18:03:21 [16,193,118ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3310.37
2023-03-30 18:03:21 [16,193,161ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3310.4
2023-03-30 18:03:21 [16,193,199ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3310.43
2023-03-30 18:03:21 [16,193,238ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3310.47
2023-03-30 18:03:21 [16,193,280ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3310.5
2023-03-30 18:03:21 [16,193,319ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3310.53
2023-03-30 18:03:21 [16,193,359ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3310.57
2023-03-30 18:03:21 [16,193,399ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3310.6
2023-03-30 18:03:21 [16,193,440ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3310.63
2023-03-30 18:03:21 [16,193,485ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3310.67
2023-03-30 18:03:21 [16,193,526ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3310.7
2023-03-30 18:03:21 [16,193,566ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3310.73
2023-03-30 18:03:21 [16,193,603ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3310.77
2023-03-30 18:03:21 [16,193,640ms] [Warning] [omni.graph.ui.ogn.nodes.OgnPrintText] 3310.8
Is this what you’re looking for?
It is in fact going up one second each second. I doesn’t reset it’s value when I stop the simulation though. Should I be reseting it?
yeah that looks good. I just want to confirm that works as expect. The not resetting thing is expected for now, but your graph doesn’t work even if you never press stop, right?
Sorry. Maybe this will clarify the problem I’m having. The data flow within the graph appears to be working just fine. The problem is the result from the Isaac Compute Odometry Node. The position and orientation values (position in particular) are what seem to jump.
The graph itself seems to be working (at least from what I can tell). My problem is I’m unsure whether the Compute Odometry node is being thrown off by something in my setup.
There error in the terminal references the clock but it may also be how I setup my robot. I have a hunch that perhaps the odometry is being improperly calculated due to poor robot setup.
The only problem is that I don’t know what action graph nodes or rigging on the articulation robot affects how the odometry node calculates the odometry. The documentation I was able to find isn’t very clear on this. Would you be able able to share insight on what the Isaac Compute Odometry Node uses to perform it’s calculations?
Ok! So I got it working. The problem was that the occupancy map I was using was an older version of the environment I’m using currently. I regenerated the occupancy map and now the odometry frame is being corrected properly.
