Odometry action graph publishes zeros
Note: For any Isaac Lab topics, please submit your topic to its GitHub repo (GitHub - isaac-sim/IsaacLab: Unified framework for robot learning built on NVIDIA Isaac Sim) following the instructions provided on Isaac Lab’s Contributing Guidelines (Contribution Guidelines — Isaac Lab Documentation).
Isaac Sim Version
4.5.0
4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
GPU Information
  • Model: RTX5000 ADA
  • Driver Version: 535.183.01
Topic Description
Detailed Description
The odometry action graph does not update when using IsaacSim 4.5. It just publishes zeros. This issue does not occur in Isaac 4.2.
Steps to Reproduce
  1. Run the odom_check branch of GitHub - UWRobotLearning/GroundControl: The Isaac Sim Extension for Ground Autonomy
  2. python scripts/environments/teleoperation/teleop_se2_agent_ROS2.py --task Isaac-Navigation-Flat-Go2-Play-v0 --num_envs 1
  3. In a separate terminal run ros2 topic echo /go2/platform/odom --field pose.pose
Error Messages
(If applicable, copy and paste any error messages you received)
Screenshots or Videos
(If applicable, add screenshots or links to videos that demonstrate the issue)
Additional Information
What I’ve Tried
(Describe any troubleshooting steps you’ve already taken)
Related Issues
(If you’re aware of any related issues or forum posts, please link them here)
Additional Context
(Add any other context about the problem here)
Is this issue reproducible following the tutorial using Isaac Sim 4.5.0?
I apologize, I am only seeing this error in IsaacLab, not IsaacSim. I posted in the wrong forum.
