Isaac Lab Test Cases Failing
Hi, I am a beginner regarding IsaacLab, and I have recently installed it to use it with Eureka for Isaaclab repository, however, after installation I ran the tests and found that several testcase is failing. Some of them seems to concern me such as the test_environments.py, test_multi_agent_environments.py, and test_rl_games_wrapper.py. Thus, I would like to know how how should I resolve these tests failing.
Some of the scripts other than the tests that I was not able to run include:
(isaaclab) elmo@elmo-Zenbook-UX6404VI-UX6404VI:~/Documents/projects/IsaacLab$ python source/standalone/benchmarks/benchmark_rsl_rl.py --task=Isaac-Cartpole-v0 --headless
File “/home/elmo/Documents/projects/IsaacLab/source/standalone/benchmarks/benchmark_rsl_rl.py”, line 20, in
import source.standalone.workflows.rsl_rl.cli_args as cli_args # isort: skip
ModuleNotFoundError: No module named ‘source’
I found the same problem with the other RL benchmark scripts
Here is my system information:
Ubuntu 22.04
GPU RTX4070
CUDA 12.5, Driver 555.58.02
CPU Intel I9 13900H
Conda 24.7.1
Isaac Sim Python 4.2.0
IsaacLab 1.2.0
As in regards to the installation process,
I followed the IsaacLab documentation completely. I also ensured that OpenGL works normally with the GPU prior to the installation process.
Per Test Result Summary
| Test Path | Result | Time (s) |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab/test/assets/test_articulation.py | PASSED | 44.58 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab/test/assets/test_deformable_object.py | PASSED | 20.65 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab/test/assets/test_rigid_object.py | PASSED | 29.56 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab/test/assets/test_rigid_object_collection.py | PASSED | 32.98 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab/test/deps/test_scipy.py | FAILED | 0.30 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab/test/deps/test_torch.py | PASSED | 2.21 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab/test/envs/test_direct_marl_env.py | PASSED | 5.21 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab/test/envs/test_env_rendering_logic.py | PASSED | 22.97 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab/test/envs/test_manager_based_env.py | PASSED | 4.78 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab/test/envs/test_manager_based_rl_env_ui.py | PASSED | 10.11 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab/test/envs/test_null_command_term.py | PASSED | 7.31 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab/test/envs/test_spaces_utils.py | PASSED | 18.48 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab/test/managers/test_event_manager.py | PASSED | 6.90 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab/test/managers/test_observation_manager.py | PASSED | 4.76 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab/test/managers/test_reward_manager.py | PASSED | 4.55 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab/test/markers/test_visualization_markers.py | PASSED | 6.47 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab/test/performance/test_kit_startup_performance.py | PASSED | 4.05 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab/test/performance/test_robot_load_performance.py | PASSED | 67.76 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab/test/scene/test_interactive_scene.py | PASSED | 5.31 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab/test/sensors/test_camera.py | PASSED | 38.91 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab/test/sensors/test_contact_sensor.py | PASSED | 15.47 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab/test/sensors/test_frame_transformer.py | PASSED | 11.20 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab/test/sensors/test_imu.py | PASSED | 49.90 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab/test/sensors/test_ray_caster_camera.py | FAILED | 24.93 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab/test/sensors/test_tiled_camera.py | PASSED | 38.80 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab/test/sim/test_build_simulation_context_headless.py | PASSED | 5.95 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab/test/sim/test_mesh_converter.py | PASSED | 9.36 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab/test/sim/test_mjcf_converter.py | PASSED | 5.86 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab/test/sim/test_schemas.py | PASSED | 7.31 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab/test/sim/test_simulation_context.py | PASSED | 4.29 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab/test/sim/test_simulation_render_config.py | PASSED | 7.86 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab/test/sim/test_spawn_from_files.py | PASSED | 7.00 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab/test/sim/test_spawn_lights.py | PASSED | 4.57 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab/test/sim/test_spawn_materials.py | PASSED | 4.96 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab/test/sim/test_spawn_meshes.py | PASSED | 7.17 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab/test/sim/test_spawn_sensors.py | PASSED | 4.20 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab/test/sim/test_spawn_shapes.py | PASSED | 5.90 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab/test/sim/test_spawn_wrappers.py | PASSED | 5.33 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab/test/sim/test_urdf_converter.py | PASSED | 8.00 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab/test/sim/test_utils.py | PASSED | 23.02 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab/test/terrains/test_terrain_generator.py | PASSED | 70.54 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab/test/terrains/test_terrain_importer.py | PASSED | 99.79 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab/test/utils/test_assets.py | PASSED | 3.38 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab/test/utils/test_circular_buffer.py | PASSED | 3.10 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab/test/utils/test_configclass.py | PASSED | 3.13 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab/test/utils/test_delay_buffer.py | PASSED | 3.76 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab/test/utils/test_dict.py | PASSED | 3.31 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab/test/utils/test_math.py | PASSED | 11.67 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab/test/utils/test_modifiers.py | PASSED | 3.91 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab/test/utils/test_noise.py | PASSED | 3.56 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab/test/utils/test_string.py | PASSED | 3.52 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab/test/utils/test_timer.py | PASSED | 5.33 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab_assets/test/test_valid_configs.py | PASSED | 68.16 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab_tasks/test/test_environment_determinism.py | PASSED | 123.84 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab_tasks/test/test_environments.py | FAILED | 148.69 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab_tasks/test/test_hydra.py | PASSED | 5.94 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab_tasks/test/test_multi_agent_environments.py | FAILED | 11.15 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab_tasks/test/wrappers/test_rl_games_wrapper.py | FAILED | 18.37 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab_tasks/test/wrappers/test_rsl_rl_wrapper.py | PASSED | 25.00 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab_tasks/test/wrappers/test_sb3_wrapper.py | PASSED | 22.37 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab_tasks/test/wrappers/test_skrl_wrapper.py | FAILED | 17.96 |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab/test/app/test_argparser_launch.py | SKIPPED | N/A |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab/test/app/test_env_var_launch.py | SKIPPED | N/A |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab/test/app/test_kwarg_launch.py | SKIPPED | N/A |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab/test/controllers/test_differential_ik.py | SKIPPED | N/A |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab/test/sensors/test_tiled_camera_env.py | SKIPPED | N/A |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab/test/sim/test_build_simulation_context_nonheadless.py | SKIPPED | N/A |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab_tasks/test/test_data_collector.py | SKIPPED | N/A |
| /home/elmo/Documents/projects/IsaacLab/source/extensions/omni.isaac.lab_tasks/test/test_record_video.py | SKIPPED | N/A |
I meet the same problem.Did you solve it?
Thank you for your interest in Isaac Lab. To ensure efficient support and collaboration, please submit your topic to its GitHub repo following the instructions provided on Isaac Lab’s Contributing Guidelines regarding discussions, submitting issues, feature requests, and contributing to the project.
We appreciate your understanding and look forward to assisting you.
