Isaac_ros_imu_bmi088 cmake error
hi
here i try to compile the ros bmi088, the source code coming from this branch:
isaac_ros_nova-main/isaac_ros_imu_bmi088
could you help me check why this error happen?
thanks
/ros/test/isaac_ros_nova-main/isaac_ros_imu_bmi088$ cmake .
– CMAKE_BUILD_TYPE: Release
– Architecture: aarch64
– Found ament_cmake_auto: 1.3.6 (/opt/ros/humble/share/ament_cmake_auto/cmake)
– Found rosidl_generator_c: 3.1.5 (/opt/ros/humble/share/rosidl_generator_c/cmake)
– Found rosidl_adapter: 3.1.5 (/opt/ros/humble/share/rosidl_adapter/cmake)
– Found rosidl_generator_cpp: 3.1.5 (/opt/ros/humble/share/rosidl_generator_cpp/cmake)
– Using all available rosidl_typesupport_c: rosidl_typesupport_fastrtps_c;rosidl_typesupport_introspection_c
– Using all available rosidl_typesupport_cpp: rosidl_typesupport_fastrtps_cpp;rosidl_typesupport_introspection_cpp
– Found rmw_implementation_cmake: 6.1.1 (/opt/ros/humble/share/rmw_implementation_cmake/cmake)
– Found rmw_fastrtps_cpp: 6.2.5 (/opt/ros/humble/share/rmw_fastrtps_cpp/cmake)
– Using RMW implementation ‘rmw_fastrtps_cpp’ as default
CMake Error at gxf/bmi088_imu/CMakeLists.txt:27 (find_package):
  • No “FindGXF.cmake” found in CMAKE_MODULE_PATH.*
CMake Warning (dev) at gxf/bmi088_imu/CMakeLists.txt:27 (find_package):
FindGXF.cmake must either be part of this project itself, in this case
adjust CMAKE_MODULE_PATH so that it points to the correct location inside
its source tree.
Or it must be installed by a package which has already been found via
find_package(). In this case make sure that package has indeed been found
and adjust CMAKE_MODULE_PATH to contain the location where that package has
installed FindGXF.cmake. This must be a location provided by that package.
This error in general means that the buildsystem of this project is relying
on a Find-module without ensuring that it is actually available.
This warning is for project developers. Use -Wno-dev to suppress it.
Hi @543773044
Welcome to the Isaac ROS forum
Where are you compiling the Isaac ROS nova package?
Please build from our docker Isaac ROS Common — isaac_ros_docs documentation
Best,
Raffaello
hi raffaello
thanks very much.
here i download the isaac_ros_common    and  run  ./scripts/run_dev.sh
could  you tell me what to do next?
put the isaac_ros_imu_bmi088 in  isaac_ros_common and run cmake .?
thanks
Hi @543773044
Setup your developer environment follow the documentation: Developer Environment Setup — isaac_ros_docs documentation
In:
cd ${ISAAC_ROS_WS}/src
Clone:
git clone https://github.com/NVIDIA-ISAAC-ROS/isaac_ros_common.git
git clone https://github.com/NVIDIA-ISAAC-ROS/isaac_ros_nova.git
Launch the Docker container using the run_dev.sh script:
cd ${ISAAC_ROS_WS}/src/isaac_ros_common && \
Inside the container, install all dependencies with
rosdep install --from-paths src --ignore-src -r -y
Now build, and source the workspace:
cd /workspaces/isaac_ros-dev && \
  colcon build --symlink-install && \
  source install/setup.bash
Now all packages are built, but let me know if you have issues.
Best,
Raffaello
hi Raffaello
 thanks a lot for your great help.
 Right now it can compile successfully.
 these step are very usefully.
 **Finished <<< isaac_ros_imu_bmi088 [53.3s]**
[Processing: custom_nitros_image, custom_nitros_string, isaac_ros_argus_camera]
Finished <<< isaac_ros_argus_camera [2min 24s]
Starting >>> isaac_ros_hawk
Starting >>> isaac_ros_owl
Finished <<< custom_nitros_string [1min 29s]
Finished <<< custom_nitros_image [1min 39s]
[Processing: isaac_ros_hawk, isaac_ros_owl]
Finished <<< isaac_ros_owl [41.6s]
Finished <<< isaac_ros_hawk [55.9s]
Summary: 40 packages finished [6min 14s]
could you share that next how to run the
You can run the script:
ros2 launch isaac_ros_imu_bmi088 isaac_ros_bmi088.launch.py
Let me know if this post is helpful
Best,
Raffaello
hi Raffaello
thanks for your great help.
here i just try to run ros2 launch isaac_ros_imu_bmi088 isaac_ros_bmi088.launch.py
but found some issue ;
1 extensions/timestamp_correlator/correlated_timestamp_driver.cpp@75: failed to open the device /dev/nvpps0 errno = 2
2 Error opening /sys/bus/iio/devices/iio:device0/in_accel_sampling_frequency
i checked in the kernel side have this node.
admin@Orin-AGX-A11:/sys/bus/iio/devices/iio:device0$ ls -l
total 0
drwxr-xr-x 2 root root 0 May 21 23:59 buffer
-rw-r–r-- 1 root root 4096 May 22 00:19 current_timestamp_clock
-r–r–r-- 1 root root 4096 May 22 00:19 dev
-r–r–r-- 1 root root 4096 May 22 00:19 dev_err
-r–r–r-- 1 root root 4096 May 22 00:19 dev_state
-r–r–r-- 1 root root 4096 May 22 00:19 dump_regs
-rw------- 1 root root 4096 May 21 23:59 in_accel_sampling_frequency
here is the full log, could you help us check? thanks a lot
admin@Orin-AGX-A11:/workspaces/isaac_ros-dev/install/isaac_ros_imu_bmi088/share/isaac_ros_imu_bmi088/launch$ ros2 launch isaac_ros_imu_bmi088 isaac_ros_bmi088.launch.py
[INFO] [launch]: All log files can be found below /home/admin/.ros/log/2024-05-22-01-19-06-592261-Orin-AGX-A11-18588
[INFO] [launch]: Default logging verbosity is set to INFO
[INFO] [component_container_mt-1]: process started with pid [18599]
[component_container_mt-1] [INFO] [1716311947.099423560] [bmi088_container]: Load Library: /workspaces/isaac_ros-dev/install/isaac_ros_correlated_timestamp_driver/lib/libcorrelated_timestamp_driver_node.so
[component_container_mt-1] [INFO] [1716311947.146545544] [bmi088_container]: Found class: rclcpp_components::NodeFactoryTemplatenvidia::isaac_ros::correlated_timestamp_driver::CorrelatedTimestampDriverNode
[component_container_mt-1] [INFO] [1716311947.146665992] [bmi088_container]: Instantiate class: rclcpp_components::NodeFactoryTemplatenvidia::isaac_ros::correlated_timestamp_driver::CorrelatedTimestampDriverNode
[component_container_mt-1] [INFO] [1716311947.153817992] [NitrosContext]: [NitrosContext] Creating a new shared context
[component_container_mt-1] [INFO] [1716311947.154063144] [correlated_timestamp_driver]: [NitrosNode] Initializing NitrosNode
[component_container_mt-1] [INFO] [1716311947.155614632] [NitrosContext]: [NitrosContext] Loading extension: gxf/lib/std/libgxf_std.so
[component_container_mt-1] [INFO] [1716311947.165184136] [NitrosContext]: [NitrosContext] Loading extension: gxf/lib/libgxf_gxf_helpers.so
[component_container_mt-1] [INFO] [1716311947.170074792] [NitrosContext]: [NitrosContext] Loading extension: gxf/lib/libgxf_sight.so
[component_container_mt-1] [INFO] [1716311947.175005416] [NitrosContext]: [NitrosContext] Loading extension: gxf/lib/libgxf_atlas.so
[component_container_mt-1] [INFO] [1716311947.179954248] [NitrosContext]: [NitrosContext] Loading application: ‘/workspaces/isaac_ros-dev/install/isaac_ros_nitros/share/isaac_ros_nitros/config/type_adapter_nitros_context_graph.yaml’
[component_container_mt-1] [INFO] [1716311947.181188872] [NitrosContext]: [NitrosContext] Initializing application…
[component_container_mt-1] [INFO] [1716311947.184903976] [NitrosContext]: [NitrosContext] Running application…
[component_container_mt-1] 2024-05-22 01:19:07.184 WARN gxf/std/program.cpp@514: No system specified. Nothing to do
[component_container_mt-1] [INFO] [1716311947.186166536] [correlated_timestamp_driver]: [NitrosNode] Starting NitrosNode
[component_container_mt-1] [INFO] [1716311947.186208136] [correlated_timestamp_driver]: [NitrosNode] Loading built-in preset extension specs
[component_container_mt-1] [INFO] [1716311947.188632776] [correlated_timestamp_driver]: [NitrosNode] Loading built-in extension specs
[component_container_mt-1] [INFO] [1716311947.188678280] [correlated_timestamp_driver]: [NitrosNode] Loading preset extension specs
[component_container_mt-1] [INFO] [1716311947.188981064] [correlated_timestamp_driver]: [NitrosNode] Loading extension specs
[component_container_mt-1] [INFO] [1716311947.189001160] [correlated_timestamp_driver]: [NitrosNode] Loading generator rules
[component_container_mt-1] [INFO] [1716311947.189012456] [correlated_timestamp_driver]: [NitrosNode] Loading extensions
[component_container_mt-1] [INFO] [1716311947.189452616] [correlated_timestamp_driver]: [NitrosContext] Loading extension: gxf/lib/libgxf_message_compositor.so
[component_container_mt-1] [INFO] [1716311947.191226088] [correlated_timestamp_driver]: [NitrosContext] Loading extension: gxf/lib/libgxf_timestamp_correlator.so
[component_container_mt-1] [INFO] [1716311947.196700008] [NitrosContext]: [NitrosContext] Loading extension: gxf/lib/serialization/libgxf_serialization.so
[component_container_mt-1] [INFO] [1716311947.201586248] [NitrosContext]: [NitrosContext] Loading extension: gxf/lib/libgxf_isaac_messages.so
[component_container_mt-1] [INFO] [1716311947.203055080] [correlated_timestamp_driver]: [NitrosNode] Loading graph to the optimizer
[component_container_mt-1] [INFO] [1716311947.204422760] [correlated_timestamp_driver]: [NitrosNode] Running optimization
[component_container_mt-1] [INFO] [1716311947.205665928] [correlated_timestamp_driver]: [NitrosNode] Obtaining graph IO group info from the optimizer
[component_container_mt-1] [INFO] [1716311947.205987144] [correlated_timestamp_driver]: [NitrosNode] Creating negotiated publishers/subscribers
[component_container_mt-1] [INFO] [1716311947.209556648] [correlated_timestamp_driver]: [NitrosNode] Starting negotiation…
[INFO] [launch_ros.actions.load_composable_nodes]: Loaded node ‘/correlated_timestamp_driver’ in container ‘/bmi088_container’
[component_container_mt-1] [INFO] [1716311947.213559432] [bmi088_container]: Load Library: /workspaces/isaac_ros-dev/install/isaac_ros_imu_bmi088/lib/libimu_bmi088_node.so
[component_container_mt-1] [INFO] [1716311947.217382408] [bmi088_container]: Found class: rclcpp_components::NodeFactoryTemplatenvidia::isaac_ros::imu_bmi088::Bmi088Node
[component_container_mt-1] [INFO] [1716311947.217437608] [bmi088_container]: Instantiate class: rclcpp_components::NodeFactoryTemplatenvidia::isaac_ros::imu_bmi088::Bmi088Node
[component_container_mt-1] [INFO] [1716311947.222133576] [bmi088]: [NitrosNode] Initializing NitrosNode
[component_container_mt-1] [INFO] [1716311947.223148648] [bmi088]: [NitrosNode] Starting NitrosNode
[component_container_mt-1] [INFO] [1716311947.223186120] [bmi088]: [NitrosNode] Loading built-in preset extension specs
[component_container_mt-1] [INFO] [1716311947.225371496] [bmi088]: [NitrosNode] Loading built-in extension specs
[component_container_mt-1] [INFO] [1716311947.225438952] [bmi088]: [NitrosNode] Loading preset extension specs
[component_container_mt-1] [INFO] [1716311947.226365864] [bmi088]: [NitrosNode] Loading extension specs
[component_container_mt-1] [INFO] [1716311947.226392872] [bmi088]: [NitrosNode] Loading generator rules
[component_container_mt-1] [INFO] [1716311947.226632744] [bmi088]: [NitrosNode] Loading extensions
[component_container_mt-1] [INFO] [1716311947.227642216] [bmi088]: [NitrosContext] Loading extension: gxf/lib/bmi088_imu/libgxf_bmi088_imu.so
[component_container_mt-1] [INFO] [1716311947.231927016] [bmi088]: [NitrosContext] Loading extension: gxf/lib/imu_utils/libgxf_imu_utils.so
[component_container_mt-1] [INFO] [1716311947.236876872] [bmi088]: [NitrosNode] Loading graph to the optimizer
[component_container_mt-1] [INFO] [1716311947.241168616] [bmi088]: [NitrosNode] Running optimization
[component_container_mt-1] [INFO] [1716311947.272903208] [bmi088]: [NitrosNode] Obtaining graph IO group info from the optimizer
[component_container_mt-1] [INFO] [1716311947.274232104] [bmi088]: [NitrosNode] Creating negotiated publishers/subscribers
[component_container_mt-1] [INFO] [1716311947.281464200] [bmi088]: [NitrosNode] Starting negotiation…
[component_container_mt-1] [INFO] [1716311947.282294024] [correlated_timestamp_driver]: Negotiating
[INFO] [launch_ros.actions.load_composable_nodes]: Loaded node ‘/bmi088’ in container ‘/bmi088_container’
[component_container_mt-1] [INFO] [1716311948.210344648] [correlated_timestamp_driver]: [NitrosNode] Starting post negotiation setup
[component_container_mt-1] [INFO] [1716311948.210445736] [correlated_timestamp_driver]: [NitrosNode] Getting data format negotiation results
[component_container_mt-1] [INFO] [1716311948.210476072] [correlated_timestamp_driver]: [NitrosPublisher] Use the negotiated data format: “nitros_correlated_timestamp”
[component_container_mt-1] [INFO] [1716311948.211041736] [correlated_timestamp_driver]: [NitrosNode] Exporting the final graph based on the negotiation results
[component_container_mt-1] [INFO] [1716311948.215676456] [correlated_timestamp_driver]: [NitrosNode] Wrote the final top level YAML graph to “/tmp/isaac_ros_nitros/graphs/ZKKXFGQWXA/ZKKXFGQWXA.yaml”
[component_container_mt-1] [INFO] [1716311948.215796168] [correlated_timestamp_driver]: [NitrosNode] Calling user’s pre-load-graph callback
[component_container_mt-1] [INFO] [1716311948.215832840] [correlated_timestamp_driver]: [NitrosNode] Loading application
[component_container_mt-1] [INFO] [1716311948.215864904] [correlated_timestamp_driver]: [NitrosContext] Loading application: ‘/tmp/isaac_ros_nitros/graphs/ZKKXFGQWXA/ZKKXFGQWXA.yaml’
[component_container_mt-1] [INFO] [1716311948.219755784] [correlated_timestamp_driver]: [NitrosNode] Linking Nitros pub/sub to the loaded application
[component_container_mt-1] [INFO] [1716311948.220086408] [correlated_timestamp_driver]: [NitrosNode] Calling user’s post-load-graph callback
[component_container_mt-1] [INFO] [1716311948.220254120] [correlated_timestamp_driver]: [NitrosContext] Initializing application…
[component_container_mt-1] [INFO] [1716311948.225740456] [correlated_timestamp_driver]: [NitrosContext] Running application…
[component_container_mt-1] [INFO] [1716311948.226093160] [correlated_timestamp_driver]: [NitrosNode] Starting a heartbeat timer (eid=22)
[component_container_mt-1] 2024-05-22 01:19:08.226 ERROR extensions/timestamp_correlator/correlated_timestamp_driver.cpp@75: failed to open the device /dev/nvpps0 errno = 2
[component_container_mt-1] 2024-05-22 01:19:08.226 ERROR gxf/std/entity_executor.cpp@563: Entity [ZKKXFGQWXA_correlator] must be in Started, Tick Pending, Ticking or Idle stage before stopping. Current state is StartPending
[component_container_mt-1] 2024-05-22 01:19:08.226 WARN gxf/std/greedy_scheduler.cpp@250: Error while executing entity 17 named ‘ZKKXFGQWXA_correlator’: GXF_FAILURE
[component_container_mt-1] [INFO] [1716311948.282211112] [bmi088]: [NitrosNode] Starting post negotiation setup
[component_container_mt-1] [INFO] [1716311948.282285096] [bmi088]: [NitrosNode] Getting data format negotiation results
[component_container_mt-1] [INFO] [1716311948.282313192] [bmi088]: [NitrosPublisher] Negotiation ended with no results
[component_container_mt-1] [INFO] [1716311948.282336520] [bmi088]: [NitrosPublisher] Use only the compatible publisher: topic_name=“/imu”, data_format=“nitros_imu”
[component_container_mt-1] [INFO] [1716311948.282361000] [bmi088]: [NitrosSubscriber] Use the negotiated data format: “nitros_correlated_timestamp”
[component_container_mt-1] [INFO] [1716311948.282639880] [bmi088]: [NitrosNode] Exporting the final graph based on the negotiation results
[component_container_mt-1] [INFO] [1716311948.299052200] [bmi088]: [NitrosNode] Wrote the final top level YAML graph to “/tmp/isaac_ros_nitros/graphs/OHYGACIKEM/OHYGACIKEM.yaml”
[component_container_mt-1] [INFO] [1716311948.299152424] [bmi088]: [NitrosNode] Calling user’s pre-load-graph callback
[component_container_mt-1] [INFO] [1716311948.299187848] [bmi088]: [NitrosNode] Loading application
[component_container_mt-1] [INFO] [1716311948.299220904] [bmi088]: [NitrosContext] Loading application: ‘/tmp/isaac_ros_nitros/graphs/OHYGACIKEM/OHYGACIKEM.yaml’
[component_container_mt-1] [INFO] [1716311948.310230088] [bmi088]: [NitrosNode] Linking Nitros pub/sub to the loaded application
[component_container_mt-1] [INFO] [1716311948.310483240] [bmi088]: [NitrosNode] Calling user’s post-load-graph callback
[component_container_mt-1] [INFO] [1716311948.310620936] [bmi088]: [NitrosContext] Initializing application…
[component_container_mt-1] [INFO] [1716311948.322099528] [bmi088]: [NitrosContext] Running application…
[component_container_mt-1] [INFO] [1716311948.322459560] [bmi088]: [NitrosNode] Starting a heartbeat timer (eid=65)
[component_container_mt-1] 2024-05-22 01:19:08.322 ERROR /workspaces/isaac_ros-dev/src/isaac_ros_nova/isaac_ros_imu_bmi088/gxf/bmi088_imu/extensions/bmi088_imu/bmi088_driver.cpp@491: Error opening /sys/bus/iio/devices/iio:device0/in_accel_sampling_frequency
[component_container_mt-1] 2024-05-22 01:19:08.322 ERROR /workspaces/isaac_ros-dev/src/isaac_ros_nova/isaac_ros_imu_bmi088/gxf/bmi088_imu/extensions/bmi088_imu/bmi088_driver.cpp@89: Expression ‘writeAndVerifyInt(accel_freq_path + “/in_accel_sampling_frequency”, accel_frequency_.get())’ failed with error ‘GXF_FAILURE’. Failed to set accelerometer frequency, available frequencies are: 25, 50, 100, 200, 400, 800, 1600
[component_container_mt-1] 2024-05-22 01:19:08.323 WARN gxf/std/multi_thread_scheduler.cpp@325: Error while executing entity E46 named ‘OHYGACIKEM_bmi088_driver’: GXF_FAILURE
[component_container_mt-1] 2024-05-22 01:19:08.323 ERROR gxf/std/entity_executor.cpp@563: Entity [OHYGACIKEM_bmi088_driver] must be in Started, Tick Pending, Ticking or Idle stage before stopping. Current state is StartPending
[component_container_mt-1] 2024-05-22 01:19:09.226 ERROR gxf/std/entity_executor.cpp@210: Entity with eid 22 not found!
[component_container_mt-1] [WARN] [1716311949.226425320] [correlated_timestamp_driver]: [NitrosNode] The heartbeat entity (eid=22) was stopped. The graph may have been terminated.
[component_container_mt-1] [INFO] [1716311949.233014088] [bmi088]: [NitrosNode] Terminating the running application
[component_container_mt-1] [INFO] [1716311949.233078376] [bmi088]: [NitrosContext] Interrupting GXF…
[component_container_mt-1] 2024-05-22 01:19:09.233 ERROR gxf/core/runtime.cpp@1400: Graph interrupt failed with error: GXF_FAILURE
[component_container_mt-1] [ERROR] [1716311949.233248584] [bmi088]: [NitrosContext] GxfGraphInterrupt Error: GXF_FAILURE
[component_container_mt-1] [INFO] [1716311949.233261128] [bmi088]: [NitrosContext] Waiting on GXF…
[component_container_mt-1] 2024-05-22 01:19:09.233 ERROR gxf/std/program.cpp@556: wait failed. Deactivating…
[component_container_mt-1] |==================================================================================================================================================================|
[component_container_mt-1] | Job Statistics Report (regular) |
[component_container_mt-1] | Name | Count | Time (Median - 90% - Max) [ms] | Load (%) | Exec(ms) | Variation (Median - 90% - Max) [ns] |
[component_container_mt-1] |------------------------------------------------------------------------------------------------------------------------------------------------------------------|
[component_container_mt-1] | Entity Statistics Report (regular) |
[component_container_mt-1] | Entity Name | Entity State | Count | Time (Median - 90% - Max) [ms] |
[component_container_mt-1] 2024-05-22 01:19:09.235 WARN gxf/std/entity_warden.cpp@433: Component of type nvidia::gxf::MultiThreadScheduler, cid 97 failed to deinitialize with code GXF_FAILURE
[component_container_mt-1] 2024-05-22 01:19:09.235 ERROR gxf/core/runtime.cpp@731: Could not deinitialize entity ‘OHYGACIKEM_XZILHTNEVM’ (E95): GXF_FAILURE
[component_container_mt-1] 2024-05-22 01:19:09.235 ERROR gxf/std/program.cpp@558: Deactivation failed.
[component_container_mt-1] 2024-05-22 01:19:09.235 ERROR gxf/core/runtime.cpp@1408: Graph wait failed with error: GXF_FAILURE
[component_container_mt-1] [ERROR] [1716311949.235550952] [bmi088]: [NitrosContext] GxfGraphWait Error: GXF_FAILURE
[component_container_mt-1] [INFO] [1716311949.235569864] [bmi088]: [NitrosNode] Application termination done
[component_container_mt-1] [INFO] [1716311949.248555976] [correlated_timestamp_driver]: [NitrosNode] Terminating the running application
[component_container_mt-1] [INFO] [1716311949.248613672] [correlated_timestamp_driver]: [NitrosContext] Interrupting GXF…
[component_container_mt-1] [INFO] [1716311949.248652488] [correlated_timestamp_driver]: [NitrosContext] Waiting on GXF…
[component_container_mt-1] 2024-05-22 01:19:09.248 ERROR gxf/std/program.cpp@556: wait failed. Deactivating…
[component_container_mt-1] 2024-05-22 01:19:09.249 ERROR gxf/core/runtime.cpp@1408: Graph wait failed with error: GXF_FAILURE
[component_container_mt-1] [ERROR] [1716311949.249454120] [correlated_timestamp_driver]: [NitrosContext] GxfGraphWait Error: GXF_FAILURE
[component_container_mt-1] [INFO] [1716311949.249472168] [correlated_timestamp_driver]: [NitrosNode] Application termination done
[INFO] [component_container_mt-1]: process has finished cleanly [pid 18599]
admin@Orin-AGX-A11:/sys/bus/iio/devices$ ls -l
total 0
lrwxrwxrwx 1 root root 0 May 21 23:59 iio:device0 → …/…/…/devices/platform/31e0000.i2c/i2c-8/i2c-9/9-0069/iio:device0
lrwxrwxrwx 1 root root 0 May 21 23:59 iio:device1 → …/…/…/devices/platform/31e0000.i2c/i2c-8/i2c-9/9-0069/iio:device1
admin@Orin-AGX-A11:/sys/bus/iio/devices$ cd iio:device0
total 0
-r–r–r-- 1 root root 4096 May 22 00:19 in_accel_sampling_frequency_available
-rw------- 1 root root 4096 May 21 23:59 in_accel_scale
-r–r–r-- 1 root root 4096 May 22 00:19 in_accel_scale_available
-rw------- 1 root root 4096 Mar 15 2023 in_accel_x_raw
-rw------- 1 root root 4096 Mar 15 2023 in_accel_y_raw
-rw------- 1 root root 4096 Mar 15 2023 in_accel_z_raw
-r–r–r-- 1 root root 4096 May 21 23:59 mount_matrix
-r–r–r-- 1 root root 4096 May 21 23:59 name
lrwxrwxrwx 1 root root 0 May 22 00:17 of_node → …/…/…/…/…/…/…/firmware/devicetree/base/i2c@31e0000/virtual_i2c_mux@50/i2c@0/bmi088_a@69
-r–r–r-- 1 root root 4096 May 22 00:17 part
drwxr-xr-x 2 root root 0 May 22 00:19 power
drwxr-xr-x 2 root root 0 Mar 15 2023 scan_elements
lrwxrwxrwx 1 root root 0 May 21 23:59 subsystem → …/…/…/…/…/…/…/bus/iio
-rw-r–r-- 1 root root 4096 Mar 15 2023 uevent
Looking at the errors seems there is no access to the devices.
Have you executed Nova Orin Init to properly configure the Nova Orin sensor suite?
hi
right now the open issue gone. but have one new doubt.
here what i do
1 cnfig the sensor like this
sensors:
front_stereo_camera:
sudo cp nova-orin.yaml /etc/nova/setup.yaml
2 try to install the ./nova-orin-init_*_arm64.deb
it have some error
ERROR: backup /etc/logrotate.d/rsyslog.nova.disabled already exist
ERROR: /opt/nvidia/nova/logrotate/…/utils.sh:151 (‘return 2’ exited with code 2)
File “/opt/nvidia/nova/setup_nova.py”, line 237, in
main()
File “/opt/nvidia/nova/setup_nova.py”, line 233, in main
setup_manager.run()
File “/opt/nvidia/nova/setup_nova.py”, line 181, in run
raise ValueError(
ValueError: Failed at calling /opt/nvidia/nova/logrotate/setup.sh in step logrotate with response 2.
ERROR: /var/lib/dpkg/info/nova-orin-init.postinst:27 (‘$NOVA_BASE_DIR/python/venv/bin/python3 $NOVA_BASE_DIR/setup_nova.py -p $processed_setup setup’ exited with code 1)
dpkg: error processing package nova-orin-init (–configure):
installed nova-orin-init package post-installation script subprocess returned error exit status 1
Errors were encountered while processing:
3 try to run the ros2 launch isaac_ros_imu_bmi088 isaac_ros_bmi088.launch.py
it always print this log
[component_container_mt-1] [33m2024-05-23 22:39:25.106 WARN extensions/timestamp_correlator/correlated_timestamp_driver.cpp@159: ioctl failed for NVPPS_GETEVENT/GETTIMESTAMP err Invalid argument[0m
here i add the full log of run the isaac_ros_bmi088 and install nova-orin-init_*_arm64.deb
[INFO] [launch]: All log files can be found below /home/admin/.ros/log/2024-05-23-22-39-23-536307-Orin-AGX-A11-14823
[INFO] [component_container_mt-1]: process started with pid [14834]
[component_container_mt-1] [INFO] [1716475164.027313216] [bmi088_container]: Load Library: /workspaces/isaac_ros-dev/install/isaac_ros_correlated_timestamp_driver/lib/libcorrelated_timestamp_driver_node.so
[component_container_mt-1] [INFO] [1716475164.048847104] [bmi088_container]: Found class: rclcpp_components::NodeFactoryTemplatenvidia::isaac_ros::correlated_timestamp_driver::CorrelatedTimestampDriverNode
[component_container_mt-1] [INFO] [1716475164.048925248] [bmi088_container]: Instantiate class: rclcpp_components::NodeFactoryTemplatenvidia::isaac_ros::correlated_timestamp_driver::CorrelatedTimestampDriverNode
[component_container_mt-1] [INFO] [1716475164.053635616] [NitrosContext]: [NitrosContext] Creating a new shared context
[component_container_mt-1] [INFO] [1716475164.053798144] [correlated_timestamp_driver]: [NitrosNode] Initializing NitrosNode
[component_container_mt-1] [INFO] [1716475164.054785024] [NitrosContext]: [NitrosContext] Loading extension: gxf/lib/std/libgxf_std.so
[component_container_mt-1] [INFO] [1716475164.060860768] [NitrosContext]: [NitrosContext] Loading extension: gxf/lib/libgxf_gxf_helpers.so
[component_container_mt-1] [INFO] [1716475164.064552512] [NitrosContext]: [NitrosContext] Loading extension: gxf/lib/libgxf_sight.so
[component_container_mt-1] [INFO] [1716475164.068254016] [NitrosContext]: [NitrosContext] Loading extension: gxf/lib/libgxf_atlas.so
[component_container_mt-1] [INFO] [1716475164.072295328] [NitrosContext]: [NitrosContext] Loading application: ‘/workspaces/isaac_ros-dev/install/isaac_ros_nitros/share/isaac_ros_nitros/config/type_adapter_nitros_context_graph.yaml’
[component_container_mt-1] [INFO] [1716475164.073326496] [NitrosContext]: [NitrosContext] Initializing application…
[component_container_mt-1] [INFO] [1716475164.076550592] [NitrosContext]: [NitrosContext] Running application…
[component_container_mt-1] [33m2024-05-23 22:39:24.076 WARN gxf/std/program.cpp@514: No system specified. Nothing to do[0m
[component_container_mt-1] [INFO] [1716475164.077647424] [correlated_timestamp_driver]: [NitrosNode] Starting NitrosNode
[component_container_mt-1] [INFO] [1716475164.077683808] [correlated_timestamp_driver]: [NitrosNode] Loading built-in preset extension specs
[component_container_mt-1] [INFO] [1716475164.080011264] [correlated_timestamp_driver]: [NitrosNode] Loading built-in extension specs
[component_container_mt-1] [INFO] [1716475164.080049024] [correlated_timestamp_driver]: [NitrosNode] Loading preset extension specs
[component_container_mt-1] [INFO] [1716475164.080350656] [correlated_timestamp_driver]: [NitrosNode] Loading extension specs
[component_container_mt-1] [INFO] [1716475164.080370848] [correlated_timestamp_driver]: [NitrosNode] Loading generator rules
[component_container_mt-1] [INFO] [1716475164.080380576] [correlated_timestamp_driver]: [NitrosNode] Loading extensions
[component_container_mt-1] [INFO] [1716475164.080758880] [correlated_timestamp_driver]: [NitrosContext] Loading extension: gxf/lib/libgxf_message_compositor.so
[component_container_mt-1] [INFO] [1716475164.082252608] [correlated_timestamp_driver]: [NitrosContext] Loading extension: gxf/lib/libgxf_timestamp_correlator.so
[component_container_mt-1] [INFO] [1716475164.086796512] [NitrosContext]: [NitrosContext] Loading extension: gxf/lib/serialization/libgxf_serialization.so
[component_container_mt-1] [INFO] [1716475164.091137152] [NitrosContext]: [NitrosContext] Loading extension: gxf/lib/libgxf_isaac_messages.so
[component_container_mt-1] [INFO] [1716475164.092395232] [correlated_timestamp_driver]: [NitrosNode] Loading graph to the optimizer
[component_container_mt-1] [INFO] [1716475164.093695264] [correlated_timestamp_driver]: [NitrosNode] Running optimization
[component_container_mt-1] [INFO] [1716475164.094920512] [correlated_timestamp_driver]: [NitrosNode] Obtaining graph IO group info from the optimizer
[component_container_mt-1] [INFO] [1716475164.095237056] [correlated_timestamp_driver]: [NitrosNode] Creating negotiated publishers/subscribers
[component_container_mt-1] [INFO] [1716475164.098241088] [correlated_timestamp_driver]: [NitrosNode] Starting negotiation…
[component_container_mt-1] [INFO] [1716475164.101426048] [bmi088_container]: Load Library: /workspaces/isaac_ros-dev/install/isaac_ros_imu_bmi088/lib/libimu_bmi088_node.so
[component_container_mt-1] [INFO] [1716475164.104836992] [bmi088_container]: Found class: rclcpp_components::NodeFactoryTemplatenvidia::isaac_ros::imu_bmi088::Bmi088Node
[component_container_mt-1] [INFO] [1716475164.104881088] [bmi088_container]: Instantiate class: rclcpp_components::NodeFactoryTemplatenvidia::isaac_ros::imu_bmi088::Bmi088Node
[component_container_mt-1] [INFO] [1716475164.109039680] [bmi088]: [NitrosNode] Initializing NitrosNode
[component_container_mt-1] [INFO] [1716475164.109923840] [bmi088]: [NitrosNode] Starting NitrosNode
[component_container_mt-1] [INFO] [1716475164.109951904] [bmi088]: [NitrosNode] Loading built-in preset extension specs
[component_container_mt-1] [INFO] [1716475164.111994080] [bmi088]: [NitrosNode] Loading built-in extension specs
[component_container_mt-1] [INFO] [1716475164.112073920] [bmi088]: [NitrosNode] Loading preset extension specs
[component_container_mt-1] [INFO] [1716475164.112911840] [bmi088]: [NitrosNode] Loading extension specs
[component_container_mt-1] [INFO] [1716475164.112939040] [bmi088]: [NitrosNode] Loading generator rules
[component_container_mt-1] [INFO] [1716475164.113134720] [bmi088]: [NitrosNode] Loading extensions
[component_container_mt-1] [INFO] [1716475164.113978496] [bmi088]: [NitrosContext] Loading extension: gxf/lib/bmi088_imu/libgxf_bmi088_imu.so
[component_container_mt-1] [INFO] [1716475164.117562336] [bmi088]: [NitrosContext] Loading extension: gxf/lib/imu_utils/libgxf_imu_utils.so
[component_container_mt-1] [INFO] [1716475164.121782336] [bmi088]: [NitrosNode] Loading graph to the optimizer
[component_container_mt-1] [INFO] [1716475164.125440704] [bmi088]: [NitrosNode] Running optimization
[component_container_mt-1] [INFO] [1716475164.154214432] [bmi088]: [NitrosNode] Obtaining graph IO group info from the optimizer
[component_container_mt-1] [INFO] [1716475164.155307328] [bmi088]: [NitrosNode] Creating negotiated publishers/subscribers
[component_container_mt-1] [INFO] [1716475164.161140736] [bmi088]: [NitrosNode] Starting negotiation…
[component_container_mt-1] [INFO] [1716475164.161662400] [correlated_timestamp_driver]: Negotiating
[component_container_mt-1] [INFO] [1716475165.098917472] [correlated_timestamp_driver]: [NitrosNode] Starting post negotiation setup
[component_container_mt-1] [INFO] [1716475165.099011904] [correlated_timestamp_driver]: [NitrosNode] Getting data format negotiation results
[component_container_mt-1] [INFO] [1716475165.099036992] [correlated_timestamp_driver]: [NitrosPublisher] Use the negotiated data format: “nitros_correlated_timestamp”
[component_container_mt-1] [INFO] [1716475165.099341312] [correlated_timestamp_driver]: [NitrosNode] Exporting the final graph based on the negotiation results
[component_container_mt-1] [INFO] [1716475165.101255488] [correlated_timestamp_driver]: [NitrosNode] Wrote the final top level YAML graph to “/tmp/isaac_ros_nitros/graphs/DLATYMEKCZ/DLATYMEKCZ.yaml”
[component_container_mt-1] [INFO] [1716475165.101319552] [correlated_timestamp_driver]: [NitrosNode] Calling user’s pre-load-graph callback
[component_container_mt-1] [INFO] [1716475165.101333568] [correlated_timestamp_driver]: [NitrosNode] Loading application
[component_container_mt-1] [INFO] [1716475165.101346272] [correlated_timestamp_driver]: [NitrosContext] Loading application: ‘/tmp/isaac_ros_nitros/graphs/DLATYMEKCZ/DLATYMEKCZ.yaml’
[component_container_mt-1] [INFO] [1716475165.102973536] [correlated_timestamp_driver]: [NitrosNode] Linking Nitros pub/sub to the loaded application
[component_container_mt-1] [INFO] [1716475165.103132064] [correlated_timestamp_driver]: [NitrosNode] Calling user’s post-load-graph callback
[component_container_mt-1] [INFO] [1716475165.103191200] [correlated_timestamp_driver]: [NitrosContext] Initializing application…
[component_container_mt-1] [INFO] [1716475165.105397568] [correlated_timestamp_driver]: [NitrosContext] Running application…
[component_container_mt-1] [INFO] [1716475165.105568096] [correlated_timestamp_driver]: [NitrosNode] Starting a heartbeat timer (eid=22)
[component_container_mt-1] [1;31m2024-05-23 22:39:25.105 ERROR extensions/timestamp_correlator/correlated_timestamp_driver.cpp@61: ioctl failed for NVPPS_GETTIMESTAMP err Invalid argument
[component_container_mt-1] [0m
here is the install log
bst@Orin-AGX-A11:~/ros/nova_orin_v1.2.0-5$ sudo apt install ./nova-orin-init_*_arm64.deb
Reading package lists… Done
Building dependency tree
Reading state information… Done
Note, selecting ‘nova-orin-init’ instead of ‘./nova-orin-init_1.2.0-1_arm64.deb’
nova-orin-init is already the newest version (1.2.0).
The following packages were automatically installed and are no longer required:
apt-clone archdetect-deb bogl-bterm cryptsetup-bin dctrl-tools dpkg-repack gir1.2-goa-1.0 gir1.2-timezonemap-1.0 gir1.2-xkl-1.0 grub-common libavresample-dev libavresample4 libdc1394-22-dev
libdebian-installer4 libexif-dev libgdcm-dev libgphoto2-dev libilmbase-dev libopencv4.2-java libopencv4.2-jni libopenexr-dev libpaps0 libraw1394-dev libtimezonemap-data libtimezonemap1 os-prober
paps python3-icu python3-pam rdate tasksel tasksel-data
Use ‘sudo apt autoremove’ to remove them.
0 upgraded, 0 newly installed, 0 to remove and 226 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] Y
Setting up nova-orin-init (1.2.0) …
Finishing up nova-orin-init setup…
Setting up nova-orin-init python venv…
Obtaining file:///opt/nvidia/nova/python/nova-init-py
Installing build dependencies … done
Getting requirements to build wheel … done
Preparing wheel metadata … done
Requirement already satisfied: pytest-timeout in /opt/nvidia/nova/python/venv/lib/python3.8/site-packages (from nova_init==0.0.1) (2.3.1)
Requirement already satisfied: pystemd in /opt/nvidia/nova/python/venv/lib/python3.8/site-packages (from nova_init==0.0.1) (0.13.2)
Requirement already satisfied: numpy in /opt/nvidia/nova/python/venv/lib/python3.8/site-packages (from nova_init==0.0.1) (1.24.4)
Requirement already satisfied: pytest in /opt/nvidia/nova/python/venv/lib/python3.8/site-packages (from nova_init==0.0.1) (8.2.1)
Requirement already satisfied: requests in /opt/nvidia/nova/python/venv/lib/python3.8/site-packages (from nova_init==0.0.1) (2.32.2)
Requirement already satisfied: pandas in /opt/nvidia/nova/python/venv/lib/python3.8/site-packages (from nova_init==0.0.1) (2.0.3)
Requirement already satisfied: pyyaml in /opt/nvidia/nova/python/venv/lib/python3.8/site-packages (from nova_init==0.0.1) (6.0.1)
Requirement already satisfied: lxml in /opt/nvidia/nova/python/venv/lib/python3.8/site-packages (from pystemd->nova_init==0.0.1) (5.2.2)
Requirement already satisfied: psutil in /opt/nvidia/nova/python/venv/lib/python3.8/site-packages (from pystemd->nova_init==0.0.1) (5.9.8)
Requirement already satisfied: tomli>=1; python_version < “3.11” in /opt/nvidia/nova/python/venv/lib/python3.8/site-packages (from pytest->nova_init==0.0.1) (2.0.1)
Requirement already satisfied: packaging in /opt/nvidia/nova/python/venv/lib/python3.8/site-packages (from pytest->nova_init==0.0.1) (24.0)
Requirement already satisfied: iniconfig in /opt/nvidia/nova/python/venv/lib/python3.8/site-packages (from pytest->nova_init==0.0.1) (2.0.0)
Requirement already satisfied: pluggy<2.0,>=1.5 in /opt/nvidia/nova/python/venv/lib/python3.8/site-packages (from pytest->nova_init==0.0.1) (1.5.0)
Requirement already satisfied: exceptiongroup>=1.0.0rc8; python_version < “3.11” in /opt/nvidia/nova/python/venv/lib/python3.8/site-packages (from pytest->nova_init==0.0.1) (1.2.1)
Requirement already satisfied: certifi>=2017.4.17 in /opt/nvidia/nova/python/venv/lib/python3.8/site-packages (from requests->nova_init==0.0.1) (2024.2.2)
Requirement already satisfied: charset-normalizer<4,>=2 in /opt/nvidia/nova/python/venv/lib/python3.8/site-packages (from requests->nova_init==0.0.1) (3.3.2)
Requirement already satisfied: urllib3<3,>=1.21.1 in /opt/nvidia/nova/python/venv/lib/python3.8/site-packages (from requests->nova_init==0.0.1) (2.2.1)
Requirement already satisfied: idna<4,>=2.5 in /opt/nvidia/nova/python/venv/lib/python3.8/site-packages (from requests->nova_init==0.0.1) (3.7)
Requirement already satisfied: tzdata>=2022.1 in /opt/nvidia/nova/python/venv/lib/python3.8/site-packages (from pandas->nova_init==0.0.1) (2024.1)
Requirement already satisfied: pytz>=2020.1 in /opt/nvidia/nova/python/venv/lib/python3.8/site-packages (from pandas->nova_init==0.0.1) (2024.1)
Requirement already satisfied: python-dateutil>=2.8.2 in /opt/nvidia/nova/python/venv/lib/python3.8/site-packages (from pandas->nova_init==0.0.1) (2.9.0.post0)
Requirement already satisfied: six>=1.5 in /opt/nvidia/nova/python/venv/lib/python3.8/site-packages (from python-dateutil>=2.8.2->pandas->nova_init==0.0.1) (1.16.0)
Installing collected packages: nova-init
Attempting uninstall: nova-init
Found existing installation: nova-init 0.0.1
Uninstalling nova-init-0.0.1:
Successfully uninstalled nova-init-0.0.1
Running setup.py develop for nova-init
Successfully installed nova-init
Requirement already satisfied: pandas in /opt/nvidia/nova/python/venv/lib/python3.8/site-packages (from -r /opt/nvidia/nova/python/nova-init-py/requirements.txt (line 1)) (2.0.3)
Requirement already satisfied: requests in /opt/nvidia/nova/python/venv/lib/python3.8/site-packages (from -r /opt/nvidia/nova/python/nova-init-py/requirements.txt (line 2)) (2.32.2)
Requirement already satisfied: numpy in /opt/nvidia/nova/python/venv/lib/python3.8/site-packages (from -r /opt/nvidia/nova/python/nova-init-py/requirements.txt (line 3)) (1.24.4)
Requirement already satisfied: pytest in /opt/nvidia/nova/python/venv/lib/python3.8/site-packages (from -r /opt/nvidia/nova/python/nova-init-py/requirements.txt (line 4)) (8.2.1)
Requirement already satisfied: pystemd in /opt/nvidia/nova/python/venv/lib/python3.8/site-packages (from -r /opt/nvidia/nova/python/nova-init-py/requirements.txt (line 5)) (0.13.2)
Requirement already satisfied: pyyaml in /opt/nvidia/nova/python/venv/lib/python3.8/site-packages (from -r /opt/nvidia/nova/python/nova-init-py/requirements.txt (line 6)) (6.0.1)
Requirement already satisfied: pytest-timeout in /opt/nvidia/nova/python/venv/lib/python3.8/site-packages (from -r /opt/nvidia/nova/python/nova-init-py/requirements.txt (line 7)) (2.3.1)
Requirement already satisfied: python-dateutil>=2.8.2 in /opt/nvidia/nova/python/venv/lib/python3.8/site-packages (from pandas->-r /opt/nvidia/nova/python/nova-init-py/requirements.txt (line 1)) (2.9
.0.post0)
Requirement already satisfied: pytz>=2020.1 in /opt/nvidia/nova/python/venv/lib/python3.8/site-packages (from pandas->-r /opt/nvidia/nova/python/nova-init-py/requirements.txt (line 1)) (2024.1)
Requirement already satisfied: tzdata>=2022.1 in /opt/nvidia/nova/python/venv/lib/python3.8/site-packages (from pandas->-r /opt/nvidia/nova/python/nova-init-py/requirements.txt (line 1)) (2024.1)
Requirement already satisfied: urllib3<3,>=1.21.1 in /opt/nvidia/nova/python/venv/lib/python3.8/site-packages (from requests->-r /opt/nvidia/nova/python/nova-init-py/requirements.txt (line 2)) (2.2.1
Requirement already satisfied: certifi>=2017.4.17 in /opt/nvidia/nova/python/venv/lib/python3.8/site-packages (from requests->-r /opt/nvidia/nova/python/nova-init-py/requirements.txt (line 2)) (2024.
2.2)
Requirement already satisfied: idna<4,>=2.5 in /opt/nvidia/nova/python/venv/lib/python3.8/site-packages (from requests->-r /opt/nvidia/nova/python/nova-init-py/requirements.txt (line 2)) (3.7)
Requirement already satisfied: charset-normalizer<4,>=2 in /opt/nvidia/nova/python/venv/lib/python3.8/site-packages (from requests->-r /opt/nvidia/nova/python/nova-init-py/requirements.txt (line 2))
(3.3.2)
Requirement already satisfied: tomli>=1; python_version < “3.11” in /opt/nvidia/nova/python/venv/lib/python3.8/site-packages (from pytest->-r /opt/nvidia/nova/python/nova-init-py/requirements.txt (li
ne 4)) (2.0.1)
Requirement already satisfied: exceptiongroup>=1.0.0rc8; python_version < “3.11” in /opt/nvidia/nova/python/venv/lib/python3.8/site-packages (from pytest->-r /opt/nvidia/nova/python/nova-init-py/requ
irements.txt (line 4)) (1.2.1)
Requirement already satisfied: packaging in /opt/nvidia/nova/python/venv/lib/python3.8/site-packages (from pytest->-r /opt/nvidia/nova/python/nova-init-py/requirements.txt (line 4)) (24.0)
Requirement already satisfied: iniconfig in /opt/nvidia/nova/python/venv/lib/python3.8/site-packages (from pytest->-r /opt/nvidia/nova/python/nova-init-py/requirements.txt (line 4)) (2.0.0)
Requirement already satisfied: pluggy<2.0,>=1.5 in /opt/nvidia/nova/python/venv/lib/python3.8/site-packages (from pytest->-r /opt/nvidia/nova/python/nova-init-py/requirements.txt (line 4)) (1.5.0)
Requirement already satisfied: lxml in /opt/nvidia/nova/python/venv/lib/python3.8/site-packages (from pystemd->-r /opt/nvidia/nova/python/nova-init-py/requirements.txt (line 5)) (5.2.2)
Requirement already satisfied: psutil in /opt/nvidia/nova/python/venv/lib/python3.8/site-packages (from pystemd->-r /opt/nvidia/nova/python/nova-init-py/requirements.txt (line 5)) (5.9.8)
Requirement already satisfied: six>=1.5 in /opt/nvidia/nova/python/venv/lib/python3.8/site-packages (from python-dateutil>=2.8.2->pandas->-r /opt/nvidia/nova/python/nova-init-py/requirements.txt (lin
e 1)) (1.16.0)
Attempting to setup compute…
Attempting to setup logrotate…
main()
setup_manager.run()
raise ValueError(
nova-orin-init
E: Sub-process /usr/bin/dpkg returned an error code (1)
Which Jetpack are you using?
Isaac ROS 2.0 works with Jetpack 5.1.2
Please ensure all requirements are verified: Getting Started — isaac_ros_docs documentation
Hi Raff
Thanks for your comment
Here I used the jet pack 5.12.
To fix your issue you can execute this code:
sudo apt remove nova-orin-init
# check that rsyslog is not empty
cat /etc/logrotate.d/rsyslog.nova.disabled
# recover the backed up file manually
mv /etc/logrotate.d/rsyslog.nova.disabled /etc/logrotate.d/rsyslog
And after reinstall again Nova Orin Init
Should be fix your issue, otherwise let me know.
Best,
Raffaello
hi Raffaello
thanks very much for your comment
here i reinstall the Nova Orin Init again, and make sure it install successfully.
it still have the error message,
i found the iio devices have four bmi088
iio:device0 iio:device1 iio:device2 iio:device3
and I reconfig the DTS for P3762_A03,
it show two device of bmi088
this error message gone
but i met new issue, this test can get the raw data from the bmi088, but only run a few ms, it show this message.
[component_container_mt-1] [INFO] [0000002497.932525826] [bmi088]: [NitrosNode] Terminating the running application
[component_container_mt-1] [INFO] [0000002497.932553634] [bmi088]: [NitrosContext] Interrupting GXF…
[component_container_mt-1] 1970-01-01 08:41:37.953 ERROR /workspaces/isaac_ros-dev/src/isaac_ros_nova/isaac_ros_imu_bmi088/gxf/bmi088_imu/extensions/bmi088_imu/bmi088_driver.cpp@387: Failed to disable channels
[component_container_mt-1] 1970-01-01 08:41:37.973 ERROR /workspaces/isaac_ros-dev/src/isaac_ros_nova/isaac_ros_imu_bmi088/gxf/bmi088_imu/extensions/bmi088_imu/bmi088_driver.cpp@387: Failed to disable channels
[component_container_mt-1] [INFO] [0000002497.974427715] [bmi088]: [NitrosContext] Waiting on GXF…
[component_container_mt-1] [INFO] [0000002497.974461187] [bmi088]: [NitrosContext] Deinitializing…
[INFO] [component_container_mt-1]: process started with pid [10973]
[component_container_mt-1] [INFO] [0000002495.769744025] [bmi088_container]: Load Library: /workspaces/isaac_ros-dev/install/isaac_ros_correlated_timestamp_driver/lib/libcorrelated_timestamp_driver_node.so
[component_container_mt-1] [INFO] [0000002495.827935802] [bmi088_container]: Found class: rclcpp_components::NodeFactoryTemplatenvidia::isaac_ros::correlated_timestamp_driver::CorrelatedTimestampDriverNode
[component_container_mt-1] [INFO] [0000002495.828011642] [bmi088_container]: Instantiate class: rclcpp_components::NodeFactoryTemplatenvidia::isaac_ros::correlated_timestamp_driver::CorrelatedTimestampDriverNode
[component_container_mt-1] [INFO] [0000002495.833360154] [NitrosContext]: [NitrosContext] Creating a new shared context
[component_container_mt-1] [INFO] [0000002495.833521306] [correlated_timestamp_driver]: [NitrosNode] Initializing NitrosNode
[component_container_mt-1] [INFO] [0000002495.834727450] [NitrosContext]: [NitrosContext] Loading extension: gxf/lib/std/libgxf_std.so
[component_container_mt-1] [INFO] [0000002495.846760955] [NitrosContext]: [NitrosContext] Loading extension: gxf/lib/libgxf_gxf_helpers.so
[component_container_mt-1] [INFO] [0000002495.854684667] [NitrosContext]: [NitrosContext] Loading extension: gxf/lib/libgxf_sight.so
[component_container_mt-1] [INFO] [0000002495.863646875] [NitrosContext]: [NitrosContext] Loading extension: gxf/lib/libgxf_atlas.so
[component_container_mt-1] [INFO] [0000002495.873226203] [NitrosContext]: [NitrosContext] Loading application: ‘/workspaces/isaac_ros-dev/install/isaac_ros_nitros/share/isaac_ros_nitros/config/type_adapter_nitros_context_graph.yaml’
[component_container_mt-1] [INFO] [0000002495.875108667] [NitrosContext]: [NitrosContext] Initializing application…
[component_container_mt-1] [INFO] [0000002495.878644443] [NitrosContext]: [NitrosContext] Running application…
[component_container_mt-1] 1970-01-01 08:41:35.878 WARN gxf/std/program.cpp@514: No system specified. Nothing to do
[component_container_mt-1] [INFO] [0000002495.879773435] [correlated_timestamp_driver]: [NitrosNode] Starting NitrosNode
[component_container_mt-1] [INFO] [0000002495.879809755] [correlated_timestamp_driver]: [NitrosNode] Loading built-in preset extension specs
[component_container_mt-1] [INFO] [0000002495.882317243] [correlated_timestamp_driver]: [NitrosNode] Loading built-in extension specs
[component_container_mt-1] [INFO] [0000002495.882359803] [correlated_timestamp_driver]: [NitrosNode] Loading preset extension specs
[component_container_mt-1] [INFO] [0000002495.882653435] [correlated_timestamp_driver]: [NitrosNode] Loading extension specs
[component_container_mt-1] [INFO] [0000002495.882672219] [correlated_timestamp_driver]: [NitrosNode] Loading generator rules
[component_container_mt-1] [INFO] [0000002495.882682811] [correlated_timestamp_driver]: [NitrosNode] Loading extensions
[component_container_mt-1] [INFO] [0000002495.883074171] [correlated_timestamp_driver]: [NitrosContext] Loading extension: gxf/lib/libgxf_message_compositor.so
[component_container_mt-1] [INFO] [0000002495.884584571] [correlated_timestamp_driver]: [NitrosContext] Loading extension: gxf/lib/libgxf_timestamp_correlator.so
[component_container_mt-1] [INFO] [0000002495.893949307] [NitrosContext]: [NitrosContext] Loading extension: gxf/lib/serialization/libgxf_serialization.so
[component_container_mt-1] [INFO] [0000002495.902999420] [NitrosContext]: [NitrosContext] Loading extension: gxf/lib/libgxf_isaac_messages.so
[component_container_mt-1] [INFO] [0000002495.905389532] [correlated_timestamp_driver]: [NitrosNode] Loading graph to the optimizer
[component_container_mt-1] [INFO] [0000002495.906858780] [correlated_timestamp_driver]: [NitrosNode] Running optimization
[component_container_mt-1] [INFO] [0000002495.908045340] [correlated_timestamp_driver]: [NitrosNode] Obtaining graph IO group info from the optimizer
[component_container_mt-1] [INFO] [0000002495.908603676] [correlated_timestamp_driver]: [NitrosNode] Creating negotiated publishers/subscribers
[component_container_mt-1] [INFO] [0000002495.921360348] [correlated_timestamp_driver]: [NitrosNode] Starting negotiation…
[component_container_mt-1] [INFO] [0000002495.924703932] [bmi088_container]: Load Library: /workspaces/isaac_ros-dev/install/isaac_ros_imu_bmi088/lib/libimu_bmi088_node.so
[component_container_mt-1] [INFO] [0000002495.934244828] [bmi088_container]: Found class: rclcpp_components::NodeFactoryTemplatenvidia::isaac_ros::imu_bmi088::Bmi088Node
[component_container_mt-1] [INFO] [0000002495.934300732] [bmi088_container]: Instantiate class: rclcpp_components::NodeFactoryTemplatenvidia::isaac_ros::imu_bmi088::Bmi088Node
[component_container_mt-1] [INFO] [0000002495.939082268] [bmi088]: [NitrosNode] Initializing NitrosNode
[component_container_mt-1] [INFO] [0000002495.940002716] [bmi088]: [NitrosNode] Starting NitrosNode
[component_container_mt-1] [INFO] [0000002495.940038172] [bmi088]: [NitrosNode] Loading built-in preset extension specs
[component_container_mt-1] [INFO] [0000002495.942083548] [bmi088]: [NitrosNode] Loading built-in extension specs
[component_container_mt-1] [INFO] [0000002495.942139324] [bmi088]: [NitrosNode] Loading preset extension specs
[component_container_mt-1] [INFO] [0000002495.943022012] [bmi088]: [NitrosNode] Loading extension specs
[component_container_mt-1] [INFO] [0000002495.943066268] [bmi088]: [NitrosNode] Loading generator rules
[component_container_mt-1] [INFO] [0000002495.943498908] [bmi088]: [NitrosNode] Loading extensions
[component_container_mt-1] [INFO] [0000002495.944408092] [bmi088]: [NitrosContext] Loading extension: gxf/lib/bmi088_imu/libgxf_bmi088_imu.so
[component_container_mt-1] [INFO] [0000002495.953714237] [bmi088]: [NitrosContext] Loading extension: gxf/lib/imu_utils/libgxf_imu_utils.so
[component_container_mt-1] [INFO] [0000002495.959186205] [bmi088]: [NitrosNode] Loading graph to the optimizer
[component_container_mt-1] [INFO] [0000002495.962997085] [bmi088]: [NitrosNode] Running optimization
[component_container_mt-1] [INFO] [0000002495.991672221] [bmi088]: [NitrosNode] Obtaining graph IO group info from the optimizer
[component_container_mt-1] [INFO] [0000002495.992853373] [bmi088]: [NitrosNode] Creating negotiated publishers/subscribers
[component_container_mt-1] [INFO] [0000002496.008988221] [bmi088]: [NitrosNode] Starting negotiation…
[component_container_mt-1] [INFO] [0000002496.009668702] [correlated_timestamp_driver]: Negotiating
[component_container_mt-1] [INFO] [0000002496.922079363] [correlated_timestamp_driver]: [NitrosNode] Starting post negotiation setup
[component_container_mt-1] [INFO] [0000002496.922154659] [correlated_timestamp_driver]: [NitrosNode] Getting data format negotiation results
[component_container_mt-1] [INFO] [0000002496.922177539] [correlated_timestamp_driver]: [NitrosPublisher] Use the negotiated data format: “nitros_correlated_timestamp”
[component_container_mt-1] [INFO] [0000002496.922706179] [correlated_timestamp_driver]: [NitrosNode] Exporting the final graph based on the negotiation results
[component_container_mt-1] [INFO] [0000002496.924727491] [correlated_timestamp_driver]: [NitrosNode] Wrote the final top level YAML graph to “/tmp/isaac_ros_nitros/graphs/OUBRJHCCCX/OUBRJHCCCX.yaml”
[component_container_mt-1] [INFO] [0000002496.924776195] [correlated_timestamp_driver]: [NitrosNode] Calling user’s pre-load-graph callback
[component_container_mt-1] [INFO] [0000002496.924790339] [correlated_timestamp_driver]: [NitrosNode] Loading application
[component_container_mt-1] [INFO] [0000002496.924803811] [correlated_timestamp_driver]: [NitrosContext] Loading application: ‘/tmp/isaac_ros_nitros/graphs/OUBRJHCCCX/OUBRJHCCCX.yaml’
[component_container_mt-1] [INFO] [0000002496.926576227] [correlated_timestamp_driver]: [NitrosNode] Linking Nitros pub/sub to the loaded application
[component_container_mt-1] [INFO] [0000002496.926775139] [correlated_timestamp_driver]: [NitrosNode] Calling user’s post-load-graph callback
[component_container_mt-1] [INFO] [0000002496.926839491] [correlated_timestamp_driver]: [NitrosContext] Initializing application…
[component_container_mt-1] [INFO] [0000002496.929166339] [correlated_timestamp_driver]: [NitrosContext] Running application…
[component_container_mt-1] [INFO] [0000002496.929429411] [correlated_timestamp_driver]: [NitrosNode] Starting a heartbeat timer (eid=22)
[component_container_mt-1] 1970-01-01 08:41:36.929 ERROR extensions/timestamp_correlator/correlated_timestamp_driver.cpp@75: failed to open the device /dev/nvpps0 errno = 2
[component_container_mt-1] 1970-01-01 08:41:36.929 ERROR gxf/std/entity_executor.cpp@563: Entity [OUBRJHCCCX_correlator] must be in Started, Tick Pending, Ticking or Idle stage before stopping. Current state is StartPending
[component_container_mt-1] 1970-01-01 08:41:36.929 WARN gxf/std/greedy_scheduler.cpp@250: Error while executing entity 17 named ‘OUBRJHCCCX_correlator’: GXF_FAILURE
[component_container_mt-1] [INFO] [0000002497.009603716] [bmi088]: [NitrosNode] Starting post negotiation setup
[component_container_mt-1] [INFO] [0000002497.009665092] [bmi088]: [NitrosNode] Getting data format negotiation results
[component_container_mt-1] [INFO] [0000002497.009680068] [bmi088]: [NitrosPublisher] Negotiation ended with no results
[component_container_mt-1] [INFO] [0000002497.009693892] [bmi088]: [NitrosPublisher] Use only the compatible publisher: topic_name=“/imu”, data_format=“nitros_imu”
[component_container_mt-1] [INFO] [0000002497.009712132] [bmi088]: [NitrosSubscriber] Use the negotiated data format: “nitros_correlated_timestamp”
[component_container_mt-1] [INFO] [0000002497.009915300] [bmi088]: [NitrosNode] Exporting the final graph based on the negotiation results
[component_container_mt-1] [INFO] [0000002497.015946916] [bmi088]: [NitrosNode] Wrote the final top level YAML graph to “/tmp/isaac_ros_nitros/graphs/XLTYNSNZSF/XLTYNSNZSF.yaml”
[component_container_mt-1] [INFO] [0000002497.015998436] [bmi088]: [NitrosNode] Calling user’s pre-load-graph callback
[component_container_mt-1] [INFO] [0000002497.016011748] [bmi088]: [NitrosNode] Loading application
[component_container_mt-1] [INFO] [0000002497.016025380] [bmi088]: [NitrosContext] Loading application: ‘/tmp/isaac_ros_nitros/graphs/XLTYNSNZSF/XLTYNSNZSF.yaml’
[component_container_mt-1] [INFO] [0000002497.020283908] [bmi088]: [NitrosNode] Linking Nitros pub/sub to the loaded application
[component_container_mt-1] [INFO] [0000002497.020416356] [bmi088]: [NitrosNode] Calling user’s post-load-graph callback
[component_container_mt-1] [INFO] [0000002497.020476004] [bmi088]: [NitrosContext] Initializing application…
[component_container_mt-1] [INFO] [0000002497.026359460] [bmi088]: [NitrosContext] Running application…
[component_container_mt-1] [INFO] [0000002497.026648228] [bmi088]: [NitrosNode] Starting a heartbeat timer (eid=65)
[component_container_mt-1] 1970-01-01 08:41:37.079 ERROR /workspaces/isaac_ros-dev/src/isaac_ros_nova/isaac_ros_imu_bmi088/gxf/bmi088_imu/extensions/bmi088_imu/bmi088_driver.cpp@441: gyro data 671091648 -2147483648 0
[component_container_mt-1] 1970-01-01 08:41:37.088 ERROR /workspaces/isaac_ros-dev/src/isaac_ros_nova/isaac_ros_imu_bmi088/gxf/bmi088_imu/extensions/bmi088_imu/bmi088_driver.cpp@441: gyro data 536911120 -2147483648 -2147483648
[component_container_mt-1] 1970-01-01 08:41:37.098 ERROR /workspaces/isaac_ros-dev/src/isaac_ros_nova/isaac_ros_imu_bmi088/gxf/bmi088_imu/extensions/bmi088_imu/bmi088_driver.cpp@441: gyro data 671509184 -2147483648 0
[component_container_mt-1] 1970-01-01 08:41:37.108 ERROR /workspaces/isaac_ros-dev/src/isaac_ros_nova/isaac_ros_imu_bmi088/gxf/bmi088_imu/extensions/bmi088_imu/bmi088_driver.cpp@441: gyro data 536912544 -2147483648 0
[component_container_mt-1] 1970-01-01 08:41:37.110 ERROR /workspaces/isaac_ros-dev/src/isaac_ros_nova/isaac_ros_imu_bmi088/gxf/bmi088_imu/extensions/bmi088_imu/bmi088_driver.cpp@412: acc data 1048553736 -2147483648 -2147483648
[component_container_mt-1] 1970-01-01 08:41:37.118 ERROR /workspaces/isaac_ros-dev/src/isaac_ros_nova/isaac_ros_imu_bmi088/gxf/bmi088_imu/extensions/bmi088_imu/bmi088_driver.cpp@441: gyro data 536911120 -2147483648 0
[component_container_mt-1] 1970-01-01 08:41:37.120 ERROR /workspaces/isaac_ros-dev/src/isaac_ros_nova/isaac_ros_imu_bmi088/gxf/bmi088_imu/extensions/bmi088_imu/bmi088_driver.cpp@412: acc data 1048553736 -2147483648 0
[component_container_mt-1] 1970-01-01 08:41:37.128 ERROR /workspaces/isaac_ros-dev/src/isaac_ros_nova/isaac_ros_imu_bmi088/gxf/bmi088_imu/extensions/bmi088_imu/bmi088_driver.cpp@441: gyro data 671091648 0 0
[component_container_mt-1] 1970-01-01 08:41:37.130 ERROR /workspaces/isaac_ros-dev/src/isaac_ros_nova/isaac_ros_imu_bmi088/gxf/bmi088_imu/extensions/bmi088_imu/bmi088_driver.cpp@412: acc data 1040161032 1073741824 -2147483648
[component_container_mt-1] 1970-01-01 08:41:37.138 ERROR /workspaces/isaac_ros-dev/src/isaac_ros_nova/isaac_ros_imu_bmi088/gxf/bmi088_imu/extensions/bmi088_imu/bmi088_driver.cpp@441: gyro data 671108800 0 0
[component_container_mt-1] 1970-01-01 08:41:37.140 ERROR /workspaces/isaac_ros-dev/src/isaac_ros_nova/isaac_ros_imu_bmi088/gxf/bmi088_imu/extensions/bmi088_imu/bmi088_driver.cpp@412: acc data 1040161032 536870912 1610612736
[component_container_mt-1] 1970-01-01 08:41:37.148 ERROR /workspaces/isaac_ros-dev/src/isaac_ros_nova/isaac_ros_imu_bmi088/gxf/bmi088_imu/extensions/bmi088_imu/bmi088_driver.cpp@441: gyro data 671111632 -2147483648 0
[component_container_mt-1] 1970-01-01 08:41:37.150 ERROR /workspaces/isaac_ros-dev/src/isaac_ros_nova/isaac_ros_imu_bmi088/gxf/bmi088_imu/extensions/bmi088_imu/bmi088_driver.cpp@412: acc data 1040161032 -1073741824 -2147483648
[component_container_mt-1] 1970-01-01 08:41:37.158 ERROR /workspaces/isaac_ros-dev/src/isaac_ros_nova/isaac_ros_imu_bmi088/gxf/bmi088_imu/extensions/bmi088_imu/bmi088_driver.cpp@441: gyro data 536877712 -2147483648 -2147483648
[component_container_mt-1] 1970-01-01 08:41:37.780 WARN /workspaces/isaac_ros-dev/src/isaac_ros_nova/isaac_ros_imu_bmi088/gxf/bmi088_imu/extensions/bmi088_imu/bmi088_driver.hpp@87: RingBufferQueue overflowed! Dropped 1 values
[component_container_mt-1] 1970-01-01 08:41:37.799 WARN /workspaces/isaac_ros-dev/src/isaac_ros_nova/isaac_ros_imu_bmi088/gxf/bmi088_imu/extensions/bmi088_imu/bmi088_driver.hpp@87: RingBufferQueue overflowed! Dropped 1 values
[component_container_mt-1] 1970-01-01 08:41:37.929 ERROR gxf/std/entity_executor.cpp@210: Entity with eid 22 not found!
[component_container_mt-1] [WARN] [0000002497.929661762] [correlated_timestamp_driver]: [NitrosNode] The heartbeat entity (eid=22) was stopped. The graph may have been terminated.
[component_container_mt-1] | XLTYNSNZSF_accel_translator | 18752 | 0.03 | 0.04 | 0.17 | 62.9 % | 491.3 | 360482989 | 638026680 | 781068861 |
[component_container_mt-1] | XLTYNSNZSF_gyro_translator | 19872 | 0.02 | 0.03 | 0.38 | 62.0 % | 504.4 | 350904173 | 621598999 | 813193182 |
[component_container_mt-1] | XLTYNSNZSF_bmi088_driver | 14 | 0.17 | 0.28 | 0.49 | 3.9 % | 3.1 | 0 | 0 | 0 |
[component_container_mt-1] | XLTYNSNZSF_accel_transl | StopPending | 1 | 0.00355 | 0.00355 | 0.00355 |
[component_container_mt-1] | XLTYNSNZSF_accel_transl | Idle | 18752 | 0.02106 | 0.02506 | 41.17350 |
[component_container_mt-1] | XLTYNSNZSF_accel_transl | Ticking | 18752 | 0.00864 | 0.01232 | 0.14410 |
[component_container_mt-1] | XLTYNSNZSF_accel_transl | Pending | 18752 | 0.00723 | 0.01370 | 0.04269 |
[component_container_mt-1] | XLTYNSNZSF_gyro_transla | StopPending | 1 | 0.00314 | 0.00314 | 0.00314 |
[component_container_mt-1] | XLTYNSNZSF_gyro_transla | Idle | 19872 | 0.02259 | 0.02512 | 41.19232 |
[component_container_mt-1] | XLTYNSNZSF_gyro_transla | Ticking | 19872 | 0.00886 | 0.01306 | 0.33818 |
[component_container_mt-1] | XLTYNSNZSF_gyro_transla | Pending | 19872 | 0.00659 | 0.01475 | 0.17222 |
[component_container_mt-1] [INFO] [0000002497.975454340] [bmi088]: [NitrosContext] Destroying context
[component_container_mt-1] [INFO] [0000002497.976114436] [bmi088]: [NitrosNode] Application termination done
[component_container_mt-1] [INFO] [0000002497.981089028] [correlated_timestamp_driver]: [NitrosNode] Terminating the running application
[component_container_mt-1] [INFO] [0000002497.981114308] [correlated_timestamp_driver]: [NitrosContext] Interrupting GXF…
[component_container_mt-1] [INFO] [0000002497.981133220] [correlated_timestamp_driver]: [NitrosContext] Waiting on GXF…
[component_container_mt-1] 1970-01-01 08:41:37.981 ERROR gxf/std/program.cpp@556: wait failed. Deactivating…
[component_container_mt-1] 1970-01-01 08:41:37.981 ERROR gxf/core/runtime.cpp@1408: Graph wait failed with error: GXF_FAILURE
[component_container_mt-1] [ERROR] [0000002497.981384932] [correlated_timestamp_driver]: [NitrosContext] GxfGraphWait Error: GXF_FAILURE
[component_container_mt-1] [INFO] [0000002497.981391140] [correlated_timestamp_driver]: [NitrosNode] Application termination done
[component_container_mt-1] | XLTYNSNZSF_bmi088_drive | StopPending | 1 | 41.05994 | 41.05994 | 41.05994 |
[component_container_mt-1] | XLTYNSNZSF_bmi088_drive | Idle | 14 | 8.07664 | 9.74806 | 773.66217 |
[component_container_mt-1] | XLTYNSNZSF_bmi088_drive | Ticking | 14 | 0.15760 | 0.25389 | 0.43446 |
[component_container_mt-1] | XLTYNSNZSF_bmi088_drive | Pending | 14 | 0.00934 | 0.01146 | 0.02362 |
[INFO] [component_container_mt-1]: process has finished cleanly [pid 10973]
admin@Orin-AGX-A11:/workspaces/isaac_ros-dev$
From the error message, it seems like NVPPS is failing. I’d recommend them to run the PFC with
nova_preflight_checker -v
If there are any errors, please reply with the PFC log/output in a file.
NVPPS typically fails when PTP4L is not running since it requires a PTP server to synchronize time. PTP4L is checked by the PFC. You can manually check it by running:
systemctl status ptp4l
If it has failed or is not running, try to restart it with:
sudo systemctl restart ptp4l
To further debug please provide the journalctl log as a file:
journalctl > journalctl.log
hi Raffaello
thanks for your comment
here in my Orin , the bmi088 address is the 0x69.
after i install the nova-orin-init
it have the bmi088 i2c address 0x68,
lrwxrwxrwx 1 root root 0 Nov 22 2023 iio:device0 → …/…/…/devices/platform/31e0000.i2c/i2c-8/i2c-9/9-0069/iio:device0
lrwxrwxrwx 1 root root 0 Nov 22 2023 iio:device1 → …/…/…/devices/platform/31e0000.i2c/i2c-8/i2c-9/9-0069/iio:device1
but always print the log,
after i reconfig the P3762, the wrong message gone.
here i attache the log of systemctl status ptp4l.txt nova_preflight_checker -v.txt journalctl.log
journalctl.log (717.5 KB)
systemctl status ptp4l.txt (1.2 KB)
nova_preflight_checker -v.txt (9.8 KB)
Thank you @543773044
We released few hours ago the new Isaac ROS 3.0 release with major fixes on Isaac ROS Nova,
There is now a new quickstart that better can help you to work with this package:
https://nvidia-isaac-ros.github.io/repositories_and_packages/isaac_ros_nova/isaac_ros_imu_bmi088/index.html#quickstart
hi Raffaello
thanks for your comment.
two doubts from my side,
1 Does the Isaac3.0 only support the Jetpack6.0 not support 5.1.2?
2 Does the Jetpack6 support P3762?
thanks
martin
Hi @543773044
Isaac ROS 3.0 only supports Jetpack 6.0. The new requirements are available on this page. Getting Started — isaac_ros_docs documentation
Platform Hardware Software Notes
Jetson Jetson Orin JetPack 6.0 For best performance, ensure that power settings are configured appropriately.
x86_64 Ampere or higher NVIDIA GPU Architecture with 8 GB RAM or higher Ubuntu 22.04+ CUDA 12.2+
Yes, support the HAWK P3762, follow the new documentation at this page: Isaac ROS Hawk Setup — isaac_ros_docs documentation
hi Raffaello
thanks very much for your great help.
we can close this ticket.
