Hi @Raffaello , thanks for the reply, yes I had deleted my build install and log directories before running colcon build. I was able to fix this issue by completely re-flashing my Orin Nano with the SDKmanager, and now I can successfully build the packages in isaac_ros_common, isaac_ros_nitros, and other packages such as isaac_ros_visual_slam and isaac_ros_object_detection. However, I am still having a VPI-related issue with isaac_ros_image_proc specifically (all the other packages in isaac_ros_image_pipeline can build successfully), the error seems to be related to cupva which is strange since the Orin Nano does not have PVA cores:
Starting >>> isaac_ros_image_proc
[Processing: isaac_ros_image_proc]
--- stderr: isaac_ros_image_proc
/usr/bin/ld: warning: libcupva_host.so.2.3, needed by /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libcupva_host_utils.so.2.3, needed by /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9, not found (try using -rpath or -rpath-link)
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::StaticDataFlow::granularity(cupva::GranType)'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::StaticDataFlow::dstDim1(int, int)'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::ConfigDataFlow::id() const'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::RasterDataFlow::srcImpl(void const*, int, int, int, int)'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::Fence::timestamp() const'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::Fence::Fence(cupva::SyncObj&)'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::RasterDataFlow::roi(int, int, int, int)'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::CmdWaitOnFences::~CmdWaitOnFences()'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::Fence::wait(long) const'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::RasterDataFlow::dstImpl(void*, int, int, int, int)'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::Executable::~Executable()'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::StaticDataFlow::handler(cupva::Parameter const&)'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::Context::~Context()'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::SyncObj::Create(bool, cupva::SyncClientType, cupva::SyncWaitMode)'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::CmdProgram::CmdProgram()'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::Stream::~Stream()'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::DynamicDataFlow::Node::bpp(int)'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::RasterDataFlow::link(cupva::RasterDataFlow&)'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::Exception::getErrorCode() const'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::DynamicDataFlow::~DynamicDataFlow()'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::Context::Context()'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::StaticDataFlow::tile(int, int)'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::CmdWaitOnFences::CmdWaitOnFences(cupva::Fence const&)'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::GetHardwareInfo()'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::StaticDataFlow::dstLinePitch(int)'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::CmdProgram::Create(cupva::Executable const&)'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::RasterDataFlow::handler(cupva::Parameter const&)'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::Parameter::setValuePointer(void*)'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::ConfigDataFlow::~ConfigDataFlow()'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::CmdProgram::operator=(cupva::CmdProgram&&) &'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::StaticDataFlow::padVal(cupva::PadModeType, int)'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::RasterDataFlow::halo(int, int, cupva::PadModeType, int)'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::Stream::submit(std::initializer_list<cupva::BaseCmd const*> const&, cupva::impl::CmdStatus**, cupva::OrderType, int, int)'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::CmdProgram::compileDataFlows()'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::DynamicDataFlow::Create()'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::Parameter::setValueArray(void const*, long)'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::mem::Alloc(long, cupva::mem::AccessType, cupva::mem::AllocType)'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::Executable::Executable(cupva::Executable&&)'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::Context::Create(unsigned int)'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::CmdProgram::~CmdProgram()'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::StaticDataFlow::src(void const*)'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::RasterDataFlow::tile(int, int)'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::CmdProgram::Create()'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::DynamicDataFlow::at(int, int)'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::mem::GetSurfaceAttributes(void const*, cupva::mem::SurfaceAttributes&)'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::StaticDataFlow::srcCircularBuffer(int, int)'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::CmdRequestFences::~CmdRequestFences()'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::StaticDataFlow::srcLinePitch(int)'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::ConfigDataFlow::Create()'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::Stream::submit(cupva::BaseCmd const* const*, cupva::impl::CmdStatus**, int, cupva::OrderType, int, int)'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::Context::GetCurrent()'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::RasterDataFlow::tileBufferImpl(void*, void*)'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::Parameter::Parameter()'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::CmdProgram::registerDataFlowHead(cupva::BaseDataFlow&&, int, float)'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::Parameter::getDevicePointer() const'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::ConfigDataFlow::linkInternal(cupva::BaseDataFlow&, bool)'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::Fence::~Fence()'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::DynamicDataFlow::Node::src(void const*, int)'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::CmdProgram::registerDataFlow(cupva::BaseDataFlow&&)'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::StaticDataFlow::dstCircularBuffer(int, int)'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::Parameter::~Parameter()'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva_utils::AllocSurface(cupva_utils::PlaneSize const*, int, cupva::SurfaceFormatType)'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::DynamicDataFlow::Node::dst(void*, int)'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::RasterDataFlow::~RasterDataFlow()'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::StaticDataFlow::dstDim2(int, int)'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::CmdRequestFences::CmdRequestFences(cupva::Fence&)'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::Context::operator=(cupva::Context&&) &'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::ConfigDataFlow::handler(cupva::Parameter const&)'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::SyncObj::~SyncObj()'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::Context::SetCurrent(cupva::impl::Context*)'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::StaticDataFlow::dst(void*, void*)'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::mem::Free(void*)'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::RasterDataFlow::Create()'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::Executable::Create(void const*, int)'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::mem::GetHostPointer(void*)'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::DynamicDataFlow::Node::tile(int, int)'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::DynamicDataFlow::init(cupva::Parameter const&, int, int)'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::CmdProgram::operator[](char const*)'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::StaticDataFlow::linkInternal(cupva::BaseDataFlow&, bool)'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::RasterDataFlow::halo(int, cupva::PadModeType, int)'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::StaticDataFlow::padDim(cupva::PadDirType, int)'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::StaticDataFlow::~StaticDataFlow()'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::StaticDataFlow::bpp(int)'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::ConfigDataFlow::src(void const*)'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::StaticDataFlow::srcDim1(int, int)'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::StaticDataFlow::id() const'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::Parameter::setValueScalar(void const*, long)'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::StaticDataFlow::Create()'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::Stream::Create(cupva::EngineType, cupva::AffinityType)'
/usr/bin/ld: /opt/nvidia/vpi2/lib/aarch64-linux-gnu/libnvvpi.so.2.3.9: undefined reference to `cupva::StaticDataFlow::srcDim2(int, int)'
collect2: error: ld returned 1 exit status
make[2]: *** [CMakeFiles/isaac_ros_image_proc.dir/build.make:367: isaac_ros_image_proc] Error 1
make[1]: *** [CMakeFiles/Makefile2:310: CMakeFiles/isaac_ros_image_proc.dir/all] Error 2
make: *** [Makefile:146: all] Error 2
Failed <<< isaac_ros_image_proc [4min 54s, exited with code 2]
Summary: 0 packages finished [4min 55s]
1 package failed: isaac_ros_image_proc
1 package had stderr output: isaac_ros_image_proc
I would appreciate any advice on how to stop VPI from trying to use cupva, or any indication as to what is causing the problem with the most recent version of isaac_ros_image_pipeline for Isaac ROS 2.1 on a Jetson Orin Nano.
