Isaac ROS Perceptor Argus Camera error
I am using a Jetson Orin machine connected with a Hawk camera trying to follow the Perceptor tutorial. However, when I run the command ros2 launch nova_developer_kit_bringup perceptor.launch.py. The error shows:
I also completed the ESS depth tutorial without error using the same camera.
Can you please help me on this? Thank you!
Hi @JackyC
Welcome to the Isaac ROS forum.
To better assist you, can you reply the following questions below:
Dear Raffaello,
Thank you for your reply.
  1. I confirmed that the device meets the requirement with Jetpack 6.0
  2. I have installed the nova-orin-init
  3. I do have the output after using the argus_camera command
Best regards,
Junchi
Thank you for your help.
I have sent your configuration to the engineers to gain a better understanding of how to assist you.
Is it possible also to share the content from /etc/nova/systeminfo.yaml ?
Thank you in advance,
Raffaello
Dear Raffaello,
I have solved this problem by updating the nova-orin-init to the newest version of 1.3.0 and customized a yaml file for one hawk camera.
Thank you for the help,
Jacky
