hi i finished setting up realsense2 isaac ros and hardware settings and visual slam quick start.
When I try to start visual slam quick start instructions, it works. I try to start tutorials with realsense, topics are shown correctly. However when try
ros2 topic hz /camera/infra1/image_rect_raw --window 20
WARNING: topic [/camera/infra1/image_rect_raw] does not appear to be published yet
ros2 launch isaac_ros_visual_slam isaac_ros_visual_slam_realsense.launch.py
[INFO] [launch]: All log files can be found below /home/admin/.ros/log/2025-08-07-14-58-32-088868-ubuntu-334196
[INFO] [launch]: Default logging verbosity is set to INFO
[INFO] [component_container-1]: process started with pid [334209]
[INFO] [realsense2_camera_node-2]: process started with pid [334211]
[realsense2_camera_node-2] [INFO] [1754546312.522116939] [camera.camera]: RealSense ROS v4.51.1
[realsense2_camera_node-2] [INFO] [1754546312.522322377] [camera.camera]: Built with LibRealSense v2.55.1
[realsense2_camera_node-2] [INFO] [1754546312.522352649] [camera.camera]: Running with LibRealSense v2.55.1
[component_container-1] [INFO] [1754546312.532370775] [visual_slam_launch_container]: Load Library: /opt/ros/humble/lib/libvisual_slam_node.so
[component_container-1] [INFO] [1754546312.645431326] [visual_slam_launch_container]: Found class: rclcpp_components::NodeFactoryTemplatenvidia::isaac_ros::visual_slam::VisualSlamNode
[component_container-1] [INFO] [1754546312.645561085] [visual_slam_launch_container]: Instantiate class: rclcpp_components::NodeFactoryTemplatenvidia::isaac_ros::visual_slam::VisualSlamNode
[component_container-1] [INFO] [1754546312.861535070] [NitrosContext]: [NitrosContext] Loading extension: gxf/lib/std/libgxf_std.so
[component_container-1] [INFO] [1754546312.865503037] [NitrosContext]: [NitrosContext] Loading extension: gxf/lib/libgxf_isaac_gxf_helpers.so
[component_container-1] [INFO] [1754546312.873103071] [NitrosContext]: [NitrosContext] Loading extension: gxf/lib/libgxf_isaac_sight.so
[component_container-1] [INFO] [1754546312.881675961] [NitrosContext]: [NitrosContext] Loading extension: gxf/lib/libgxf_isaac_atlas.so
[component_container-1] 2025-08-07 14:58:32.900 WARN external/com_nvidia_gxf/gxf/std/program.cpp@538: No GXF scheduler specified.
[component_container-1] [INFO] [1754546312.901383897] [NitrosContext]: [NitrosContext] Loading extension: gxf/lib/multimedia/libgxf_multimedia.so
[component_container-1] [INFO] [1754546312.913581238] [visual_slam_node.ManagedNitrosSubscriber]: Starting Managed Nitros Subscriber
[component_container-1] [INFO] [1754546312.916546749] [visual_slam_node.ManagedNitrosSubscriber]: Starting Managed Nitros Subscriber
[component_container-1] [INFO] [1754546312.958892484] [visual_slam_node]: cuVSLAM version: 12.6
[component_container-1] [INFO] [1754546313.068871876] [visual_slam_node]: Time taken by CUVSLAM_WarmUpGPU(): 0.109235
[INFO] [launch_ros.actions.load_composable_nodes]: Loaded node ‘/visual_slam_node’ in container ‘/visual_slam_launch_container’
[realsense2_camera_node-2] [INFO] [1754546313.164043196] [camera.camera]: Device with serial number 146222254059 was found.
[realsense2_camera_node-2] [INFO] [1754546313.164228507] [camera.camera]: Device with physical ID 2-3.2-7 was found.
[realsense2_camera_node-2] [INFO] [1754546313.164251355] [camera.camera]: Device with name Intel RealSense D455 was found.
[realsense2_camera_node-2] [INFO] [1754546313.165859438] [camera.camera]: Device with port number 2-3.2 was found.
[realsense2_camera_node-2] [INFO] [1754546313.165958509] [camera.camera]: Device USB type: 3.2
[realsense2_camera_node-2] [INFO] [1754546313.171114883] [camera.camera]: getParameters…
[realsense2_camera_node-2] [INFO] [1754546313.171720414] [camera.camera]: JSON file is not provided
[realsense2_camera_node-2] [INFO] [1754546313.171767101] [camera.camera]: Device Name: Intel RealSense D455
[realsense2_camera_node-2] [INFO] [1754546313.171785981] [camera.camera]: Device Serial No: 146222254059
[realsense2_camera_node-2] [INFO] [1754546313.171798621] [camera.camera]: Device physical port: 2-3.2-7
[realsense2_camera_node-2] [INFO] [1754546313.171809117] [camera.camera]: Device FW version: 5.16.0.1
[realsense2_camera_node-2] [INFO] [1754546313.171818589] [camera.camera]: Device Product ID: 0x0B5C
[realsense2_camera_node-2] [INFO] [1754546313.171828157] [camera.camera]: Sync Mode: Off
[realsense2_camera_node-2] [WARN] [1754546317.563751240] [camera.camera]: re-enable the stream for the change to take effect.
[realsense2_camera_node-2] [WARN] [1754546318.582287752] [camera.camera]: re-enable the stream for the change to take effect.
[realsense2_camera_node-2] [INFO] [1754546318.598397156] [camera.camera]: Stopping Sensor: Stereo Module
[realsense2_camera_node-2] [INFO] [1754546318.841705729] [camera.camera]: Starting Sensor: Stereo Module
[realsense2_camera_node-2] [INFO] [1754546318.916340959] [camera.camera]: Open profile: stream_type: Infra(1), Format: Y8, Width: 640, Height: 360, FPS: 90
[realsense2_camera_node-2] [INFO] [1754546318.916481854] [camera.camera]: Open profile: stream_type: Infra(2), Format: Y8, Width: 640, Height: 360, FPS: 90
[realsense2_camera_node-2] [INFO] [1754546318.916588413] [camera.camera]: Stopping Sensor: Motion Module
[realsense2_camera_node-2] [INFO] [1754546319.032207308] [camera.camera]: Starting Sensor: Motion Module
[realsense2_camera_node-2] [INFO] [1754546319.050180185] [camera.camera]: Open profile: stream_type: Accel(0)Format: MOTION_XYZ32F, FPS: 200
[realsense2_camera_node-2] [INFO] [1754546319.050323352] [camera.camera]: Open profile: stream_type: Gyro(0)Format: MOTION_XYZ32F, FPS: 200
[realsense2_camera_node-2] [INFO] [1754546319.055933194] [camera.camera]: RealSense Node Is Up!
I can’t see any images from realsense camera.
Is anyone has same errors?
How can I solve this.
