Isaac Sim [4.5] Husky Rotation Failure: Wheels forced straight during playback despite Orientation changes & correct settings
Note: For any Isaac Lab topics, please submit your topic to its GitHub repo (GitHub - isaac-sim/IsaacLab: Unified framework for robot learning built on NVIDIA Isaac Sim) following the instructions provided on Isaac Lab’s Contributing Guidelines (Contribution Guidelines — Isaac Lab Documentation).
Isaac Sim Version
4.5.0
code Repo:
Omniverse/Extension/[NetAI]GIST_Husky_IsaacSim_ROS at main · SmartX-Team/Omniverse
Reated to current issue’s Main Code :
Extension/[NetAI]GIST_Husky_IsaacSim_ROS/exts/gist.husky.isaacsim_ros/gist/husky/isaacsim_ros/ros_listeners.py
Operating System
Ubuntu 22.04
GPU Information
  • Model: RTXA6000
  • Driver Version: 535
제목 없는 동영상 - Clipchamp로 제작 (2)
I am encountering a persistent issue controlling a custom URDF-based Husky robot in Isaac Sim [Your Version, e.g., 2024.1.1] using ROS2 Humble via the /cmd_vel topic. I would appreciate any insights or advice.
Problem Summary:
Environment: NVIDIA Isaac Sim [Your Version], ROS2 Humble, Custom URDF-based Husky model.
Control Method: OmniGraph setup via Python script, subscribing to /cmd_vel (geometry_msgs/Twist), using DifferentialController and IsaacArticulationController.
Symptoms:
The robot responds correctly to linear.x commands (moves forward/backward).
The robot completely fails to rotate in response to angular.z commands.
Core Issue 1: The Target Velocity property (Drive → Angular → Target Velocity) for individual wheel joints remains stuck at 0.0 in the Property panel, even when the IsaacArticulationController receives a valid velocityCommand array with different values for left and right wheels intended for rotation.
Core Issue 2: When the simulation is playing (Play mode), the wheels are actively forced into a straight-ahead position (likely the initial angle). This happens despite the fact that:
Individual wheel manipulation (e.g., changing orientation) is possible when paused.
The Transform → Orientation property of the wheel prims does change in real-time according to joystick input (visual/transform state is affected). However, the physics simulation seems to override this during playback, forcing the wheels straight.
Confirmed Working Aspects:
ROS2 Input: /cmd_vel topic publishing and subscription via ROS2SubscribeTwist node are working correctly.
OmniGraph Data Flow (Upstream):
BreakVector3 correctly extracts scalar linear.x and angular.z.
DifferentialController correctly receives inputs and calculates outputs:velocityCommand ([v_left, v_right]). Confirmed via OmniGraph editor that v_left and v_right have different values when a rotation command (angular.z != 0) is sent. (Parameters like wheelRadius=0.165, wheelDistance=0.555, maxLinearSpeed, maxAngularSpeed are set).
The [v_left, v_right] array is correctly reconstructed into a 4-element array [v_right, v_left, v_right, v_left] using ArrayIndex and ArrayInsertValue nodes.
This final 4-element array is correctly fed into IsaacArticulationController’s inputs:velocityCommand, and its values change in real-time based on joystick input (including different values for left/right sides).
IsaacArticulationController Inputs: inputs:positionCommand and inputs:effortCommand are confirmed to be empty or connected to empty arrays (size 0), ensuring they do not interfere with velocityCommand processing based on the suspected if/elif logic. inputs:robotPath and inputs:jointNames are set correctly.
Confirmed Joint Physics Settings (Applied via Python script):
UsdPhysics.DriveAPI: Explicitly set for all 4 wheel joints (PhysicsRevoluteJoint):
stiffness: 0.0 (Confirmed via Property panel).
damping: 100.0 (or other appropriate positive value, confirmed).
type: Tested with both “force” and “acceleration”, but the Target Velocity update failure persists in both cases. (Specify which one is currently set, e.g., “Currently set to ‘acceleration’”).
Joint Axis: Set to “X” for all joints (Correctness of “X” itself to be verified after rotation works, but the setting is applied).
Joint Limits: Lower/Upper limits are “Not Limited”.
Exclude From Articulation: Unchecked.
Joint-Wheel Mapping: Body 0 (base_link) and Body 1 (corresponding wheel prim) are correctly linked in each joint’s properties.
Collisions: Visual inspection shows no obvious initial interpenetration between wheel and body colliders.
PhysicsConstraint: Script-based check confirmed no explicit PhysicsConstraintAPI prims found under the Husky model.
2025-05-08144450-ezgif.com-video-to-gif-converter
Summary of Core Problem Symptoms (Consolidated):
Based on extensive debugging, the core conflicting symptoms are:
Despite all upstream OmniGraph logic appearing correct and delivering a valid velocityCommand (with different L/R values) to the IsaacArticulationController, and despite the joint DriveAPI properties (stiffness=0, damping>0, type tested as “force”/“acceleration”) being correctly set, the Target Velocity property on the joints remains fixed at 0.0.
Simultaneously, the Transform → Orientation of the wheel prims does react to the joystick input as intended.
However, when the simulation enters Play mode, the wheels are actively forced straight, overriding any orientation changes caused by the input. Manually trying to force an orientation change during playback also results in the rigid body (robot chassis) moving instead of just the wheel rotating relative to the chassis.
Request for Advice:
Given that we have seemingly ruled out common issues like incorrect DriveAPI parameters (Stiffness!=0), interfering positionCommand inputs, and explicit PhysicsConstraints, we are struggling to understand why:
The IsaacArticulationController is failing to update the Target Velocity attribute?
The physics simulation is actively forcing the wheels straight during playback, even overriding visual orientation changes.
dasdasdadasdad-ezgif.com-video-to-gif-converter
Could there be another mechanism, property, or bug within IsaacArticulationController or the PhysX integration in Isaac Sim 4.5 that could cause this behavior (failing to set Target Velocity AND actively forcing a straight orientation)?
I am looking for advice on what specific areas to investigate next to resolve this perplexing issue where rotation commands seem partially processed (affecting orientation) but ultimately fail at the physics execution level (forcing wheels straight, Target Velocity at 0).
Thank you for your time and assistance.
Hi @inyong2327,
Thank you for posting your issue. I will be looking into this soon. I suspect it is an issue with either the Asset collider or the articulation configuration. Will update you soon.
Thank you for your response. I will share a GIF of a new test I conducted later.
I tested it in a different Simple World, and confirmed that rotation works without any issues there. So, I’m suspecting the cause might be related to the World’s collider settings [in the original problematic World], but I’m not sure exactly which part is causing the problem.
Actually, it’s only rotation that isn’t working (specifically, it seems only certain wheels move when attempting to rotate); all other functions like forward/backward movement, Lidar, and Camera Data generation are working correctly.
Husky_demo_new-ezgif.com-video-to-gif-converter
The issue has finally been resolved, and the root cause was the specific combination and interaction of Damping and Max Force settings.
My Husky UGV was not a standard URDF but a custom UGV model created based on Inventor. Since its original size was small, I had scaled it up for use in the digital twin world I had prepared. (I’m not entirely sure if the scaling operation itself directly increases the absolute mass value in the simulation, though typically, if density is preserved, mass would increase with volume).
I discovered that the required combination of Damping and Max Force changes significantly depending on the scale of the model. In my specific case, with Damping set to 1000 and Max Force set to 100,000, the rotational movement proceeded normally, as (presumably) shown in the video I shared.
It’s clear that the correct combination of Damping and Max Force needs to be tailored to the specific environment and model. For instance, in my testing, setting Damping to a value below 100 and then sequentially increasing Max Force from 1,000 up to 1,000,000 did not enable rotational movement. However, once I increased Damping to 1,000 (while maintaining a sufficiently high Max Force), the robot began to rotate correctly.
Conversely, if I kept Damping at 1,000 but then significantly decreased Max Force, my Husky UGV would not move. This highlights that an appropriate balance of both parameters is crucial.
I’m leaving this Q&A as a reference in case others who are conducting robot simulations based on Isaac Sim and ROS2 encounter the same or similar issues. Thank you
Final_Test_ex-ezgif.com-video-to-gif-converter
Hi @inyong2327, I am glad you were able to find a solution. It is still strange to me that a combination of Damping=1000 and Max Force=1e6 will cause it to not rotate. My guess is that the damping forces will quickly make the Joint Drive hit the Max Force. But that seem unlikely since velocities are pretty small. Its great that you were able to get unblocked, but please let me know if you run into any additional issues.
Hi. After conducting additional experiments and repeated testing, I confirmed that the cause of the problem I experienced was due to multiple factors, and now it operates almost identically to the actual UGV.
Below is the overall debugging process I went through.
1. Simulation Unit Verification
First, I identified the simulation units of my world based on the following script. I imported a World that was progressively built using USD Composer, 3DS Max, AutoCAD, etc., into Isaac Sim as a simulation environment. In my case, the unit was cm rather than m.
import omni.usd                             # For getting stage object in Kit/Isaac Sim
from pxr import UsdGeom                     # USD API
# Get the currently open stage
# Read the stage length unit (metersPerUnit)
mpu = UsdGeom.GetStageMetersPerUnit(stage)  # float value
print("metersPerUnit =", mpu)
# Interpretation examples
if mpu == 1.0:
    print(" Length unit is meters (m)")
elif mpu == 0.01:
    print("Length unit is centimeters (cm)")
else:
    print(" Custom unit, 1 SceneUnit = {} m".format(mpu))
Therefore, I adjusted the force magnitude to match the actual A200 robot’s Husky PM45L-048 motor’s maximum torque (49.3 Nm). Since my unit was cm, I adjusted the Max Force to 493,000 and Damping to approximately 27,000.
2. Tire Friction Coefficients
Although I’m not certain if these are optimized coefficients yet, based on multiple test results:
  • Dynamic Friction: 0.7
  • Static Friction: 0.8
Using these settings, there were no separate friction-related issues.
3. Ground Collision Settings
Some parts of the ground had collision set as mesh, which affects rotational movement. Even though the visual model remains as mesh, I changed the actual collision to bounding cube.
Besides these, continuous adjustment and configuration of other parameters were necessary to make it move almost identically to the actual Husky, but the main factors that were hindering rotational movement were the issues mentioned above.
