Isaac sim cant launch
Nvidia Quadro RTX 4000 Ubuntu 22.04 Server PC I was using Nvidia driver 535.
Changes I have tried:
  1. Used Nvidia drivers 545, 550, 535-server, and 525-server.
  2. Installed Docker.
  3. Reinstalled the OS.
  4. Reinstalled Isaac Sim.
Problem: The launch was not working. The app selector was not opened.
pls answer me
kit_20240708_214123.log (582.7 KB)
"I changed the driver to:
  • 535
  • 535-server
  • 545
  • 550
  • 525
  • 525-server
I reinstalled Isaac Sim:
  • hot~
  • 23.01.01
  • 4
I checked nvidia-smi and nvcc.
| NVIDIA-SMI 545.23.06 Driver Version: 545.23.06 CUDA Version: 12.3 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 Quadro RTX 4000 Off | 00000000:12:00.0 Off | N/A |
| 30% 37C P8 9W / 125W | 6MiB / 8192MiB | 0% Default |
| | | N/A |
| 1 Quadro RTX 4000 Off | 00000000:37:00.0 Off | N/A |
| 30% 36C P8 6W / 125W | 6MiB / 8192MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1123 G /usr/lib/xorg/Xorg 4MiB |
| 1 N/A N/A 1123 G /usr/lib/xorg/Xorg 4MiB |
I checked the NVIDIA settings. Please provide a solution.
Isaac Sim launch did not work, and the app selector did not appear.
Hi. Looks like the drivers were not installed correctly. Are using the .run driver installers?
Are you running on a baremetal server? Is it a headless remote machine or has a display connected to the GPUs.
If it is a headless environment, you need to run Isaac Sim and python scripts in headless mode.
“That’s correct. It seems to be a driver issue. I used run to install the 550, 545, and 540 drivers. However, it still didn’t work. I couldn’t find the cause of the problem on the forums.”
What is a bare-metal server? I am using it with HPE servers. Also, I want to start using Isaac Sim with the most basic setup, which is through the GUI. Can I not check the display connected to the GPU with nvidia-smi?
How did you install the drivers?
Are you running bare-metal, as in running Isaac Sim natively on the server in Ubuntu or are you running on a VM on the server?
You can check if you have a connected display by running xrandr.
  1. i installed the drivers (.run or autoinstall)
    2.i am runnig natively on Ubuntu server
    3.I checked the display, Below is the output
pls answer next step
Screen 0: minimum 8 x 8, current 3840 x 1080, maximum 32767 x 32767
HDMI-0 connected primary 1920x1080+1920+0 (normal left inverted right x axis y axis) 368mm x 207mm
1920x1080 60.00*+ 59.94 50.00
1600x900 60.00
1280x1024 60.02
1280x960 60.00
1280x800 59.81
1280x720 60.00 59.94 50.00
1152x864 60.00
1024x768 60.00
800x600 60.32 56.25
720x576 50.00
720x480 59.94
640x480 75.00 72.81 59.94 59.93
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 disconnected (normal left inverted right x axis y axis)
DP-4 disconnected (normal left inverted right x axis y axis)
DP-5 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 477mm x 268mm
1920x1080 60.02*+ 75.00 59.94 50.00
1680x1050 59.95
1600x1200 60.00
1600x900 59.98
1440x900 59.89
1280x1024 75.02 60.02
1280x960 60.00
1280x800 59.81
1024x768 75.03 70.07 60.00
800x600 75.00 72.19 60.32 56.25
720x576 50.00
720x480 59.94
