Isaac Sim crashes when running ROS examples
Isaac Sim Version
4.5.0
4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
GPU Information
  • Model: RTX 6000
  • Driver Version: 535.183.01
Topic Description
Detailed Description
I created my own docker container with isaac sim 4.5.0 and ros2 humble. I have this running on an ML computer with 3 NVIDIA RTX 6000 GPUs, and I’m connect to this remote machine and use webrtc streaming client to see the isaac sim GUI on my base system. Whenever I run ROS2>Navigation>Carter it runs for a minute or two and then process memory overflows and crashes. I did not have this issue when I used the same container on my base machine.
Steps to Reproduce
  1. Clone GitHub - nathanshankar/docker_isaac_ros2
  2. Build and run the container on your remote machine
  3. Run ./runheadless.sh on your remote machine and set up your web streaming client on your base machine
  4. Run the robotics examples>ros2>navigation>Carter
  5. run a ros2 node to teleop_twist_keyboard and move it around for a minute or two.
Error Messages
I don’t seem to be getting any errors, just that it’s Killed:
2025-04-04 11:20:35 [132,821ms] [Info] [rtx.rtxsensor.plugin] Initialized sensor model 0x79233964f190 on device 2
2025-04-04 11:20:35 [132,821ms] [Info] [rtx.rtxsensor.plugin] Using User-specified coordinate frame quaternion (0.000000, 0.000000, 0.000000, 1.000000) in RTXSensor
2025-04-04 11:20:35 [132,821ms] [Info] [carb.scenerenderer-rtx.plugin] RTXSensor Model produced RtxSensorCpu
2025-04-04 11:20:35 [132,821ms] [Info] [carb.scenerenderer-rtx.plugin] RTXSensor Model produced RtxSensorMetadata
2025-04-04 11:20:35 [133,070ms] [Info] [omni.kit.menu.utils.utils] omni.kit.menu.utils.refresh_menu_items Create
2025-04-04 11:20:35 [133,152ms] [Info] [omni.kit.menu.utils.utils] omni.kit.menu.utils.refresh_menu_items Edit
2025-04-04 11:20:35 [133,158ms] [Warning] [omni.timeline.plugin] Deprecated: direct use of ITimeline callbacks is deprecated. Use ITimeline::getTimeline (Python: omni.timeline.get_timeline_interface) instead.
2025-04-04 11:20:35 [133,178ms] [Info] [isaacsim.ros2.bridge.plugin] isaac_ros_nitros_bridge_interfaces NitrosBridgeImage message type not found. The NITROS bridge publisher was not created
2025-04-04 11:20:35 [133,291ms] [Info] [lidar.lidarprofilereader] Reader is not an array or member channelId not found
2025-04-04 11:20:35 [133,291ms] [Info] [lidar.lidarprofilereader] Reader is not an array or member rangeId not found
2025-04-04 11:20:35 [133,291ms] [Info] [lidar.lidarprofilereader] Reader is not an array or member vertOffsetM not found
2025-04-04 11:20:35 [133,291ms] [Info] [lidar.lidarprofilereader] Reader is not an array or member horOffsetM not found
2025-04-04 11:20:35 [133,291ms] [Info] [lidar.lidarprofilereader] Reader is not an array or member distanceCorrectionM not found
2025-04-04 11:20:35 [133,291ms] [Info] [lidar.lidarprofilereader] Reader is not an array or member focalDistM not found
2025-04-04 11:20:35 [133,291ms] [Info] [lidar.lidarprofilereader] Reader is not an array or member focalSlope not found
2025-04-04 11:20:35 [133,291ms] [Info] [lidar.lidarprofilereader] Reader is not an array or member reportRateDiv not found
2025-04-04 11:20:35 [133,291ms] [Info] [lidar.lidarprofilereader] Reader is not an array or member bank not found
2025-04-04 11:20:35 [133,291ms] [Info] [lidar.lidarprofilereader] Reader is not an array or member roi not found
2025-04-04 11:20:59 [156,844ms] [Warning] [omni.graph.core.plugin] /World/Nova_Carter_ROS/differential_drive/differential_controller_01: [/World/Nova_Carter_ROS/differential_drive] invalid dt 0.000000, cannot check for acceleration limits, skipping current step
2025-04-04 11:20:59 [156,845ms] [Info] [omni.usd.audio] resetting the animation timeline
Killed
Screenshots or Videos
Additional Information
What I’ve Tried
I’m not really sure where the issue seems to happen, since it works fine on my base system but doesn’t on a super powerful ML computer, I checked the forum but couldn’t find any available solutions.
Here’s the simulation before I start it:
Could you confirm whether the officially supported Docker container running on the remote ML system would reproduce the issue?
Yes I get the same issue with the official supported Docker Container as well. It works fine when I run it on my base system, but crashes on the ML system.
I have the same problem. Whe I just followed by the example of ROS2 navigation(https://docs.isaacsim.omniverse.nvidia.com/5.0.0/ros2_tutorials/tutorial_ros2_navigation.html), the GPU crashes with the similar situation here.
The detail of PC is as follows:
Isaac Sim Version:5.0.0
Operating System:Ubuntu 22.04
GPU Information
Isaac sim was running under an anaconda env, and the following is my output error:
2025-08-21T07:39:56Z [358,197ms] [Error] [carb.graphics-vulkan.plugin] GPU crash is detected. Trying to write shader debug info into: /home/lee/.nvidia-omniverse/logs/Kit/Isaac-Sim Full/5.0/kit_20250821_153358-98958b040787eb48-000076c234a31b30.nvdbg
2025-08-21T07:39:56Z [358,197ms] [Error] [carb.graphics-vulkan.plugin] Shader debug info successfully written
2025-08-21T07:39:56Z [358,198ms] [Warning] [carb.graphics-vulkan.plugin] GPU pagefault occured on virtual address(0x0000000000798000)
2025-08-21T07:39:56Z [358,198ms] [Warning] [carb.graphics-vulkan.plugin] GPU pagefault no associated data found closest allocations were:
2025-08-21T07:39:56Z [358,198ms] [Warning] [carb.graphics-vulkan.plugin] 1: AddressRange(0x0000000000000000 - 0x0000000000000000) with name(dummy to ignore)
2025-08-21T07:39:56Z [358,198ms] [Warning] [carb.graphics-vulkan.plugin] 2: AddressRange(0xffffffffffffffff - 0xffffffffffffffff) with name(dummy to ignore)
2025-08-21T07:39:56Z [358,198ms] [Error] [carb.graphics-vulkan.plugin] GPU crash is detected. Trying to write crash dump into: /home/lee/.nvidia-omniverse/logs/Kit/Isaac-Sim Full/5.0/kit_20250821_153358-0.nv-gpudmp
2025-08-21T07:39:56Z [358,199ms] [Error] [carb.graphics-vulkan.plugin] GPU crash dump is successfully written
2025-08-21T07:39:56Z [358,855ms] [Error] [carb.graphics-vulkan.plugin] VkResult: ERROR_DEVICE_LOST
2025-08-21T07:39:56Z [358,855ms] [Error] [carb.graphics-vulkan.plugin] vkWaitForFences failed for command queue.
2025-08-21T07:39:56Z [358,855ms] [Error] [omni.kit.imgui_renderer.plugin] ResourceLoader::endAndSubmit - Failed to wait for fence.
2025-08-21T07:39:56Z [358,855ms] [Error] [omni.kit.imgui_renderer.plugin] uploadData: failed to end and submit ResourceLoader
2025-08-21T07:39:56Z [358,859ms] [Error] [omni.kit.imgui_renderer.plugin] Failed to upload font texture
2025-08-21T07:39:56Z [358,868ms] [Error] [carb.graphics-vulkan.plugin] VkResult: ERROR_DEVICE_LOST
2025-08-21T07:39:56Z [358,868ms] [Error] [carb.graphics-vulkan.plugin] submitToQueueCommon failed.
2025-08-21T07:39:56Z [358,868ms] [Error] [gpu.foundation.plugin] A GPU crash occurred. Exiting the application...
Reasons for the failure: a device lost, out of memory, or an unexpected bug.
2025-08-21T07:39:56Z [358,869ms] [Warning] [gpu.foundation.plugin] polling aftermath dump status ...
2025-08-21T07:39:56Z [358,919ms] [Warning] [gpu.foundation.plugin] successfully waited and produced aftermath dump
2025-08-21T07:39:58Z [0ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] A crash has occurred.  If a debugger should be attached, please set the '/crashreporter/debuggerAttachTimeoutMs' setting to a timeout in milliseconds.  This can be used to allow the crash reporter to wait for up to that long for a debugger to attach before processing or sending the crash report.
2025-08-21T07:40:07Z [9,450ms] [Error] [carb.crashreporter-breakpad.plugin] 'crashreport.gui' exited with code 3
2025-08-21T07:40:07Z [9,455ms] [Error] [carb.crashreporter-breakpad.plugin] [crash]     user declined uploading a crash dump, will delete
2025-08-21T07:40:07Z [9,461ms] [Error] [carb.crashreporter-breakpad.plugin] [crash] Wrote dump file '/home/lee/.local/share/ov/data/Kit/Isaac-Sim Full/5.0/77748e48-f2d8-4659-463807a0-3a2a02b0.dmp'
2025-08-21T07:40:07Z [9,465ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] preventing upload of minidump due to user opt-out: '/home/lee/.local/share/ov/data/Kit/Isaac-Sim Full/5.0/77748e48-f2d8-4659-463807a0-3a2a02b0.dmp'
2025-08-21T07:40:07Z [9,470ms] [Error] [carb.crashreporter-breakpad.plugin] [crash]     dump file size is 11860192 bytes, file is readable.
2025-08-21T07:40:07Z [9,475ms] [Fatal] [carb.crashreporter-breakpad.plugin] [crash] Crash detected in pid 1395389 thread 1395389
2025-08-21T07:40:07Z [9,480ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] Crash metadata:
2025-08-21T07:40:07Z [9,485ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  BuildGitlabJobID = '182268558'
2025-08-21T07:40:07Z [9,490ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  CarbSdkVersion = '206.4+release.9396.3c6f8191.gl'
2025-08-21T07:40:07Z [9,494ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  CrashTime = 'Thu Aug 21 07:39:58 2025 GMT'
2025-08-21T07:40:07Z [9,499ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  DriverShaderCacheWrapper = 'disabled'
2025-08-21T07:40:07Z [9,504ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  DumpId = '77748e48-f2d8-4659-463807a0-3a2a02b0'
2025-08-21T07:40:07Z [9,509ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  LastUploadStatus = '0'
2025-08-21T07:40:07Z [9,513ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  ProductName = 'OmniverseKit'
2025-08-21T07:40:07Z [9,519ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  PythonTracebackStatus = ''py-spy' successfully wrote info to '/home/lee/.local/share/ov/data/Kit/Isaac-Sim Full/5.0/77748e48-f2d8-4659-463807a0-3a2a02b0.py.txt''
2025-08-21T07:40:07Z [9,523ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  RetryCount = '0'
2025-08-21T07:40:07Z [9,528ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  StartupTime = '1755761638'
2025-08-21T07:40:07Z [9,532ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  UploadSuccessful = '0'
2025-08-21T07:40:07Z [9,538ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  UptimeSeconds = '360'
2025-08-21T07:40:07Z [9,542ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  UserStory = ''
2025-08-21T07:40:07Z [9,547ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  UserStoryStatus = ''crashreport.gui' exited with code 3'
2025-08-21T07:40:07Z [9,551ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  Version = '107.3.1+production.206797.8131b85d.gl'
2025-08-21T07:40:07Z [9,557ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  aftermath_active_shader_0_hash_match_count = '1'
2025-08-21T07:40:07Z [9,561ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  aftermath_active_shader_0_match_0 = 'rtx/scenedb/Skinning.comp.hlsl,main,scenedb: skinning,98958b040787eb48'
2025-08-21T07:40:07Z [9,566ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  aftermath_active_shader_count = '1'
2025-08-21T07:40:07Z [9,570ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  aftermath_enabled = '1'
2025-08-21T07:40:07Z [9,576ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  aftermath_flags = '3'
2025-08-21T07:40:07Z [9,580ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  aftermath_status = 'auto-enabled'
2025-08-21T07:40:07Z [9,585ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  aftermath_version = '2024.1'
2025-08-21T07:40:07Z [9,590ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  appName = 'Isaac-Sim Full'
2025-08-21T07:40:07Z [9,595ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  appState = 'started'
2025-08-21T07:40:07Z [9,599ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  appVersion = '5.0.0'
2025-08-21T07:40:07Z [9,604ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  autoloadExts = 'isaacsim.asset.gen.conveyor.ui-2.1.17,isaacsim.asset.gen.conveyor-1.0.22,omni.kit.graph.widget.variables-2.1.0'
2025-08-21T07:40:07Z [9,609ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  buildBranch = 'production'
2025-08-21T07:40:07Z [9,614ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  buildCi = 'gl'
2025-08-21T07:40:07Z [9,618ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  buildConfig = 'release'
2025-08-21T07:40:07Z [9,623ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  buildGitlabJobName = 'kit-build-release-linux-x86_64'
2025-08-21T07:40:07Z [9,628ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  buildGitlabJobStage = 'kit-build'
2025-08-21T07:40:07Z [9,633ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  buildGitlabPipelineID = '30713850'
2025-08-21T07:40:07Z [9,637ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  buildHash = '8131b85d'
2025-08-21T07:40:08Z [9,642ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  buildMajor = '107'
2025-08-21T07:40:08Z [9,647ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  buildMinor = '3'
2025-08-21T07:40:08Z [9,652ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  buildNumber = '206797'
2025-08-21T07:40:08Z [9,656ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  buildPatch = '1'
2025-08-21T07:40:08Z [9,662ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  buildVersion = '107.3.1'
2025-08-21T07:40:08Z [9,666ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  carboniteFrameworkVersion = '206.4+release.9396.3c6f8191.gl'
2025-08-21T07:40:08Z [9,671ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  carboniteSdkVersion = '206.4+release.9396.3c6f8191.gl'
2025-08-21T07:40:08Z [9,675ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  commandLine = '/home/<username>/isaacsim/kit/kit /home/<username>/isaacsim/apps/isaacsim.exp.full.kit'
2025-08-21T07:40:08Z [9,681ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  cpuCoreLimited = '128'
2025-08-21T07:40:08Z [9,685ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  cpuId = 'Intel64 Family 6 Model 207 Stepping 2'
2025-08-21T07:40:08Z [9,690ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  cpuLogicalCoresBareMetal = '128'
2025-08-21T07:40:08Z [9,695ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  cpuName = 'INTEL(R) XEON(R) GOLD 6530'
2025-08-21T07:40:08Z [9,700ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  cpuPhysicalCoresBareMetal = '64'
2025-08-21T07:40:08Z [9,704ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  cpuUsageQuota = '-1.000000'
2025-08-21T07:40:08Z [9,709ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  cpuVendor = 'GenuineIntel'
2025-08-21T07:40:08Z [9,714ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  desktopOrigin = '(0, 0)'
2025-08-21T07:40:08Z [9,719ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  desktopSize = '1920x1080'
2025-08-21T07:40:08Z [9,723ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  displayCount = '1'
2025-08-21T07:40:08Z [9,728ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  displayRes_0 = '1920x1080x32bit@60Hz'
2025-08-21T07:40:08Z [9,733ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  environmentName = 'Individual'
2025-08-21T07:40:08Z [9,738ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  externalBuild = '1'
2025-08-21T07:40:08Z [9,742ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  extraExts = 'isaacsim.ros2.bridge-4.9.3'
2025-08-21T07:40:08Z [9,748ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  gpuCrash = '1'
2025-08-21T07:40:08Z [9,752ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  gpuDriver_0 = '580.65'
2025-08-21T07:40:08Z [9,757ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  gpuDriver_1 = '580.65'
2025-08-21T07:40:08Z [9,761ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  gpuVRAM_0 = '34609299456'
2025-08-21T07:40:08Z [9,767ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  gpuVRAM_1 = '34609299456'
2025-08-21T07:40:08Z [9,771ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  gpu_0 = 'NVIDIA RTX 5000 Ada Generation'
2025-08-21T07:40:08Z [9,776ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  gpu_1 = 'NVIDIA RTX 5000 Ada Generation'
2025-08-21T07:40:08Z [9,781ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  kitRendererDriverVersion = '580.65'
2025-08-21T07:40:08Z [9,786ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  lastCommand = 'SelectPrims(old_selected_paths=?,new_selected_paths=?,expand_in_stage=True)'
2025-08-21T07:40:08Z [9,790ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  lastCommands = 'CreateNodeCommand(graph=?,node_path=/Render/PostProcess/SDGPipeline/WriterSyncGate_01,node_type=omni.graph.action.RationalTimeSyncGate,create_usd=True),CreateNodeCommand(graph=?,node_path=/Render/PostProcess/SDGPipeline/Replicator_NodeWriterWriter,node_type=isaacsim.ros2.bridge.ROS2PublishCameraInfo,create_usd=True),CreateNodeCommand(graph=?,node_path=/Render/PostProcess/SDGPipeline/WriterSyncGate_02,node_type=omni.graph.action.RationalTimeSyncGate,create_usd=True),CreateNodeCommand(graph=?,node_path=/Render/PostProcess/SDGPipeline/Replicator_NodeWriterWriter_01,node_type=isaacsim.ros2.bridge.ROS2PublishImage,create_usd=True),CreateNodeCommand(graph=?,node_path=/Render/PostProcess/SDGPipeline/WriterSyncGate_03,node_type=omni.graph.action.RationalTimeSyncGate,create_usd=True),CreateAttrCommand(node=?,attr_name=state:_sdp_intergraph_downstream_node_handles_,attr_type=?,attr_port=?,attr_default=?,attr_extended_type=?),CreateNodeCommand(graph=?,node_path=/Render/PostProcess/SDGPipeline/Replicator_01_NodeWriterWriter_01,node_type=isaacsim.ros2.bridge.ROS2PublishImage,create_usd=True),CreateNodeCommand(graph=?,node_path=/Render/PostProcess/SDGPipeline/WriterSyncGate_04,node_type=omni.graph.action.RationalTimeSyncGate,create_usd=True),CreateAttrCommand(node=?,attr_name=state:_sdp_intergraph_downstream_node_handles_,attr_type=?,attr_port=?,attr_default=?,attr_extended_type=?),SelectPrims(old_selected_paths=?,new_selected_paths=?,expand_in_stage=True)'
2025-08-21T07:40:08Z [9,796ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  lib_isaacSim_buildBranch = 'HEAD'
2025-08-21T07:40:08Z [9,800ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  lib_isaacSim_buildDate = 'Thu Jul 31 02:50:55 2025 +0000'
2025-08-21T07:40:08Z [9,805ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  lib_isaacSim_buildHash = '184afb1'
2025-08-21T07:40:08Z [9,809ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  lib_isaacSim_buildRepo = 'https://gitlab-ci-token:glcbt-64_VDfMLKcrxVTx6vasJknB@gitlab-master.nvidia.com/omniverse/isaac/omni_isaac_sim.git'
2025-08-21T07:40:08Z [9,815ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  lib_isaacSim_buildVersion = '5.0.0-rc.45'
2025-08-21T07:40:08Z [9,819ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  lib_physx_buildBranch = 'HEAD'
2025-08-21T07:40:08Z [9,824ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  lib_physx_buildDate = 'Jul-23-2025'
2025-08-21T07:40:08Z [9,828ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  lib_physx_buildHash = '214216c'
2025-08-21T07:40:08Z [9,834ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  lib_physx_buildRepo = 'gitlab-master.nvidia.com/omniverse/physics'
2025-08-21T07:40:08Z [9,838ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  lib_physx_buildVersion = '107.3.18'
2025-08-21T07:40:08Z [9,843ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  memoryStats = '(avail/total) RAM: 230.758/251.262GB, Swap: 2/2GB, VM: 1.71799e+10/1.71799e+10GB'
2025-08-21T07:40:08Z [9,848ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  nvidia-smi = '
==============NVSMI LOG==============
Timestamp                                 : Thu Aug 21 15:33:58 2025
Driver Version                            : 580.65.06
CUDA Version                              : 13.0
Attached GPUs                             : 2
GPU 00000000:27:00.0
    Product Name                          : NVIDIA RTX 5000 Ada Generation
    Product Brand                         : NVIDIA RTX
    Product Architecture                  : Ada Lovelace
    Display Mode                          : Requested functionality has been deprecated
    Display Attached                      : Yes
    Display Active                        : Enabled
    Persistence Mode                      : Enabled
    Addressing Mode                       : None
    MIG Mode
        Current                           : N/A
        Pending                           : N/A
    Accounting Mode                       : Disabled
    Accounting Mode Buffer Size           : 4000
    Driver Model
        Current                           : N/A
        Pending                           : N/A
    Serial Number                         : 1324924077673
    GPU UUID                              : GPU-ce72f916-4b80-f908-2ab4-9799e726b9e2
    GPU PDI                               : 0x78ec0c1c1ac4d9c5
    Minor Number                          : 0
    VBIOS Version                         : 95.02.5E.00.04
    MultiGPU Board                        : No
    Board ID                              : 0x2700
    Board Part Number                     : 900-5G132-2740-001
    GPU Part Number                       : 26B2-850-A1
    FRU Part Number                       : N/A
    Platform Info
        Chassis Serial Number             : N/A
        Slot Number                       : N/A
        Tray Index                        : N/A
        Host ID                           : N/A
        Peer Type                         : N/A
        Module Id                         : 1
        GPU Fabric GUID                   : N/A
    Inforom Version
        Image Version                     : G132.0550.00.02
        OEM Object                        : 2.1
        ECC Object                        : 6.16
        Power Management Object           : N/A
    Inforom BBX Object Flush
        Latest Timestamp                  : 2025/08/21 15:24:41.870
        Latest Duration                   : 82514 us
    GPU Operation Mode
        Current                           : N/A
        Pending                           : N/A
    GPU C2C Mode                          : N/A
    GPU Virtualization Mode
        Virtualization Mode               : None
        Host VGPU Mode                    : N/A
        vGPU Heterogeneous Mode           : N/A
    GPU Recovery Action                   : None
    GSP Firmware Version                  : 580.65.06
    IBMNPU
        Relaxed Ordering Mode             : N/A
    PCI
        Bus                               : 0x27
        Device                            : 0x00
        Domain                            : 0x0000
        Base Classcode                    : 0x3
        Sub Classcode                     : 0x0
        Device Id                         : 0x26B210DE
        Bus Id                            : 00000000:27:00.0
        Sub System Id                     : 0x17FA17AA
        GPU Link Info
            PCIe Generation
                Max                       : 4
                Current                   : 1
                Device Current            : 1
                Device Max                : 4
                Host Max                  : 5
            Link Width
                Max                       : 16x
                Current                   : 16x
        Bridge Chip
            Type                          : N/A
            Firmware                      : N/A
        Replays Since Reset               : 0
        Replay Number Rollovers           : 0
        Tx Throughput                     : 9900 KB/s
        Rx Throughput                     : 9850 KB/s
        Atomic Caps Outbound              : N/A
        Atomic Caps Inbound               : N/A
    Fan Speed                             : 30 %
    Performance State                     : P8
    Clocks Event Reasons
        Idle                              : Active
        Applications Clocks Setting       : Not Active
        SW Power Cap                      : Not Active
        HW Slowdown                       : Not Active
            HW Thermal Slowdown           : Not Active
            HW Power Brake Slowdown       : Not Active
        Sync Boost                        : Not Active
        SW Thermal Slowdown               : Not Active
        Display Clock Setting             : Not Active
    Clocks Event Reasons Counters
        SW Power Capping                  : 60360896 us
        Sync Boost                        : 0 us
        SW Thermal Slowdown               : 0 us
        HW Thermal Slowdown               : 0 us
        HW Power Braking                  : 0 us
    Sparse Operation Mode                 : N/A
    FB Memory Usage
        Total                             : 32760 MiB
        Reserved                          : 540 MiB
        Used                              : 701 MiB
        Free                              : 31520 MiB
    BAR1 Memory Usage
        Total                             : 256 MiB
        Used                              : 13 MiB
        Free                              : 243 MiB
    Conf Compute Protected Memory Usage
        Total                             : 0 MiB
        Used                              : 0 MiB
        Free                              : 0 MiB
    Compute Mode                          : Default
    Utilization
        GPU                               : 0 %
        Memory                            : 0 %
        Encoder                           : 0 %
        Decoder                           : 0 %
        JPEG                              : 0 %
        OFA                               : 0 %
    Encoder Stats
        Active Sessions                   : 0
        Average FPS                       : 0
        Average Latency                   : 0
    FBC Stats
        Active Sessions                   : 0
        Average FPS                       : 0
        Average Latency                   : 0
    DRAM Encryption Mode
        Current                           : N/A
        Pending                           : N/A
    ECC Mode
        Current                           : Disabled
        Pending                           : Disabled
    ECC Errors
        Volatile
            SRAM Correctable              : N/A
            SRAM Uncorrectable Parity     : N/A
            SRAM Uncorrectable SEC-DED    : N/A
            DRAM Correctable              : N/A
            DRAM Uncorrectable            : N/A
        Aggregate
            SRAM Threshold Exceeded       : N/A
        Aggregate Uncorrectable SRAM Sources
            SRAM L2                       : N/A
            SRAM SM                       : N/A
            SRAM Microcontroller          : N/A
            SRAM PCIE                     : N/A
            SRAM Other                    : N/A
        Channel Repair Pending            : No
        TPC Repair Pending                : No
    Retired Pages
        Single Bit ECC                    : N/A
        Double Bit ECC                    : N/A
        Pending Page Blacklist            : N/A
    Remapped Rows
        Correctable Error                 : 0
        Uncorrectable Error               : 0
        Pending                           : No
        Remapping Failure Occurred        : No
        Bank Remap Availability Histogram
            Max                           : 128 bank(s)
            High                          : 0 bank(s)
            Partial                       : 0 bank(s)
            Low                           : 0 bank(s)
            None                          : 0 bank(s)
    Temperature
        GPU Current Temp                  : 52 C
        GPU T.Limit Temp                  : 34 C
        GPU Shutdown T.Limit Temp         : -7 C
        GPU Slowdown T.Limit Temp         : -2 C
        GPU Max Operating T.Limit Temp    : 0 C
        GPU Target Temperature            : 84 C
        Memory Current Temp               : N/A
        Memory Max Operating T.Limit Temp : N/A
    GPU Power Readings
        Average Power Draw                : 29.77 W
        Instantaneous Power Draw          : 28.94 W
        Current Power Limit               : 250.00 W
        Requested Power Limit             : 250.00 W
        Default Power Limit               : 250.00 W
        Min Power Limit                   : 100.00 W
        Max Power Limit                   : 250.00 W
    GPU Memory Power Readings
        Average Power Draw                : N/A
        Instantaneous Power Draw          : N/A
    Module Power Readings
        Current Power Limit               : N/A
        Requested Power Limit             : N/A
        Default Power Limit               : N/A
        Min Power Limit                   : N/A
        Max Power Limit                   : N/A
    Power Smoothing                       : N/A
    Workload Power Profiles
        Requested Profiles                : N/A
        Enforced Profiles                 : N/A
    Clocks
        Graphics                          : 210 MHz
        SM                                : 210 MHz
        Memory                            : 405 MHz
        Video                             : 1185 MHz
    Applications Clocks
        Graphics                          : 2550 MHz
        Memory                            : 9001 MHz
    Default Applications Clocks
        Graphics                          : 2550 MHz
        Memory                            : 9001 MHz
    Deferred Clocks
        Memory                            : N/A
    Max Clocks
        Graphics                          : 3105 MHz
        SM                                : 3105 MHz
        Memory                            : 9001 MHz
        Video                             : 2415 MHz
    Max Customer Boost Clocks
        Graphics                          : N/A
    Clock Policy
        Auto Boost                        : N/A
        Auto Boost Default                : N/A
    Fabric
        State                             : N/A
        Status                            : N/A
        CliqueId                          : N/A
        ClusterUUID                       : N/A
        Health
            Summary                       : N/A
            Bandwidth                     : N/A
            Route Recovery in progress    : N/A
            Route Unhealthy               : N/A
            Access Timeout Recovery       : N/A
            Incorrect Configuration       : N/A
    Processes
        GPU instance ID                   : N/A
        Compute instance ID               : N/A
        Process ID                        : 2454
            Type                          : G
            Used GPU Memory               : 206 MiB
        Process ID                        : 2794
            Type                          : G
            Used GPU Memory               : 234 MiB
        Process ID                        : 3986
            Type                          : G
            Used GPU Memory               : 125 MiB
        Process ID                        : 191152
            Type                          : G
            Used GPU Memory               : 84 MiB
    Capabilities
        EGM                               : disabled
GPU 00000000:38:00.0
    Display Attached                      : No
    Display Active                        : Disabled
    MIG Mode
        Current                           : N/A
        Pending                           : N/A
    Driver Model
        Current                           : N/A
        Pending                           : N/A
    Serial Number                         : 1324924078015
    GPU UUID                              : GPU-a219835d-2bfe-dfaf-e9cc-39ec858472aa
    GPU PDI                               : 0x402a98baf71f657b
    Minor Number                          : 1
    MultiGPU Board                        : No
    Board ID                              : 0x3800
    Platform Info
        Slot Number                       : N/A
        Tray Index                        : N/A
        Host ID                           : N/A
        Peer Type                         : N/A
        Module Id                         : 1
    Inforom Version
        OEM Object                        : 2.1
        ECC Object                        : 6.16
        Latest Timestamp                  : N/A
        Latest Duration                   : N/A
    GPU Operation Mode
        Current                           : N/A
        Pending                           : N/A
    GPU C2C Mode                          : N/A
    IBMNPU
    PCI
        Bus                               : 0x38
        Device                            : 0x00
        Domain                            : 0x0000
        Sub Classcode                     : 0x0
        Bus Id                            : 00000000:38:00.0
        GPU Link Info
            PCIe Generation
                Max                       : 4
                Current                   : 1
                Device Current            : 1
                Device Max                : 4
                Host Max                  : 5
            Link Width
                Max                       : 16x
                Current                   : 16x
        Bridge Chip
            Type                          : N/A
            Firmware                      : N/A
        Tx Throughput                     : 350 KB/s
        Rx Throughput                     : 600 KB/s
    Fan Speed                             : 30 %
        Idle                              : Active
        SW Power Capping                  : 41234 us
        Sync Boost                        : 0 us
    FB Memory Usage
        Total                             : 32760 MiB
        Reserved                          : 532 MiB
        Used                              : 18 MiB
        Free                              : 32212 MiB
    BAR1 Memory Usage
        Total                             : 256 MiB
        Used                              : 3 MiB
        Free                              : 253 MiB
        Total                             : 0 MiB
        Used                              : 0 MiB
        Free                              : 0 MiB
    Utilization
        GPU                               : 0 %
        Memory                            : 0 %
        Encoder                           : 0 %
        Decoder                           : 0 %
        JPEG                              : 0 %
        OFA                               : 0 %
    Encoder Stats
        Active Sessions                   : 0
        Average FPS                       : 0
        Average Latency                   : 0
    FBC Stats
        Active Sessions                   : 0
        Average FPS                       : 0
        Average Latency                   : 0
        Current                           : N/A
        Pending                           : N/A
    ECC Mode
        Current                           : Disabled
        Pending                           : Disabled
    ECC Errors
        Volatile
        Aggregate
            SRAM L2                       : N/A
            SRAM SM                       : N/A
            SRAM PCIE                     : N/A
            SRAM Other                    : N/A
    Retired Pages
    Remapped Rows
        Pending                           : No
            Max                           : 128 bank(s)
            High                          : 0 bank(s)
            Partial                       : 0 bank(s)
            Low                           : 0 bank(s)
            None                          : 0 bank(s)
    Temperature
        GPU Current Temp                  : 45 C
        GPU T.Limit Temp                  : 40 C
    GPU Power Readings
        Average Power Draw                : 16.93 W
        Instantaneous Power Draw          : 16.92 W
    Clocks
        Graphics                          : 210 MHz
        SM                                : 210 MHz
        Memory                            : 405 MHz
        Video                             : 1185 MHz
    Applications Clocks
        Graphics                          : 2550 MHz
        Memory                            : 9001 MHz
        Graphics                          : 2550 MHz
        Memory                            : 9001 MHz
    Deferred Clocks
        Memory                            : N/A
    Max Clocks
        Graphics                          : 3105 MHz
        SM                                : 3105 MHz
        Memory                            : 9001 MHz
        Video                             : 2415 MHz
        Graphics                          : N/A
    Clock Policy
        Auto Boost                        : N/A
    Fabric
        State                             : N/A
        Status                            : N/A
        CliqueId                          : N/A
        ClusterUUID                       : N/A
        Health
            Summary                       : N/A
            Bandwidth                     : N/A
    Processes
        Process ID                        : 2454
            Type                          : G
            Used GPU Memory               : 4 MiB
    Capabilities
        EGM                               : disabled
2025-08-21T07:40:08Z [9,853ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  osDistro = 'ubuntu'
2025-08-21T07:40:08Z [9,858ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  osName = '22.04.5 LTS (Jammy Jellyfish)'
2025-08-21T07:40:08Z [9,863ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  osVersion = '22.04.5'
2025-08-21T07:40:08Z [9,867ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  portableMode = '0'
2025-08-21T07:40:08Z [9,872ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  primaryDisplayRes = '1920x1080x32bit@60Hz'
2025-08-21T07:40:08Z [9,877ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  runEnvironment = 'Individual'
2025-08-21T07:40:08Z [9,882ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  runningInContainer = '0'
2025-08-21T07:40:08Z [9,886ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  shaderdb_debugSymbols = '0'
2025-08-21T07:40:08Z [9,891ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  shaderdb_dumpIncludeOverrides = '0'
2025-08-21T07:40:08Z [9,896ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  shaderdb_dumpIntermediates = '0'
2025-08-21T07:40:08Z [9,901ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  shaderdb_obfuscateCode = '1'
2025-08-21T07:40:08Z [9,905ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  shaderdb_optimizationLevel = '1'
2025-08-21T07:40:08Z [9,911ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  systemInfo = '
| Driver Version: 580.65.06     | Graphics API: Vulkan
| GPU | Name                             | Active | LDA | GPU Memory | Vendor-ID | LUID       |
|     |                                  |        |     |            | Device-ID | UUID       |
|     |                                  |        |     |            | Bus-ID    |            |
| 0   | NVIDIA RTX 5000 Ada Generation   | Yes: 0 |     | 33006   MB | 10de      | 0          |
|     |                                  |        |     |            | 26b2      | ce72f916.. |
|     |                                  |        |     |            | 27        |            |
| 1   | NVIDIA RTX 5000 Ada Generation   | Yes: 1 |     | 33006   MB | 10de      | 0          |
|     |                                  |        |     |            | 26b2      | a219835d.. |
|     |                                  |        |     |            | 38        |            |
| OS: 22.04.5 LTS (Jammy Jellyfish) ubuntu, Version: 22.04.5, Kernel: 6.8.0-65-generic
| XServer Vendor: The X.Org Foundation, XServer Version: 12101004 (1.21.1.4)
| Processor: INTEL(R) XEON(R) GOLD 6530
| Cores: 64 | Logical Cores: 128
| Total Memory (MB): 257291 | Free Memory: 247099
| Total Page/Swap (MB): 2047 | Free Page/Swap: 2047
2025-08-21T07:40:08Z [9,915ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  telemetrySessionId = '7790943244257202327'
2025-08-21T07:40:08Z [9,920ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  terminatedByAbort = '0'
2025-08-21T07:40:08Z [9,925ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  totalRamBareMetalMB = '257291'
2025-08-21T07:40:08Z [9,930ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  totalRamLimitedMB = '257291'
2025-08-21T07:40:08Z [9,934ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  totalSwapBareMetalMB = '2047'
2025-08-21T07:40:08Z [9,939ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  totalSwapLimitedMB = '2047'
2025-08-21T07:40:08Z [9,944ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  userId = 'default'
2025-08-21T07:40:08Z [9,949ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  workingDirectory = '/home/<username>/isaacsim'
2025-08-21T07:40:08Z [9,953ms] [Fatal] [carb.crashreporter-breakpad.plugin] [crash] Thread 1395389 backtrace follows:
2025-08-21T07:40:08Z [10,018ms] [Fatal] [carb.crashreporter-breakpad.plugin] 000: libc.so.6!__sigaction+0x50 (libc_sigaction.c:?)
2025-08-21T07:40:08Z [10,030ms] [Fatal] [carb.crashreporter-breakpad.plugin] 001: libgpu.foundation.plugin.so!carbOnPluginStartup+0x4374 (??:?)
2025-08-21T07:40:08Z [10,040ms] [Fatal] [carb.crashreporter-breakpad.plugin] 002: libomni.kit.renderer.plugin.so!carbOnPluginPreStartup+0x5ee4 (??:?)
2025-08-21T07:40:08Z [10,049ms] [Fatal] [carb.crashreporter-breakpad.plugin] 003: libomni.kit.renderer.plugin.so!carbOnPluginPreStartup+0x6803 (??:?)
2025-08-21T07:40:08Z [10,060ms] [Fatal] [carb.crashreporter-breakpad.plugin] 004: libcarb.eventdispatcher.plugin.so!carbOnPluginRegisterEx+0x3441 (??:?)
2025-08-21T07:40:08Z [10,069ms] [Fatal] [carb.crashreporter-breakpad.plugin] 005: libomni.kit.loop-isaac.plugin.so!void std::__detail::__to_chars_10_impl<unsigned int>(char*, unsigned int, unsigned int)+0x1a48d (??:?)
2025-08-21T07:40:08Z [10,080ms] [Fatal] [carb.crashreporter-breakpad.plugin] 006: libomni.kit.app.plugin.so!+0x235e1
2025-08-21T07:40:08Z [10,091ms] [Fatal] [carb.crashreporter-breakpad.plugin] 007: libomni.kit.app.plugin.so!carbOnPluginPreStartup+0x1fa0 (??:?)
2025-08-21T07:40:08Z [10,096ms] [Fatal] [carb.crashreporter-breakpad.plugin] 008: kit!+0x3cd3
2025-08-21T07:40:08Z [10,150ms] [Fatal] [carb.crashreporter-breakpad.plugin] 009: libc.so.6!__libc_init_first+0x90 (./csu/../sysdeps/nptl/libc_start_call_main.h:58)
2025-08-21T07:40:08Z [10,199ms] [Fatal] [carb.crashreporter-breakpad.plugin] 010: libc.so.6!__libc_start_main+0x80 (./csu/../csu/libc-start.c:128)
2025-08-21T07:40:08Z [10,205ms] [Fatal] [carb.crashreporter-breakpad.plugin] 011: kit!_start+0x25 (??:?)
Since the case I made by my self with ROS2 followed by the tutorial can run well without any problem, I just doubted whether these examples are not compatible in Isaac 5.0.0. How can I check or handle this problem?
Please create a new topic and mention this one. It will allow us to provide more focused support for your specific issue, as the original thread is an older discussion about a different version of Isaac Sim.
Please try reproducing this issue with the official Docker container from the upcoming Isaac Sim 5.1.0 GA release.
If the problem persists after upgrading, please share the the complete log output so it can be reviewed in more detail.
I experienced a lot of crashes with driver 580 / CUDA 13. After downgrading to 570 / CUDA 12.8, the system was stable and I could run all the navigation examples (with ROS2 Humble, not Jazzy)
Thanks for sharing your experience from your Isaac Sim 5.0.0 setup. Your findings about crash behavior with more recent drivers really help reaffirm the issues reported in this thread. I also noticed your results are very similar to what’s described in Isaac Sim detects wrong driver version on Ubuntu 24.04 with RTX 4060 Laptop - #2 by akhandveergarg.
Hello!
Best regards,
