Isaac Sim installation error
I’m having problems installing Isaac Sim on my PC. When I try to install Isaac Sim on Omniverse I get following error:
Error occurred during installation of Isaac Sim: Command failed: “/home/mario/.local/share/isaac_sim-2021.2.1/omni.isaac.sim.post.install.sh”
ln: failed to create symbolic link ‘extension_examples/examples’: File exists
I apologize in advance if it is some banal problem, but I have little experience with Omniverse, and a little bit of help would do.
Thank you
Hi try uninstalling that version of Isaac Sim then remove the folder below if it exists.
Next reinstall Isaac Sim.
It worked! Thank you very much!
I meet the same issue . I delete the isaac_sim-2021.2.1 folder and reinstall on omniverse , but the issue occurs again
@fzg7919 Please share your installation log file with the error.
Here’s the path to the log file:
~/.nvidia-omniverse/logs/launcher.log
thanks here is the log:
launcher.log (552.5 KB)
and my isaacsim folder path is : /home/narwal/.local/share/ov/pkg/isaac_sim-2021.2.1
this is no isaacsim folder under " /home/narwal/.local/share"
Try uninstalling Isaac Sim then remove the folder below if it still exists:
Then re-install Isaac Sim.
