Topic Description
I need to utilize Isaac Sim with an RTX LiDAR Sensor to correctly simulate the interaction with objects that are absorptive or highly reflective. My hope is that the point cloud I see will be either sparse or highly noisy for that specific object.
I am modelling my Lidar on the HESAI JT128 Lidar. This is my config:
def OmniLidar "JT_128_10hz" (
apiSchemas = ["OmniSensorGenericLidarCoreAPI"]
float omni:sensor:Core:avgPowerW = 0.002
float omni:sensor:Core:azimuthErrorMean = 0
float omni:sensor:Core:azimuthErrorStd = 0.03
float omni:sensor:Core:elevationErrorMean = 0
float omni:sensor:Core:elevationErrorStd = 0.03
float[] omni:sensor:Core:emitterState:s001:azimuthDeg = [-1.08, -9.71, -1.09, -9.71, -1.10, -9.72, -1.12, -9.73, 2.69, 11.33, 2.68, 11.34, 2.68, 11.36, 2.68, 11.39, -1.19, -9.92, -1.21, -9.98, -1.22, -10.04, -1.24, -10.11, 2.50, 11.47, 2.51, 11.56, 2.52, 11.65, 2.54, 11.75, -1.33, -10.60, -1.35, -10.71, -1.37, -10.84, -1.39, -10.97, 2.64, 12.39, 2.67, 12.55, 2.70, 12.71, 2.73, 12.89, -1.51, -11.77, -1.54, -11.96, -1.57, -12.15, -1.60, -12.36, 2.94, 13.96, 2.98, 14.21, 3.04, 14.48, 3.09, 14.76, -1.77, -13.62, -1.80, -13.91, -1.85, -14.22, -1.89, -14.55, 3.44, 16.55, 3.53, 16.98, 3.62, 17.43, 3.72, 17.92, -2.14, -16.65, -2.20, -17.16, -2.26, -17.70, -2.33, -18.30, 4.37, 21.24, 4.54, 22.06, 4.73, 22.96, 4.93, 23.96, -2.77, -22.52, -2.88, -23.61, -3.01, -24.83, -3.15, -26.20, 6.43, 32.52, 6.87, 34.78, 7.39, 37.40, 8.01, 40.46, -4.25, -41.40, -4.60, -45.72, -5.04, -50.95, -5.61, -57.28, 26.63, 31.42, 38.15, 47.90, -6.32, -0.86, 18.19, 117.30]
uint[] omni:sensor:Core:emitterState:s001:channelId = [1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128]
float[] omni:sensor:Core:emitterState:s001:distanceCorrectionM = [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]
float[] omni:sensor:Core:emitterState:s001:elevationDeg = [-4.43, -3.50, -2.55, -1.65, -0.75, 0.13, 0.99, 1.85, 2.64, 3.46, 4.29, 5.09, 5.91, 6.69, 7.49, 8.25, 9.08, 9.84, 10.59, 11.34, 12.08, 12.81, 13.54, 14.26, 15.11, 15.83, 16.53, 17.23, 17.93, 18.62, 19.31, 19.99, 20.71, 21.38, 22.07, 22.73, 23.42, 24.07, 24.76, 25.40, 26.06, 26.73, 27.39, 28.05, 28.71, 29.35, 30.02, 30.66, 31.37, 32.05, 32.68, 33.34, 33.99, 34.63, 35.29, 35.92, 36.56, 37.23, 37.86, 38.51, 39.15, 39.79, 40.45, 41.07, 41.78, 42.47, 43.08, 43.75, 44.37, 45.02, 45.67, 46.29, 46.93, 47.65, 48.23, 48.91, 49.53, 50.18, 50.82, 51.44, 52.17, 52.84, 53.47, 54.11, 54.78, 55.38, 56.09, 56.66, 57.36, 58.11, 58.68, 59.37, 60.00, 60.64, 61.33, 61.90, 62.71, 63.44, 64.06, 64.72, 65.41, 66.00, 66.78, 67.29, 68.10, 69.12, 69.49, 70.36, 70.89, 71.58, 72.32, 72.77, 73.88, 75.22, 75.36, 76.40, 76.87, 77.51, 78.41, 78.51, 79.62, 81.04, 82.40, 83.64, 85.36, 87.02, 88.64, 88.99]
uint[] omni:sensor:Core:emitterState:s001:fireTimeNs = [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]
float[] omni:sensor:Core:emitterState:s001:focalDistM = [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]
float[] omni:sensor:Core:emitterState:s001:focalSlope = [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]
float[] omni:sensor:Core:emitterState:s001:horOffsetM = [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]
float[] omni:sensor:Core:emitterState:s001:reportRateDiv = [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]
float[] omni:sensor:Core:emitterState:s001:vertOffsetM = [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]
float omni:sensor:Core:farRangeM = 60
float omni:sensor:Core:focusDistM = 0.3
token omni:sensor:Core:intensityMappingType = "LINEAR"
token omni:sensor:Core:intensityProcessing = "NORMALIZATION"
uint omni:sensor:Core:maxReturns = 2
float omni:sensor:Core:minReflectance = 0.1
float omni:sensor:Core:minReflectionRangeM = 40
float omni:sensor:Core:nearRangeM = 0.3
uint omni:sensor:Core:numberOfChannels = 128
uint omni:sensor:Core:numberOfEmitters = 128
uint omni:sensor:Core:pulseTimeNs = 10
float omni:sensor:Core:rangeAccuracyM = 0.03
float omni:sensor:Core:rangeResolutionM = 0.004
token omni:sensor:Core:rayType = "IDEALIZED"
uint omni:sensor:Core:reportRateBaseHz = 36000
token omni:sensor:Core:rotationDirection = "CW"
uint omni:sensor:Core:scanRateBaseHz = 20
token omni:sensor:Core:scanType = "ROTARY"
bool omni:sensor:Core:skipDroppingInvalidPoints = 1
float omni:sensor:Core:waveLengthNm = 905
string omni:sensor:modelName = "JT_128_10hz"
float omni:sensor:tickRate = 20
token ui:displayGroup = "Material Graphs"
token ui:displayName = "JT_128_10hz"
int ui:order = 1024
float3 xformOp:rotateXYZ = (0, 0, 0)
float3 xformOp:scale = (1, 1, 1)
double3 xformOp:translate = (0, 0, 0.04784)
uniform token[] xformOpOrder = ["xformOp:translate", "xformOp:rotateXYZ", "xformOp:scale"]
I followed the instructions step by step to set the nodes and the Non Visual Materials but the Point Cloud looks the same no matter what material I apply to the object. Including the flags mentioned.
-–/app/sensors/nv/lidar/enableRtxReflectanceInformation=True
--/app/sensors/nv/lidar/enableAdditionalRtxReturnInformation=True
--/app/sensors/nv/lidar/enableRtxSensorGeometry=True
--/app/sensors/nv/lidar/enablePolarization=True
--/app/sensors/nv/materials/resetMaterials=True
--/app/sensors/nv/materials/enableMaterialInterLayerContribution=True
I am the running Isaac Sim 5.1.0 executable on ubuntu 22.04 with ROS Humble.
