Thanks for the guidance. I have one clarification regarding the SS capacitor.
In the P3768_A04 base schematic (DevKit), I found two capacitors in this area:
C309 = 47 nF / 16 V, connected directly from the SS pin to GND.
C312 = 1 nF / 16 V, connected to the SW-side circuitry, not directly to the SS pin.
Since the instruction specifically mentions removing C312 and checking the SS pin voltage, could you please confirm whether C312 is actually the intended SS capacitor, or should I remove C309 (47 nF), which is directly connected to the SS pin?
I want to make sure I remove the correct capacitor before performing the test.
Since SS remains at 0V even with C309 removed, the internal soft-start current source inside the IC is not functioning. I assume this points to an IC-level issue.
Recommended next steps:
Confirm the exact P/N of the regulator IC mounted on your board — check the marking on the IC package and compare it against the P/N used in the P3768_A04 reference design
Verify the pin mapping of your IC against its datasheet
Verify surrounding passive components — confirm that all resistor/capacitor values around the regulator match the reference design (especially feedback divider, bootstrap, and soft-start)
If all of the above check out, there may be a cold solder joint issue — try reflowing the IC and surrounding passives on one board and re-test
I verified the IC part number and footprint, and both match the IC used on the development board. Before proceeding with the remaining verification, I captured new waveforms at the SW node from the inductor pad(DNP) and at VDD_5_SYS from the capacitor side. Please verify these waveforms as well.
I have verified the IC part marking and compared the pin-to-pin connections with both the development board and the datasheet. I also measured the resistor values on the board using a multimeter, and they appear to be correct.
My main concern is how the same IC-related issue could occur on all five boards. Since the issue is present on all five boards, I am wondering if there could be another problem in the surrounding power circuitry rather than the IC itself.
I am attaching the power section schematic for reference. If anyone could review the schematic and help identify any possible issues or incorrect connections, it would be very helpful.
We reviewed the 5 V regulator circuit around U1 in your schematic and did not identify any discrepancies in the connections, pin assignments, or nominal component values compared with U3 in the P3768-A04 reference design.
At this stage, we are unable to determine the root cause of the startup issue from the schematic and measurement results provided. We recommend contacting GStek, the manufacturer of the GS9230NVTQ-R, for detailed debugging support.
