Issue with box in palletizing example
Trying to replace the bin/tote in the UR10 palletizing example with a package and can’t seem to get it to work. Not sure if it’s an issue with the lighting since it does seem to look different. Here is where I set up the box in the code:
     if spawn_new:
         name = "bin_{}".format(len(self.bins))
         prim_path = self.env_path + "/bins/{}".format(name)
         add_reference_to_stage(usd_path=self.assets.small_klt_usd, prim_path=prim_path)
         from pxr import UsdPhysics, Gf
         stage = self.scene.stage
         prim = stage.GetPrimAtPath(prim_path)
         if not prim.IsValid():
             raise RuntimeError(f"Prim at path {prim_path} is not valid.")
         rigid_body_api = UsdPhysics.RigidBodyAPI.Get(stage, prim_path)
         if not rigid_body_api:
             UsdPhysics.RigidBodyAPI.Apply(prim)
         if not UsdPhysics.CollisionAPI.Get(stage, prim.GetPath()):
             UsdPhysics.CollisionAPI.Apply(prim)
             UsdPhysics.MeshCollisionAPI.Apply(prim)
         colliders = prim.GetChildren()
         if not colliders:
             collider_prim_path = prim.GetPath().AppendChild("collider")
             collider_prim = stage.DefinePrim(collider_prim_path, "Cube")
             UsdPhysics.CollisionAPI.Apply(collider_prim)
             UsdPhysics.MeshCollisionAPI.Apply(collider_prim)
         if not UsdPhysics.MaterialAPI.Get(stage, prim.GetPath()):
             material = UsdPhysics.MaterialAPI.Apply(prim)
             material.GetStaticFrictionAttr().Set(0.8)  # Set static friction
             material.GetDynamicFrictionAttr().Set(0.5)
         rigid_body_api = UsdPhysics.RigidBodyAPI.Get(stage, prim.GetPath())
         mass_api = UsdPhysics.MassAPI.Get(stage, prim.GetPath())
         if not mass_api:
             mass_api = UsdPhysics.MassAPI.Apply(prim)
         self.on_conveyor = self.scene.add(CortexRigidPrim(name=name, prim_path=prim_path))
         self.on_conveyor.set_local_scale([.005,.008,.005])
         self._spawn_bin(self.on_conveyor)
         self.bins.append(self.on_conveyor)
And a video of what is happening.
when you say “it looks different” and might be an “issue with the lighting”, are you concerned mostly about the visual looks of the package? or are you concerned about the failed pickup?
If it’s the former, it hard to tell without knowing more about the asset itself. You can attach it here and we can take a look on our end. and also a reference of what you are expecting it to look like.
If you are concerned about the pickup. It looks like the suction gripper is hitting the edge of the package. You can potentially test this theory by either make a wider box (if you don’t want to change any of the code), or move the grasp point to be in the middle of the package.
Hi qwan, thanks for your response. The concern is the failed pickup. Is there a place in the code to change where suction is? I’ve tried wider box already and that seemed to fail.
I’ll put the full code below.
# Copyright (c) 2021-2023, NVIDIA CORPORATION. All rights reserved.
# NVIDIA CORPORATION and its licensors retain all intellectual property
# and proprietary rights in and to this software, related documentation
# and any modifications thereto. Any use, reproduction, disclosure or
# distribution of this software and related documentation without an express
# license agreement from NVIDIA CORPORATION is strictly prohibited.
import random
import numpy as np
import omni
import omni.isaac.cortex.math_util as math_util
from omni.isaac.core.objects.capsule import VisualCapsule
from omni.isaac.core.objects.sphere import VisualSphere
from omni.isaac.core.prims.xform_prim import XFormPrim
from omni.isaac.core.tasks.base_task import BaseTask
from omni.isaac.core.utils.rotations import euler_angles_to_quat
from omni.isaac.core.utils.stage import add_reference_to_stage
from omni.isaac.cortex.cortex_rigid_prim import CortexRigidPrim
from omni.isaac.cortex.cortex_utils import get_assets_root_path
from omni.isaac.cortex.robot import CortexUr10
from omni.isaac.cortex.sample_behaviors.ur10 import bin_stacking_behavior as behavior
from omni.isaac.examples.cortex.cortex_base import CortexBase
class Ur10Assets:
    def __init__(self):
        self.assets_root_path = get_assets_root_path()
        self.ur10_table_usd = (
            self.assets_root_path + "/Isaac/Samples/Leonardo/Stage/ur10_bin_stacking_short_suction.usd"
        self.small_klt_usd = self.assets_root_path + "/Isaac/Props/KLT_Bin/small_KLT.usd"
        self.background_usd = self.assets_root_path + "/Isaac/Environments/Simple_Warehouse/warehouse.usd"
        self.rubiks_cube_usd = self.assets_root_path + "/Isaac/Props/Rubiks_Cube/rubiks_cube.usd"
def random_bin_spawn_transform():
    x = random.uniform(-0.15, 0.15)
    y = 1.5
    z = -0.15
    position = np.array([x, y, z])
    z = random.random() * 0.02 - 0.01
    w = random.random() * 0.02 - 0.01
    norm = np.sqrt(z**2 + w**2)
    quat = math_util.Quaternion([w / norm, 0, 0, z / norm])
    if random.random() > 0.5:
        print("<flip>")
        # flip the bin so it's upside down
        quat = quat * math_util.Quaternion([0, 0, 1, 0])
    else:
        print("<no flip>")
    return position, quat.vals
class BinStackingTask(BaseTask):
    def __init__(self, env_path, assets) -> None:
        super().__init__("bin_stacking")
        self.assets = assets
        self.env_path = env_path
        self.bins = []
        self.stashed_bins = []
        self.on_conveyor = None
    def _spawn_bin(self, rigid_bin):
        x, q = random_bin_spawn_transform()
        rigid_bin.set_world_pose(position=x, orientation=q)
        rigid_bin.set_linear_velocity(np.array([0, -0.30, 0]))
        rigid_bin.set_visibility(True)
    def post_reset(self) -> None:
        if len(self.bins) > 0:
            for rigid_bin in self.bins:
                self.scene.remove_object(rigid_bin.name)
            self.bins.clear()
    def pre_step(self, time_step_index, simulation_time) -> None:
        """Spawn a new randomly oriented bin if the previous bin has been placed."""
        spawn_new = False
        if self.on_conveyor is None:
            spawn_new = True
        else:
            (x, y, z), _ = self.on_conveyor.get_world_pose()
            is_on_conveyor = y > 0.0 and -0.4 < x and x < 0.4
            if not is_on_conveyor:
                spawn_new = True
        if spawn_new:
    def world_cleanup(self):
        self.bins = []
        return
class BinStacking(CortexBase):
    def __init__(self, monitor_fn=None):
        super().__init__()
        self._monitor_fn = monitor_fn
        self.robot = None
    def setup_scene(self):
        world = self.get_world()
        env_path = "/World/Ur10Table"
        ur10_assets = Ur10Assets()
        add_reference_to_stage(usd_path=ur10_assets.ur10_table_usd, prim_path=env_path)
        add_reference_to_stage(usd_path=ur10_assets.background_usd, prim_path="/World/Background")
        background_prim = XFormPrim(
            "/World/Background", position=[10.00, 2.00, -1.18180], orientation=[0.7071, 0, 0, 0.7071]
        self.robot = world.add_robot(CortexUr10(name="robot", prim_path="{}/ur10".format(env_path)))
        obs = world.scene.add(
            VisualSphere(
                "/World/Ur10Table/Obstacles/FlipStationSphere",
                name="flip_station_sphere",
                position=np.array([0.73, 0.76, -0.13]),
                radius=0.2,
                visible=False,
        self.robot.register_obstacle(obs)
            VisualSphere(
                "/World/Ur10Table/Obstacles/NavigationDome",
                name="navigation_dome_obs",
                position=[-0.031, -0.018, -1.086],
                radius=1.1,
                visible=False,
        az = np.array([1.0, 0.0, -0.3])
        ax = np.array([0.0, 1.0, 0.0])
        ay = np.cross(az, ax)
        R = math_util.pack_R(ax, ay, az)
        quat = math_util.matrix_to_quat(R)
            VisualCapsule(
                "/World/Ur10Table/Obstacles/NavigationBarrier",
                name="navigation_barrier_obs",
                position=[0.471, 0.276, -0.463 - 0.1],
                orientation=quat,
                radius=0.5,
                height=0.9,
                visible=False,
            VisualCapsule(
                "/World/Ur10Table/Obstacles/NavigationFlipStation",
                name="navigation_flip_station_obs",
                position=np.array([0.766, 0.755, -0.5]),
                radius=0.5,
                height=0.5,
                visible=False,
    async def setup_post_load(self):
        if not self.robot:
            self.robot = world._robots["robot"]
            world._current_tasks.clear()
            world._behaviors.clear()
            world._logical_state_monitors.clear()
        self.task = BinStackingTask(env_path, ur10_assets)
        print(world.scene)
        self.task.set_up_scene(world.scene)
        world.add_task(self.task)
        self.decider_network = behavior.make_decider_network(self.robot, self._on_monitor_update)
        world.add_decider_network(self.decider_network)
        return
    def _on_monitor_update(self, diagnostics):
        decision_stack = ""
        if self.decider_network._decider_state.stack:
            decision_stack = "\n".join(
                    "{0}{1}".format("  " * i, element)
                    for i, element in enumerate(str(i) for i in self.decider_network._decider_state.stack)
        if self._monitor_fn:
            self._monitor_fn(diagnostics, decision_stack)
    def _on_physics_step(self, step_size):
        world.step(False, False)
        return
    async def on_event_async(self):
        await omni.kit.app.get_app().next_update_async()
        world.reset_cortex()
        world.add_physics_callback("sim_step", self._on_physics_step)
        await world.play_async()
        return
    async def setup_pre_reset(self):
        if world.physics_callback_exists("sim_step"):
            world.remove_physics_callback("sim_step")
        return
        return
The code for finding the grasp point on the bin is in omni.isaac.cortex.sample_behaviors.bin_stacking_behavior.py, inside the method monitor_active_bin_grasp_T().
The general idea is that the target pose for the gripper is saved to the self.active_bin.grasp_T variable. To find this pose, monitor_active_bin_grasp_T() is dynamically finding the world_pose of the bin, figuring out if it’s facing up or down, as well as its orientation, and add a little margin above the suction surface for clearance. This is based on some characteristics that’s specific to the bin used in the demo, such as the location of the origin frame and the fact the thickness of the bin wall is fairly small. You can hardcode some numbers inside this method to match your asset. You can also potentially add a reference frame as the grasp point in your asset saved as part of the USD, so that inside this function, you can just retrieve the pose of this frame and directly get your pose (or the negative of it if upside down is a possibility).
Oh gotcha, I’m seeing the sample behavior as an import is there a way to access that file?
it should be in <isaacsim_install_location>/exts/omni.isaac.cortex.sample_behaviors/omni/isaac/cortex/sample_behaviors/ur10/bin_stacking_behavior.py
If you don’t know where your isaacsim is installed, the easiest way to get that is open one of the examples from the menu, like “Isaac Examples → Hello World”, there’s a folder icon on the upper right hand corner, clicking on that will open the folder that contains the “hello world” example code, which should be in <isaacsim_install_location>/exts/omni.isaac.examples/omni/isaac/examples/hello_world. So you can just crawl back up through the tree and find the folder that contains omni.isaac.cortex.sample_behaviors
Awesome, thanks. Would any other function need to be changed?
