We’d like to run the demo on the below webiner by Andrei Haidu .
Could you tell us where can we get those below python code?
Best regards,
Best regards,
Hi there,
here is the script from the webinar. The 2023.1.0 Isaac Sim release will include an updated version as well.
import asyncio
import json
import os
import carb
import numpy as np
import omni.physx as _physx
import omni.timeline
import omni.usd
from omni.isaac.core.utils.bounds import create_bbox_cache
from omni.isaac.kit.utils import set_carb_setting
from omni.physx import get_physx_scene_query_interface
from PIL import Image
class PalletizingDemo:
def __init__(self):
# Iterate through all 36 bins
self._stage = None
self._bin_counter = 0
self._active_bin = None
# Flag the state of the simulation
self._bin_holder_scenario_done = False
self._replicator_running = False
# Track the state of the active bin (e.g., incontact with pallet)
self._physx_sub = None
self._overlap_update_timer = 0.0
self._overlap_update_rate = 1.0
self._overlap_extent = None
# Pause / resume palletizing simulation
self._timeline = None
# Output directory for the data
self._output_dir = os.path.join(os.getcwd(), "_out_demo", "")
def start(self):
self._init()
self._physx_sub = _physx.get_physx_interface().subscribe_physics_step_events(self._on_physics_step)
print("Starting palletizing demo")
def _init(self):
self._stage = omni.usd.get_context().get_stage()
self._active_bin = self._stage.GetPrimAtPath(f"/environments/env/bins/bin_{self._bin_counter}")
bb_cache = create_bbox_cache()
half_ext = bb_cache.ComputeLocalBound(self._active_bin).GetRange().GetSize() * 0.5
self._overlap_extent = carb.Float3(half_ext[0] * 1.1, half_ext[1] * 1.1, half_ext[2] * 1.1)
self._timeline = omni.timeline.get_timeline_interface()
def _on_physics_step(self, dt):
self._overlap_update_timer += dt
if self._overlap_update_timer > self._overlap_update_rate:
self._check_bin_overlaps()
def _check_bin_overlaps(self):
bin_pose = omni.usd.utils.get_world_transform_matrix(self._active_bin)
origin = bin_pose.ExtractTranslation()
quat_gf = bin_pose.ExtractRotation().GetQuaternion()
hit_info = get_physx_scene_query_interface().overlap_box(
carb.Float3(self._overlap_extent),
carb.Float3(origin[0], origin[1], origin[2]),
carb.Float4(
quat_gf.GetImaginary()[0], quat_gf.GetImaginary()[1], quat_gf.GetImaginary()[2], quat_gf.GetReal()
self._on_overlap_hit,
False, # 'False' to indicate an 'overlap multiple' query
def _on_overlap_hit(self, hit):
if self._replicator_running:
return False # return False to stop the query
self_hit = hit.rigid_body == self._active_bin.GetPrimPath()
if self_hit:
return True # return True to continue the query
bin_holder_hit = hit.rigid_body.startswith("/environments/env/pallet_holder")
if bin_holder_hit and not self._bin_holder_scenario_done:
self._replicator_running = True
asyncio.ensure_future(self._run_bin_holder_scenario())
return False
pallet_hit = hit.rigid_body.startswith("/environments/env/pallet/Xform/Mesh_015")
other_bin_hit = hit.rigid_body.startswith("/environments/env/bins/bin_")
if pallet_hit or other_bin_hit:
asyncio.ensure_future(self._run_pallet_scenario())
return False
return True
async def _run_bin_holder_scenario(self):
print(f"Running bin holder scenario for bin {self._bin_counter}..")
# Util function to save rgb images to file
def save_img(rgb_data, filename):
rgb_image_data = np.frombuffer(rgb_data, dtype=np.uint8).reshape(*rgb_data.shape, -1)
rgb_img = Image.fromarray(rgb_image_data, "RGBA")
rgb_img.save(filename + ".png")
self._timeline.pause()
self.create_bin_holder_graph()
self._switch_to_pathtracing()
rgb_annot = rep.AnnotatorRegistry.get_annotator("rgb")
is_annot = rep.AnnotatorRegistry.get_annotator("instance_segmentation", init_params={"colorize": True})
rp = rep.create.render_product("/Replicator/Camera_Xform/Camera", (512, 512))
rgb_annot.attach([rp])
is_annot.attach([rp])
out_dir = os.path.join(self._output_dir, f"annot_bin_{self._bin_counter}", "")
os.makedirs(out_dir, exist_ok=True)
for i in range(4):
await rep.orchestrator.step_async(pause_timeline=False)
rgb_data = rgb_annot.get_data()
rgb_filename = f"{out_dir}rgb_{i}"
save_img(rgb_data, rgb_filename)
is_data = is_annot.get_data()
is_filename = f"{out_dir}is_{i}"
is_img_data = is_data["data"]
height, width = is_img_data.shape[:2]
is_img_data = is_img_data.view(np.uint8).reshape(height, width, -1)
save_img(is_img_data, is_filename)
is_info = is_data["info"]
with open(f"{out_dir}is_info_{i}.json", "w") as f:
json.dump(is_info, f, indent=4)
rgb_annot.detach([rp])
is_annot.detach([rp])
await rep.orchestrator.stop_async()
self._switch_to_raytracing()
self._stage.RemovePrim("/Replicator")
self._bin_holder_scenario_done = True
self._timeline.play()
def create_bin_holder_graph(self):
color_palette = [(1, 0, 0), (0, 1, 0), (0, 0, 1)]
def randomize_bin_holder_lights():
lights = rep.create.light(
light_type="Sphere",
temperature=rep.distribution.normal(6500, 2000),
intensity=rep.distribution.normal(95000, 15000),
position=rep.distribution.uniform((0.25, 0.25, 0.5), (1, 1, 0.75)),
scale=rep.distribution.uniform(0.5, 0.8),
color=rep.distribution.choice(color_palette),
count=3,
return lights.node
rep.randomizer.register(randomize_bin_holder_lights)
camera_positions = [(1.96, 0.72, -0.34), (1.48, 0.70, 0.90), (0.79, -0.86, 0.12), (-0.49, 1.47, 0.58)]
camera = rep.create.camera()
with rep.trigger.on_frame():
rep.randomizer.randomize_bin_holder_lights()
with camera:
rep.modify.pose(position=rep.distribution.sequence(camera_positions), look_at=(0.78, 0.72, -0.1))
def _switch_to_pathtracing(self):
carb_settings = carb.settings.get_settings()
set_carb_setting(carb_settings, "/rtx/rendermode", "PathTracing")
set_carb_setting(carb_settings, "/rtx/pathtracing/spp", 32)
set_carb_setting(carb_settings, "/rtx/pathtracing/totalSpp", 32)
set_carb_setting(carb_settings, "/rtx/pathtracing/clampSpp", 32)
def _switch_to_raytracing(self):
set_carb_setting(carb_settings, "/rtx/rendermode", "RayTracedLighting")
# 0: Disabled, 1: TAA, 2: FXAA, 3: DLSS, 4:RTXAA
set_carb_setting(carb_settings, "/rtx/post/aa/op", 3)
async def _run_pallet_scenario(self):
print(f"Running pallet scenario for bin {self._bin_counter}")
self.create_bin_graph()
self.create_pallet_graph()
out_dir = os.path.join(self._output_dir, f"writer_bin_{self._bin_counter}", "")
writer = rep.WriterRegistry.get("BasicWriter")
writer.initialize(output_dir=out_dir, rgb=True, instance_segmentation=True, colorize_instance_segmentation=True)
await writer.attach_async([rp])
await rep.orchestrator.run_async(num_frames=16)
await rep.orchestrator.wait_until_complete_async()
writer.detach()
self._next_bin()
def create_bin_graph(self):
bin_paths = [f"/environments/env/bins/bin_{i}" for i in range(36)]
bins_node = rep.get.prim_at_path(bin_paths)
mats = rep.create.material_omnipbr(
diffuse=rep.distribution.uniform((0.2, 0.1, 0.3), (0.6, 0.6, 0.7)),
roughness=rep.distribution.choice([0.1, 0.9]),
count=10,
def randomize_bin_materials():
with bins_node:
rep.randomizer.materials(mats)
return bins_node.node
rep.randomizer.register(randomize_bin_materials)
rep.randomizer.randomize_bin_materials()
with camera:
rep.modify.pose(
position=rep.distribution.uniform((0, -2, 2), (2, 1, 3)), look_at="/environments/env/pallet"
def create_pallet_graph(self):
pallet_node = rep.get.prim_at_path("/environments/env/pallet")
def randomize_pallet_textures():
with pallet_node:
rep.randomizer.texture(
textures=[
"omniverse://localhost/NVIDIA/Materials/Base/Wood/Oak/Oak_BaseColor.png",
"omniverse://localhost/NVIDIA/Materials/Base/Wood/Ash/Ash_BaseColor.png",
"omniverse://localhost/NVIDIA/Materials/Base/Wood/Plywood/Plywood_BaseColor.png",
"omniverse://localhost/NVIDIA/Materials/Base/Wood/Timber/Timber_BaseColor.png",
texture_rotate=rep.distribution.uniform(80, 95),
return pallet_node.node
rep.randomizer.register(randomize_pallet_textures)
with rep.trigger.on_frame(interval=4, rt_subframes=4):
rep.randomizer.randomize_pallet_textures()
def _next_bin(self):
self._bin_counter += 1
if self._bin_counter >= 36:
print("Demo finished!")
return
Thank you very much for your kindness.
I really appreciate your help.
I’d like to continue to check the behavior with your code.
Best regards,
I can run the demo with your code.
Thank you!
Best regards,
