Async error using viewpoint and synthetic_utils in the python file
Hi.
I want to make additional viewpoint and adapt my own imaging processing code in python.
I referenced IsaacSim example.
/home/idim/.local/share/ov/pkg/isaac_sim2021.2.1/exts/omni.isaac.demos/omni/isaac/demos/franka_leonardo_test.py
and add my customized functions(_set_camera) below.
class Extension(omni.ext.IExt):
    async def _on_create_franka(self, task):
        self._viewport.set_camera_position("/OmniverseKit_Persp", 142, -127, 56, True)
        self._viewport.set_camera_target("/OmniverseKit_Persp", -180, 234, -27, True)
        ##### Add camera viewport #####
        self._set_camera()
    def _set_camera(self):
        import omni.kit
        from omni.isaac.synthetic_utils import SyntheticDataHelper
        camera_path = "/environments/env_0_0/Franka/panda/panda_hand/geometry/realsense/realsense_camera"
        viewport_handle = omni.kit.viewport.get_viewport_interface().create_instance()
        viewport_window = omni.kit.viewport.get_viewport_interface().get_viewport_window(viewport_handle)
        viewport_window.set_active_camera(camera_path)
        viewport_window.set_texture_resolution(512, 512)
        viewport_window.set_window_pos(1000, 400)
        viewport_window.set_window_size(420, 420)
        self.viewport_window = viewport_window
        self.sd_helper = SyntheticDataHelper()
        self.sd_helper.initialize(sensor_names=["rgb"], viewport=self.viewport_window)
        viewport2RGB = self.sd_helper.get_groundtruth(["rgb"], self.viewport_window)
        viewport2RGB= list(viewport2RGB.values())[0]
        return
I got this result,
but some error occurs below.
2022-01-20 09:03:03 [478,612ms] [Error] [carb.events.python] RuntimeError: This event loop is already running
At:
  /home/idim/.local/share/ov/pkg/isaac_sim-2021.2.1/kit/python/lib/python3.7/asyncio/base_events.py(523): _check_runnung
  /home/idim/.local/share/ov/pkg/isaac_sim-2021.2.1/kit/python/lib/python3.7/asyncio/base_events.py(531): run_forever
  /home/idim/.local/share/ov/pkg/isaac_sim-2021.2.1/kit/extscore/omni.kit.async_engine/omni/kit/async_engine/async_engine.py(49): _on_update
  /home/idim/.local/share/ov/pkg/isaac_sim-2021.2.1/exts/omni.isaac.synthetic_utils/omni/isaac/synthetic_utils/syntheticdata.py(142): initialize
  /home/idim/.local/share/ov/pkg/isaac_sim-2021.2.1/exts/omni.isaac.synthetic_utils/omni/isaac/synthetic_utils/syntheticdata.py(163): get_groundtruth
  /home/idim/.local/share/ov/pkg/isaac_sim-2021.2.1/exts/omni.isaac.demos/omni/isaac/demos/franka_leonardo_test.py(256): _set_camera
  /home/idim/.local/share/ov/pkg/isaac_sim-2021.2.1/exts/omni.isaac.demos/omni/isaac/demos/franka_leonardo_test.py(148): _on_create_franka
  /home/idim/.local/share/ov/pkg/isaac_sim-2021.2.1/kit/python/lib/python3.7/asyncio/events.py(88): _run
  /home/idim/.local/share/ov/pkg/isaac_sim-2021.2.1/kit/python/lib/python3.7/asyncio/base_events.py(1786): _run_once
  /home/idim/.local/share/ov/pkg/isaac_sim-2021.2.1/kit/python/lib/python3.7/asyncio/base_events.py(541): run_forever
  /home/idim/.local/share/ov/pkg/isaac_sim-2021.2.1/kit/extscore/omni.kit.async_engine/omni/kit/async_engine/async_engine.py(56): _on_update
I think the error comes from ā€œSyntheticDataHelper()ā€, but I need it to use my customized image processing function(opencv).
How can I fix this async_engine error?
Thank you !
Hi @swimpark
What about if you read the images directly from ā€œomni.syntheticdataā€ extension…?
from omni.syntheticdata import sensors
color = sensors.get_rgb(self.viewport_window)
depth = sensors.get_depth(self.viewport_window)
I tried changing it as you comment,
        import omni.kit
but it said another error.
2022-01-20 11:02:30 [1,220,286ms] [Warning] [carb.sensors.plugin] Uninitialized sensor passed in, no sensor data
2022-01-20 11:02:30 [1,220,286ms] [Error] [asyncio] [/home/idim/.local/share/ov/pkg/isaac_sim-2021.2.1/kit/python/lib/python3.7/asyncio/base_events.py:1619] Task exception was never retrieved
future: <Task finished coro=<Extension._on_create_franka() done, defined at /home/idim/.local/share/ov/pkg/isaac_sim-2021.2.1/exts/omni.isaac.demos/omni/isaac/demos/franka_leonardo_test.py:111> exception=ValueError('cannot reshape array of size 0 into shape (0,0,newaxis)')>
  File "/home/idim/.local/share/ov/pkg/isaac_sim-2021.2.1/exts/omni.isaac.demos/omni/isaac/demos/franka_leonardo_test.py", line 147, in _on_create_franka
    self._set_camera()
  File "/home/idim/.local/share/ov/pkg/isaac_sim-2021.2.1/exts/omni.isaac.demos/omni/isaac/demos/franka_leonardo_test.py", line 248, in _set_camera
    color = sensors.get_rgb(viewport_window)
  File "/home/idim/.local/share/ov/pkg/isaac_sim-2021.2.1/kit/extscore/omni.syntheticdata/omni/syntheticdata/scripts/sensors.py", line 94, in get_rgb
    return np.frombuffer(data, np.uint8).reshape(h, w, -1)
ValueError: cannot reshape array of size 0 into shape (0,0,newaxis)
Hi
I think this error is because the sensor is not initialized.
You can check PATH_TO_ISAAC_SIM/exts/omni.isaac.synthetic_utils/omni/isaac/synthetic_utils/syntheticdata.py line 118 to see how to initialize the sensors…
Also, I think you can catch (and ignore) this error and keep executing the code… The sensor will be initialized eventually (after a few steps)…
Thank you for your reply.
I confirmed that the first image is processed with my customized functions, ā€˜_set_camera’ and ā€˜getfeature’, and it doesn’t work anymore after push the ā€˜start’ button.
I’m fixing this error, but it still has the same error.
The below is the code that I run. ( I used omni.addon,DATA VISUALIZER, that you made :) )
# Copyright (c) 2020-2021, NVIDIA CORPORATION.  All rights reserved.
# NVIDIA CORPORATION and its licensors retain all intellectual property
# and proprietary rights in and to this software, related documentation
# and any modifications thereto.  Any use, reproduction, disclosure or
# distribution of this software and related documentation without an express
# license agreement from NVIDIA CORPORATION is strictly prohibited.
import carb.input
from pxr import Usd, UsdGeom
import omni.kit.commands
import omni.ext
import omni.appwindow
import omni.ui as ui
import omni.kit.settings
from omni.kit.menu.utils import add_menu_items, remove_menu_items, MenuItemDescription
import asyncio
import weakref
from omni.isaac.motion_planning import _motion_planning
from omni.isaac.dynamic_control import _dynamic_control
import omni.physx as _physx
from .utils.scenario import Scenario
from .utils.ghost_scenario import GhostScenario
import cv2
import numpy as np
import omni.kit.test
from omni.add_on.visualizer import _visualizer
EXTENSION_NAME = "Leonardo Preview Test"
    def on_startup(self):
        """Initialize extension and UI elements
        self._timeline = omni.timeline.get_timeline_interface()
        self._viewport = omni.kit.viewport.get_default_viewport_window()
        self._usd_context = omni.usd.get_context()
        self._stage = self._usd_context.get_stage()
        self._window = None
        self._create_franka_btn = None
        self._perform_task_btn = None
        self._stop_task_btn = None
        self._toggle_obstacle_btn = None
        self._mp = _motion_planning.acquire_motion_planning_interface()
        self._dc = _dynamic_control.acquire_dynamic_control_interface()
        self._physxIFace = _physx.acquire_physx_interface()
        self._settings = carb.settings.get_settings()
        self._appwindow = omni.appwindow.get_default_app_window()
        self._sub_stage_event = self._usd_context.get_stage_event_stream().create_subscription_to_pop(
            self._on_stage_event
        self._scenario = Scenario(self._dc, self._mp)
        self._editor_event_subscription = None
        self._menu_items = [
            MenuItemDescription(
                name="Demos",
                sub_menu=[
                        name="Leonardo Demo_test", onclick_fn=lambda a=weakref.proxy(self): a._menu_callback()
        add_menu_items(self._menu_items, "Isaac Examples")
        self._first_step = True
    def _menu_callback(self):
        self._build_ui()
    def _build_ui(self):
        if not self._window:
            self._window = ui.Window(
                title=EXTENSION_NAME, width=300, height=200, dockPreference=ui.DockPreference.LEFT_BOTTOM
            with self._window.frame:
                with ui.VStack():
                    self._create_franka_btn = ui.Button("Create Scenario", clicked_fn=self._on_environment_setup)
                    self._perform_task_btn = ui.Button("Perform Task", clicked_fn=self._on_perform_task)
                    self._perform_task_btn.enabled = False
                    self._stop_task_btn = ui.Button("Stop/Reset Task", clicked_fn=self._on_stop_tasks)
                    self._stop_task_btn.enabled = False
                    self._toggle_obstacle_btn = ui.Button("Toggle Obstacle", clicked_fn=self._on_toggle_obstacle)
                    self._toggle_obstacle_btn.enabled = False
            self._editor_event_subscription = (
                omni.kit.app.get_app().get_update_event_stream().create_subscription_to_pop(self._on_update_ui)
        self._window.visible = True
    def _on_environment_setup(self):
        # wait for new stage before creating franka
        task = asyncio.ensure_future(omni.usd.get_context().new_stage_async())
        asyncio.ensure_future(self._on_create_franka(task))
        """Load any assets required by the scenario and create objects
        done, pending = await asyncio.wait({task})
        if task not in done:
            await omni.kit.app.get_app().next_update_async()
            return
        self._scenario = GhostScenario(self._dc, self._mp)
        self._create_franka_btn.enabled = False
        self._timeline.stop()
        self._physxIFace.release_physics_objects()
        self._settings.set("/rtx/reflections/halfRes", True)
        self._settings.set("/rtx/shadows/denoiser/quarterRes", True)
        self._settings.set("/rtx/translucency/reflectionCutoff", 0.1)
        self._scenario.create_franka()
        self.sd_helper = None
        self._set_camera()
        self._physxIFace.force_load_physics_from_usd()
        self._physx_subs = _physx.get_physx_interface().subscribe_physics_step_events(self._on_simulation_step)
        self._stop_task_btn.enabled = True
        self._toggle_obstacle_btn.enabled = True
        light_prim = self._stage.GetPrimAtPath("/World/defaultLight")
        if light_prim:
            light_prim.SetActive(False)
        import omni.kit
        self.viewport_window = None
        image = np.array(viewport2RGB)
        image2 = self.GetFeature(image)
        _visualizer.imshow("window", image2)
        # cv2.imshow('test', dst)
        # cv2.waitKey(0)  # ė³€ģˆ˜ź°’ė§Œķ¼ ģ‚¬ģš©ģžģ˜ ķ‚¤ģž…ė „ ģ‹œź°„ģ„ ėŒ€źø°ģ‹œķ‚“
        # cv2.destroyAllWindows()  # ķ”„ė”œź·øėžØ ģ¢…ė£Œģ „ ģžģ›ģ„ ķ•“ģ œ
        return
    def GetFeature(self, frame):
        lower_green  = np.array([10, 40, 15])    # lower color threshold
        upper_green  = np.array([150, 255, 255]) # upper color threshold
        drawing_frame = frame.copy()
        # get contours
        hsv_frame   = cv2.cvtColor(frame, cv2.COLOR_BGR2HSV)
        mask_green  = cv2.inRange(hsv_frame, lower_green, upper_green)
        height_list = [] # to compare maximum height of each contours
        width_list  = [] # to compare maximum width of each contours
        area_list   = []
        cnts, _ = cv2.findContours(mask_green, cv2.RETR_LIST, cv2.CHAIN_APPROX_NONE)
        for c in cnts:
            A = cv2.contourArea(c)
            if A < 500: # ignore areas smaller than 500
                continue
            else:
                area_list.append(A)
                # get extreme points from a contour
                extLeft  = tuple(c[c[:, :, 0].argmin()][0])
                extRight = tuple(c[c[:, :, 0].argmax()][0])
                extTop   = tuple(c[c[:, :, 1].argmin()][0])
                extBot   = tuple(c[c[:, :, 1].argmax()][0])
                # draw everything
                cv2.drawContours(drawing_frame, [c], -1, (0, 255, 0), 2)
                cv2.circle(drawing_frame, extLeft, 3, (0, 0, 255), -1)
                cv2.circle(drawing_frame, extRight, 3, (255, 255, 0), -1)
                cv2.circle(drawing_frame, extTop, 3, (255, 0, 0), -1)
                cv2.circle(drawing_frame, extBot, 3, (0, 255, 255), -1)
                height_list.append(abs(extRight[0]-extLeft[0]))
                width_list.append(abs(extBot[1]-extTop[1]))
        # maximum height, width and area
        height = max(height_list)
        width  = max(width_list)
        area   = max(area_list)
        # write things down in the frame
        cv2.putText(drawing_frame, "- HEIGHT : "+ str(height), (10, 60), cv2.FONT_HERSHEY_SIMPLEX, 0.4, (255,255,255), 1)
        cv2.putText(drawing_frame, "- WIDTH  : "+ str(width), (10, 80), cv2.FONT_HERSHEY_SIMPLEX, 0.4, (255,255,255), 1)
        cv2.putText(drawing_frame, "- AREA   : "+ str(area), (10, 100), cv2.FONT_HERSHEY_SIMPLEX, 0.4, (255,255,255), 1)
        return drawing_frame
    def _on_stop_tasks(self, *args):
        """Stop all tasks being performed by the scenario
        self._scenario.stop_tasks()
    def _on_simulation_step(self, step):
        """This function is called every timestep in the editor
        Arguments:
            step (float): elapsed time between steps
        if self._first_step:
            self._scenario.register_assets()
            self._first_step = False
        self._scenario.step(step)
    def _on_stage_event(self, event):
        """This function is called when stage events occur.
        Enables UI elements when stage is opened.
        Prevents tasks from being started until all assets are loaded
        Arguments:
            event (int): event type
        if self._window:
            self.stage = self._usd_context.get_stage()
            if event.type == int(omni.usd.StageEventType.OPENED):
                self._create_franka_btn.enabled = True
                self._on_stop_tasks()
    def _on_toggle_obstacle(self, *args):
        Toggle obstacle visibility
        for obstacle in self._scenario._obstacles:
            imageable = UsdGeom.Imageable(self._stage.GetPrimAtPath(obstacle.asset_path))
            visibility = imageable.ComputeVisibility(Usd.TimeCode.Default())
            if visibility == UsdGeom.Tokens.invisible:
                imageable.MakeVisible()
                obstacle.unsuppress()
            else:
                imageable.MakeInvisible()
                obstacle.suppress()
    def _on_perform_task(self, *args):
        """Perform all tasks in the scenario
        self._scenario.perform_tasks()
    def _on_update_ui(self, step):
        """Callback that updates UI elements every frame
        if self._scenario.is_created():
            if self._timeline.is_playing():
                self._perform_task_btn.enabled = True
                self._perform_task_btn.text = "Perform Task"
                if self._scenario._running is True:
                else:
            else:
                self._perform_task_btn.text = "Press Play To Enable"
                self._scenario._running = False
        else:
            self._perform_task_btn.text = "Press Create To Enable"
    def on_shutdown(self):
        """Cleanup objects on extension shutdown
        self._scenario = None
        self._physx_subs = None
        remove_menu_items(self._menu_items, "Isaac Examples")
        self._window = None
        self._menus = None
I am waiting for your insight about this issue.
Thank you !
Hi @swimpark
What I think it’s happening (Note: It’s just my thoughts): SyntheticDataHelper is designed for standalone applications, where the user has explicit control over the update loop. But, because you are launching Isaac Sim and programming on an extension, Isaac Sim is in control… That is why you get the ā€œRuntimeError: This event loop is already runningā€ error
A proposed solution (Note: it does not imply it is the best):
  1. use omni.syntheticdata extension
  2. initialize the sensor inside a function subscribed to the simulation/update loop (the sensor will need some frames to be rendered for initialization)
  3. use the initialized sensor to get the image
Here you can find a modified version of the code. The code I have added is wrapped by:
# NUMBER ++++++++++++++++++++++++++++
import carb.input
import omni.ext
import asyncio
import weakref
import cv2
import numpy as np
import omni.kit
# 1 +++++++++++++++++++++++++++++++++++++++++++
import omni.syntheticdata._syntheticdata as sd
        self._window = None
        # 1.1 ++++++++++++++++++++++++++++++++++++++++++++
        self._sd_interface = sd.acquire_syntheticdata_interface()
        self.is_sensor_initialized = False
                name="Demos",
                sub_menu=[
        self._build_ui()
                with ui.VStack():
            return
        self._set_camera()
        if light_prim:
        # get contours
        area_list   = []
        for c in cnts:
                continue
            else:
                area_list.append(A)
                # draw everything
        Arguments:
        # 2 +++++++++++++++++++++++++++++++++++++++++++
        if not self.is_sensor_initialized:
            print("Waiting for sensor to initialize")
            sensor = sensors.create_or_retrieve_sensor(self.viewport_window, sd.SensorType.Rgb)
            self.is_sensor_initialized = self._sd_interface.is_sensor_initialized(sensor)
            if self.is_sensor_initialized:
                print("Sensor initialized!")
        # 3 ++++++++++++++++++++++++++++++++++++++++++
            image = sensors.get_rgb(self.viewport_window)
            _visualizer.imshow("window", image)
        Arguments:
        if self._window:
            else:
                obstacle.suppress()
                else:
            else:
        else:
        self._window = None
        self._menus = None
Finally, It works !
Thank you for your kind replies :)
This is the result video.
Really thank you !
Hi @swimpark
Glad to hear that…
By the way, it looks like you are working locally. So, if you want to speed up the simulation, better display the images using cv2…
The omni.add_on.visualizer extension introduces a delay due to the conversion from ndarray to ByteImageProvider in order to display the images. It is designed to add extra visualization functionalities for headless deployment without xserver
Thank you for your feedback.
I changed the visualization method as you comment.
            cv2.imshow("Result", image2)
            cv2.waitKey(1)
Does it match what you intended?
Yes, it looks great…
In any case, you can test the performance of both implementations by enabling the FPS visualization :)
