(Solved? See my response below. tldr; needs to fully wait for scene to render. FYI, on another bug, I also highlighted the need for a wait look for the DataWriter to finish spooling out before killing it.)
Using Isaac Sim, Synthetic data capture I can build the image files nicely, i.e., in color - see below. Leveraging the exact same scenario, with the given file generator.py, the rgb image is in gray scale - instead of color - see the next image. This image is what is returned from the sensors.get_rgb call in syntheticdata.py (211), i.e., it isn’t converted to gray scale later by DataWriter.
The system is a relatively clean ubuntu 18.04 - built for this project a few days ago. GPU is RTX 3070. Isaac Sim seems to run fine. A basic sample ‘visualize_groundtruth.py’ runs fine - no errors, some (different) warnings - and a good output image. generator_stereo.py sort of worked - it showed the physics, but in grayscale. Also crashed with a bad_weak_ptr after about 10 seconds.
(Apologies for reposting this - but this is a show stopper for training object pose detection. Sofar the rest of the pre-training, including outputting the relative pose of the camera to the object is working fine.)
Thought - loading the scenario in Isaac sim takes about 115 seconds. However the python version starts generating data at 30 seconds. Perhaps the offline python needs to wait for full rendering???
There are warnings that show up during the run (from inside VS Code). The full run dump is below, but here’s a summary list:
- Warn: dumps uploading isn’t available, Extension with the same id is already registered
- Warn: already a module ‘pxr.UsdPhysics’
- Warn: [CUDA:RENDER] 0.1 CUDA rend warn : CUDA module initialization failed (version of your CUDA runtime library is 11.0, but 11.1 is required). FYI - I re-did with option ‘install_dependencies.sh --config=x86_64_cuda_11_1’ but no change after restart.
- Warn: DcPeekObjectType: Function called while not simulating
- and more warnings on shutdown… 436 outstanding handles; texture images not released correctly and could leak; failed to find plugin; leaking 1 carb::tasking::Counter.
From Isaac sim, using the built-in synthetic data recorder
Captured using python code (generator.py):
Full dump of run (from VS Code Terminal window):
pg@pg-U-18:~/.local/share/ov/pkg/isaac_sim-2021.1.1$ cd /home/pg/.local/share/ov/pkg/isaac_sim-2021.1.1 ; /usr/bin/env /usr/bin/python /home/pg/.vscode/extensions/ms-python.python-2021.8.1105858891/pythonFiles/lib/python/debugpy/launcher 46649 – /home/pg/.local/share/ov/pkg/isaac_sim-2021.1.1/python_samples/syntheticdata/offline_generation/mPgenerator.py
[Warning] [omni.kit.app.plugin] No crash reporter present, dumps uploading isn’t available.
[Info] [carb] Logging to file: /home/pg/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/logs/Kit/Isaac-Sim/2021.1/kit_20210810_150854.log
[Info] [carb] Initializing plugin: carb.events.plugin (interfaces: [carb::events::IEvents v0.2]) (impl: carb.events.plugin)
[0.012s] Loading user config located at: ‘/home/pg/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/data/Kit/Isaac-Sim/2021.1/user.config.json’
2021-08-10 19:08:54 [41ms] [Warning] [omni.ext.plugin] Extension with the same id is already registered. ext_id: ‘omni.kit.xr-1.0.0’, ext 1: ‘/home/pg/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.xr’, ext 2: ‘/home/pg/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.kit.xr’
[0.058s] [ext: omni.kit.pipapi-0.0.0] startup
[0.113s] [ext: omni.kit.pip_archive-0.0.0] startup
[0.129s] [ext: omni.usd.config-1.0.0] startup
[0.137s] [ext: omni.usd.libs-1.0.0] startup
2021-08-10 19:08:54 [161ms] [Error] [carb.python] Failed to reload python module pxr.Tf. Error: module pxr.Tf._tf not in sys.modules. Traceback:
File “/home/pg/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/plugins/bindings-python/omni/ext/impl/_internal.py”, line 56, in reload_module
return importlib.reload(sys.modules[name])
File “/home/pg/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/python/lib/python3.7/importlib/init.py”, line 148, in reload
raise ImportError(msg.format(name), name=name)
ImportError: module pxr.Tf._tf not in sys.modules2021-08-10 19:08:54 [161ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘pxr.Tf’ in ‘/home/pg/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.usd.libs/.’ failed to load.
At:
/home/pg/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/plugins/bindings-python/omni/ext/impl/_internal.py(169): startup_all_extensions_in_module
/home/pg/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/plugins/bindings-python/omni/ext/impl/_internal.py(225): startup_all_extensions_in_module
PythonExtension.cpp::startup()(2):
/home/pg/.local/share/ov/pkg/isaac_sim-2021.1.1/exts/omni.isaac.python_app/omni/isaac/python_app/python_app.py(185): _start_app
/home/pg/.local/share/ov/pkg/isaac_sim-2021.1.1/exts/omni.isaac.python_app/omni/isaac/python_app/python_app.py(107): init
/home/pg/.local/share/ov/pkg/isaac_sim-2021.1.1/python_samples/syntheticdata/offline_generation/mPgenerator.py(66): init
/home/pg/.local/share/ov/pkg/isaac_sim-2021.1.1/python_samples/syntheticdata/offline_generation/mPgenerator.py(418):
/home/pg/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/python/lib/python3.7/runpy.py(85): _run_code
/home/pg/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/python/lib/python3.7/runpy.py(96): _run_module_code
/home/pg/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/python/lib/python3.7/runpy.py(263): run_path
/home/pg/.vscode/extensions/ms-python.python-2021.8.1105858891/pythonFiles/lib/python/debugpy/…/debugpy/server/cli.py(285): run_file
/home/pg/.vscode/extensions/ms-python.python-2021.8.1105858891/pythonFiles/lib/python/debugpy/…/debugpy/server/cli.py(444): main
/home/pg/.vscode/extensions/ms-python.python-2021.8.1105858891/pythonFiles/lib/python/debugpy/main.py(45):
/home/pg/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/python/lib/python3.7/runpy.py(193): _run_module_as_main2021-08-10 19:08:54 [161ms] [Error] [omni.ext.plugin] [ext: omni.usd.libs-1.0.0] Failed to process python module extension in ‘/home/pg/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.usd.libs/.’.
[0.186s] [ext: omni.kit.async_engine-0.0.0] startup
[0.193s] [ext: omni.stats-0.0.0] startup
[0.201s] [ext: omni.assets.plugins-0.0.0] startup
[0.202s] [ext: omni.kit.loop-isaac-0.1.0] startup
[0.205s] [ext: omni.client-0.1.0] startup
[0.221s] [ext: omni.appwindow-1.0.0] startup
[0.238s] [ext: omni.kit.renderer.core-0.0.0] startup|---------------------------------------------------------------------------------------------|
| Driver Version: 460.91 | Graphics API: Vulkan
| GPU | Name | Active | LDA | GPU Memory | Vendor-ID | LUID |
| | | | | | Device-ID | UUID |
| 0 | GeForce RTX 3070 | Yes | | 8438 MB | 10de | 0 |
| | | | | | 2484 | 1b228445… |
| OS: Linux pg-U-18, Version: 4.15.0-153-generic
| XServer Vendor: The X.Org Foundation, XServer Version: 11906000 (1.19.6.0)
| Processor: Intel(R) Core™ i7-7700K CPU @ 4.20GHz | Cores: Unknown | Logical: 8
| Total Memory (MB): 32122 | Free Memory: 22509
| Total Page/Swap (MB): 2047 | Free Page/Swap: 2047
[0.931s] [ext: omni.kit.test-0.0.0] startup
[0.952s] [ext: omni.ui-2.1.8] startup
[0.979s] [ext: omni.kit.mainwindow-0.0.0] startup
[0.987s] [ext: omni.kit.uiapp-0.0.0] startup
[0.988s] [ext: omni.usd.schema.physics-1.0.0] startup
2021-08-10 19:08:55 [1,078ms] [Warning] [carb.python] There is already a module ‘pxr.UsdPhysics’ in ‘/home/pg/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.usd.schema.physics/pxr/UsdPhysics/init.py’. Can’t import another module with the same name in public space from ‘/home/pg/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extsPhysics/omni.usd.schema.physics’.
2021-08-10 19:08:55 [1,088ms] [Warning] [carb.python] There is already a module ‘usd.schema.physics’ in ‘/home/pg/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.usd.schema.physics/usd/schema/physics/init.py’. Can’t import another module with the same name in public space from ‘/home/pg/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extsPhysics/omni.usd.schema.physics’.
[1.098s] [ext: omni.usd.schema.isaac-0.1.0] startup
[1.203s] [ext: omni.usd.schema.semantics-0.0.0] startup
[1.222s] [ext: omni.usd.schema.audio-0.0.0] startup
[1.240s] [ext: omni.usd.schema.physx-0.0.0] startup
[1.304s] [ext: omni.usd.schema.anim-0.0.0] startup
[1.366s] [ext: omni.services.facilities.base-1.0.0] startup
[1.397s] [ext: omni.services.core-1.1.0] startup
[1.819s] [ext: omni.services.transport.server.base-1.0.0] startup
[1.825s] [ext: omni.services.transport.server.http-1.0.0] startup
[2.423s] [ext: omni.kit.notification_manager-1.0.0] startup
[2.434s] [ext: omni.services.transport.client.base-1.0.0] startup
[2.438s] [ext: omni.kit.agent-0.1.0] startup
[2.442s] [ext: omni.kit.window.popup_dialog-2.0.0] startup
[2.455s] [ext: omni.hydra.scene_delegate-0.1.0] startup
[2.464s] [ext: omni.services.client-0.2.0] startup
[2.727s] [ext: carb.audio-0.1.0] startup
[2.749s] [ext: omni.timeline-1.0.0] startup
[2.756s] [ext: omni.kit.commands-0.0.0] startup
[2.773s] [ext: omni.services.transport.client.http_async-1.0.0] startup
[4.310s] [ext: omni.kit.search_core-1.0.0] startup
[4.316s] [ext: omni.kit.widget.path_field-2.0.2] startup
[4.328s] [ext: omni.usd-1.4.2] startup
[4.464s] [ext: omni.kit.thumbnails.images-0.1.1] startup
[4.478s] [ext: omni.kit.widget.filebrowser-2.2.4] startup
[4.490s] [ext: omni.kit.widget.browser_bar-2.0.1] startup
[4.493s] [ext: omni.kit.stage_templates-1.0.4] startup
[4.499s] [ext: omni.kit.window.filepicker-2.3.1] startup
[5.063s] [ext: omni.kit.window.file-1.2.2] startup
[5.392s] [ext: omni.renderer-rtx-0.0.0] startup
[5.393s] [ext: omni.kvdb-0.0.0] startup
[5.424s] [ext: omni.usdphysics-1.2.0] startup
[5.425s] [ext: omni.convexdecomposition-1.2.0] startup
[5.456s] [ext: omni.localcache-0.0.0] startup
[5.486s] [ext: omni.kit.menu.utils-1.0.1] startup
[5.511s] [ext: omni.physx-1.2.0-5.1] startup
[5.555s] [ext: omni.kit.material.library-1.0.4] startup
[5.588s] [ext: omni.kit.menu.create-1.0.1] startup
[5.591s] [ext: omni.kit.window.drop_support-1.0.0] startup
[5.593s] [ext: omni.kit.context_menu-1.1.0] startup
[5.892s] [ext: omni.hydra.rtx-0.1.0] startup
[5.896s] [ext: omni.kit.window.content_browser-2.3.1] startup
[6.182s] [ext: omni.kit.window.viewport-0.0.0] startup
2021-08-10 19:09:00 [6,175ms] [Warning] [omni.ext.plugin] [ext: omni.kit.window.viewport-0.0.0] ‘/home/pg/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/plugins/rtx/rtx.reshade.plugin’ in ‘[[native.plugin]]’ was not found.
2021-08-10 19:09:00 [6,394ms] [Warning] [rtx.neuraylib.plugin] [CUDA:RENDER] 0.1 CUDA rend warn : CUDA module initialization failed.
2021-08-10 19:09:00 [6,394ms] [Warning] [rtx.neuraylib.plugin] [CUDA:RENDER] 0.1 CUDA rend warn : The version of your CUDA runtime library is 11.0, but 11.1 is required
2021-08-10 19:09:00 [6,394ms] [Warning] [rtx.neuraylib.plugin] [CUDA:RENDER] 0.1 CUDA rend warn : Please verify that you are using the right shared CUDA libraries.
2021-08-10 19:09:00 [6,500ms] [Warning] [rtx.neuraylib.plugin] [IRAY:RENDER] 1.1 IRAY rend warn : CUDA module initialization failed.
2021-08-10 19:09:00 [6,500ms] [Warning] [rtx.neuraylib.plugin] [IRAY:RENDER] 1.1 IRAY rend warn : The version of your CUDA runtime library is 11.0, but 11.1 is required; iray photoreal can only run in CPU mode.
2021-08-10 19:09:00 [6,500ms] [Warning] [rtx.neuraylib.plugin] [IRAY:RENDER] 1.1 IRAY rend warn : Please verify that you are using the right shared CUDA libraries.
2021-08-10 19:09:00 [6,500ms] [Warning] [rtx.neuraylib.plugin] [IRAY:RENDER] 1.1 IRAY rend warn : There is no CUDA-capable GPU available to the iray photoreal renderer.
2021-08-10 19:09:03 [8,871ms] [Warning] [carb] Acquiring non optional plugin interface which is not listed as dependency: [rtx::raytracing::Subsurface v0.1] (plugin: rtx.raytracing.plugin), by client: carb.scenerenderer-rtx.plugin. Add it to CARB_PLUGIN_IMPL_DEPS() macro of a client.
[9.208s] [ext: omni.physx.commands-1.0.0] startup
[9.242s] [ext: omni.kit.widget.stage-2.4.0] startup
[9.266s] [ext: omni.kit.window.property-0.0.0] startup
[9.270s] [ext: omni.kit.widget.settings-1.0.0] startup
[9.275s] [ext: omni.kit.property.usd-3.9.4] startup
[9.318s] [ext: omni.kit.window.preferences-1.1.1] startup
[9.378s] [ext: omni.debugdraw-0.0.0] startup
[9.387s] [ext: omni.kit.property.material-1.6.4] startup
[9.396s] [ext: omni.physx.ui-1.2.0-5.1] startup
[9.449s] [ext: omni.kit.numpy.common-0.1.0] startup
[9.739s] [ext: omni.kit.property.physx-0.1.0] startup
[9.832s] [ext: omni.kit.window.toolbar-1.0.0] startup
[9.850s] [ext: omni.physx.demos-1.0.0] startup
[9.880s] [ext: omni.isaac.dynamic_control-0.1.3] startup
[9.925s] [ext: omni.physx.vehicle-1.2.0-5.1] startup
[9.971s] [ext: omni.physx.cct-1.2.0-5.1] startup
[10.005s] [ext: omni.isaac.utils-0.1.4] startup
[10.029s] [ext: omni.syntheticdata-0.1.5] startup
[10.661s] [ext: omni.physx.bundle-1.2.0-5.1] startup
[10.661s] [ext: omni.isaac.range_sensor-0.1.2] startup
[10.678s] [ext: omni.isaac.robot_engine_bridge_ui-0.1.0] startup
[10.689s] [ext: omni.kit.primitive.mesh-1.0.0] startup
[10.701s] [ext: omni.isaac.robot_engine_bridge-0.1.0] startup
[11.359s] [ext: omni.kit.window.console-0.0.0] startup
[11.361s] [ext: omni.isaac.motion_planning-0.1.4] startup
[11.371s] [ext: omni.isaac.occupancy_map-0.1.0] startup
[11.379s] [ext: omni.kit.widget.prompt-1.0.0] startup
[11.386s] [ext: omni.kit.asset_converter-1.1.22] startup
[11.448s] [ext: omni.kit.window.script_editor-1.5.0] startup
[11.449s] [ext: omni.kit.window.status_bar-0.0.0] startup
[11.451s] [ext: omni.rtx.window.settings-0.6.0] startup
[11.464s] [ext: omni.isaac.synthetic_utils-0.1.0] startup
[11.497s] [ext: omni.kit.widget.graph-1.1.2] startup
[11.512s] [ext: omni.kit.window.profiler-1.0.0] startup
[11.524s] [ext: omni.rtx.settings.core-0.5.4] startup
[11.532s] [ext: omni.isaac.dr-0.1.6] startup
[11.543s] [ext: omni.kit.window.extensions-1.0.2] startup
[11.553s] [ext: omni.isaac.urdf-0.1.4] startup
[11.568s] [ext: omni.isaac.contact_sensor-0.1.0] startup
[11.577s] [ext: omni.isaac.python_app-0.0.0] startup
[11.579s] [ext: omni.isaac.sim.python-2021.1.1] startup
[11.579s] app started
OmniKitHelper Starting up …
OmniKitHelper Startup Complete
Loading materials. Will generate data soon…
2021-08-10 19:09:24 [30,657ms] [Warning] [omni.isaac.dynamic_control.plugin] DcPeekObjectType: Function called while not simulating
Writing data to /home/pg/.local/share/ov/pkg/isaac_sim-2021.1.1/output
extra updates
ground truth available
Relative pose: (9.66,433.40,32.75) -17.95
2021-08-10 19:09:25 [31,666ms] [Warning] [omni.isaac.dynamic_control.plugin] DcPeekObjectType: Function called while not simulating
extra updates
Relative pose: (76.58,408.49,31.31) -12.20
2021-08-10 19:09:26 [32,455ms] [Warning] [omni.isaac.dynamic_control.plugin] DcPeekObjectType: Function called while not simulating
extra updates
Relative pose: (26.72,429.27,34.31) -18.64
2021-08-10 19:09:27 [33,250ms] [Warning] [omni.isaac.dynamic_control.plugin] DcPeekObjectType: Function called while not simulating
extra updates
Relative pose: (26.62,366.74,29.17) -10.46
2021-08-10 19:09:28 [34,046ms] [Warning] [omni.isaac.dynamic_control.plugin] DcPeekObjectType: Function called while not simulating
extra updates
Relative pose: (93.03,443.58,5.18) -12.08
sleep for 10 - let I/O spool out
shutdown
Shutting Down OmniKitHelper…
[44.864s] [ext: omni.isaac.sim.python-2021.1.1] shutdown
[44.864s] [ext: omni.isaac.contact_sensor-0.1.0] shutdown
[44.911s] [ext: omni.isaac.dr-0.1.6] shutdown
[44.923s] [ext: omni.isaac.motion_planning-0.1.4] shutdown
[44.923s] [ext: omni.isaac.robot_engine_bridge-0.1.0] shutdown
[44.973s] [ext: omni.isaac.occupancy_map-0.1.0] shutdown
[45.019s] [ext: omni.isaac.urdf-0.1.4] shutdown
[45.076s] [ext: omni.isaac.utils-0.1.4] shutdown
[45.289s] [ext: omni.isaac.dynamic_control-0.1.3] shutdown
[45.338s] [ext: omni.isaac.python_app-0.0.0] shutdown
[45.339s] [ext: omni.isaac.range_sensor-0.1.2] shutdown
[45.349s] [ext: omni.isaac.robot_engine_bridge_ui-0.1.0] shutdown
[45.351s] [ext: omni.isaac.synthetic_utils-0.1.0] shutdown
[45.353s] [ext: omni.kit.asset_converter-1.1.22] shutdown
[45.394s] [ext: omni.physx.bundle-1.2.0-5.1] shutdown
[45.394s] [ext: omni.physx.vehicle-1.2.0-5.1] shutdown
[45.442s] [ext: omni.kit.property.physx-0.1.0] shutdown
[45.483s] [ext: omni.kit.property.material-1.6.4] shutdown
[45.484s] [ext: omni.kit.property.usd-3.9.4] shutdown
[45.485s] [ext: omni.kit.window.content_browser-2.3.1] shutdown
[45.486s] [ext: omni.kit.window.profiler-1.0.0] shutdown
[45.487s] [ext: omni.physx.cct-1.2.0-5.1] shutdown
[45.528s] [ext: omni.physx.demos-1.0.0] shutdown
[45.570s] [ext: omni.physx.ui-1.2.0-5.1] shutdown
[45.615s] [ext: omni.syntheticdata-0.1.5] shutdown
[45.615s] [ext: omni.kit.window.viewport-0.0.0] shutdown
2021-08-10 19:09:40 [45,881ms] [Warning] [gpu.foundation.plugin] carb::extras::HandleDatabase<TrueType, HandleType, Allocator>::~HandleDatabase() [with TrueType = rtx::shaderdb::InternalShaderDesc; HandleType = rtx::shaderdb::_ShaderHandle*; Allocator = std::allocatorrtx::shaderdb::InternalShaderDesc]: had 436 outstanding handle(s) at shutdown
[45.893s] [ext: omni.kit.window.drop_support-1.0.0] shutdown
[45.893s] [ext: omni.kit.primitive.mesh-1.0.0] shutdown
[45.895s] [ext: omni.kit.window.preferences-1.1.1] shutdown
[45.901s] [ext: omni.kit.window.status_bar-0.0.0] shutdown
[45.902s] [ext: omni.kit.uiapp-0.0.0] shutdown
[45.902s] [ext: omni.kit.window.file-1.2.2] shutdown
[45.902s] [ext: omni.rtx.settings.core-0.5.4] shutdown
[45.905s] [ext: omni.rtx.window.settings-0.6.0] shutdown
[45.905s] [ext: omni.kit.window.filepicker-2.3.1] shutdown
[45.905s] [ext: omni.kit.notification_manager-1.0.0] shutdown
[45.905s] [ext: omni.kit.widget.stage-2.4.0] shutdown
[45.906s] [ext: omni.kit.context_menu-1.1.0] shutdown
[45.906s] [ext: omni.kit.widget.browser_bar-2.0.1] shutdown
[45.906s] [ext: omni.kit.widget.filebrowser-2.2.4] shutdown
[45.906s] [ext: omni.kit.window.extensions-1.0.2] shutdown
[45.906s] [ext: omni.kit.widget.graph-1.1.2] shutdown
[45.906s] [ext: omni.kit.widget.path_field-2.0.2] shutdown
[45.906s] [ext: omni.kit.widget.prompt-1.0.0] shutdown
[45.906s] [ext: omni.kit.widget.settings-1.0.0] shutdown
[45.907s] [ext: omni.kit.window.console-0.0.0] shutdown
[45.907s] [ext: omni.kit.window.popup_dialog-2.0.0] shutdown
[45.908s] [ext: omni.kit.window.property-0.0.0] shutdown
[45.908s] [ext: omni.kit.window.script_editor-1.5.0] shutdown
[45.908s] [ext: omni.kit.window.toolbar-1.0.0] shutdown
[45.909s] [ext: omni.kit.mainwindow-0.0.0] shutdown
[45.909s] [ext: omni.kit.material.library-1.0.4] shutdown
[45.910s] [ext: omni.kit.menu.create-1.0.1] shutdown
[45.911s] [ext: omni.kit.menu.utils-1.0.1] shutdown
[45.911s] [ext: omni.ui-2.1.8] shutdown
[45.911s] [ext: omni.kit.renderer.core-0.0.0] shutdown
2021-08-10 19:09:40 [46,056ms] [Warning] [gpu.foundation.plugin] Texture:‘/tmp/carb.ljfoo0/bookmark_grey.36x36.png’ is not released correctly and cause leak.
2021-08-10 19:09:40 [46,056ms] [Warning] [gpu.foundation.plugin] Texture:‘/tmp/carb.ljfoo0/filter.28x32.png’ is not released correctly and cause leak.
2021-08-10 19:09:40 [46,056ms] [Warning] [gpu.foundation.plugin] Texture:‘/tmp/carb.ljfoo0/angle_left.32x32.png’ is not released correctly and cause leak.
2021-08-10 19:09:40 [46,056ms] [Warning] [gpu.foundation.plugin] Texture:‘/tmp/carb.ljfoo0/angle_right.32x32.png’ is not released correctly and cause leak.
2021-08-10 19:09:40 [46,056ms] [Warning] [gpu.foundation.plugin] Texture:‘/tmp/carb.ljfoo0/settings.28x32.png’ is not released correctly and cause leak.
2021-08-10 19:09:40 [46,056ms] [Warning] [gpu.foundation.plugin] Release above leaking textures on exit.
[46.108s] [ext: omni.appwindow-1.0.0] shutdown
[46.108s] [ext: omni.kit.search_core-1.0.0] shutdown
[46.108s] [ext: omni.kit.thumbnails.images-0.1.1] shutdown
[46.108s] [ext: omni.services.transport.server.http-1.0.0] shutdown
[46.108s] [ext: omni.services.transport.server.base-1.0.0] shutdown
[46.109s] [ext: omni.services.transport.client.http_async-1.0.0] shutdown
[46.109s] [ext: omni.services.client-0.2.0] shutdown
[46.109s] [ext: omni.services.core-1.1.0] shutdown
[46.109s] [ext: omni.kit.test-0.0.0] shutdown
[46.109s] [ext: omni.kit.loop-isaac-0.1.0] shutdown
[46.109s] [ext: omni.usd.schema.isaac-0.1.0] shutdown
[46.109s] [ext: omni.debugdraw-0.0.0] shutdown
[46.109s] [ext: omni.kit.numpy.common-0.1.0] shutdown
[46.110s] [ext: omni.kit.stage_templates-1.0.4] shutdown
[46.110s] [ext: omni.physx.commands-1.0.0] shutdown
[46.150s] [ext: omni.physx-1.2.0-5.1] shutdown
[46.190s] [ext: omni.convexdecomposition-1.2.0] shutdown
[46.232s] [ext: omni.localcache-0.0.0] shutdown
[46.273s] [ext: omni.kvdb-0.0.0] shutdown
[46.316s] [ext: omni.usd.schema.physx-0.0.0] shutdown
[46.362s] [ext: omni.usdphysics-1.2.0] shutdown
[46.362s] [ext: omni.usd-1.4.2] shutdown
[46.371s] [ext: omni.usd.schema.physics-1.0.0] shutdown
[46.413s] [ext: carb.audio-0.1.0] shutdown
[46.413s] [ext: omni.renderer-rtx-0.0.0] shutdown
[46.414s] [ext: omni.client-0.1.0] shutdown
[46.416s] [ext: omni.assets.plugins-0.0.0] shutdown
[46.416s] [ext: omni.hydra.rtx-0.1.0] shutdown
[46.416s] [ext: omni.hydra.scene_delegate-0.1.0] shutdown
2021-08-10 19:09:40 [46,406ms] [Warning] [carb] unloadPlugin: Failed to find a plugin at: /home/pg/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/plugins/libomni.gpucompute-cuda.plugin.so.
2021-08-10 19:09:40 [46,406ms] [Warning] [carb] unloadPlugin: Failed to find a plugin at: /home/pg/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/plugins/libomni.gpucompute-d3dvk.plugin.so.
[46.416s] [ext: omni.kit.agent-0.1.0] shutdown
[46.417s] [ext: omni.kit.async_engine-0.0.0] shutdown
[46.417s] [ext: omni.kit.commands-0.0.0] shutdown
[46.417s] [ext: omni.kit.pip_archive-0.0.0] shutdown
[46.417s] [ext: omni.kit.pipapi-0.0.0] shutdown
[46.417s] [ext: omni.services.facilities.base-1.0.0] shutdown
[46.417s] [ext: omni.services.transport.client.base-1.0.0] shutdown
[46.417s] [ext: omni.stats-0.0.0] shutdown
[46.417s] [ext: omni.timeline-1.0.0] shutdown
[46.417s] [ext: omni.usd.schema.anim-0.0.0] shutdown
[46.417s] [ext: omni.usd.schema.semantics-0.0.0] shutdown
[46.417s] [ext: omni.usd.schema.audio-0.0.0] shutdown
[46.417s] [ext: omni.usd.libs-1.0.0] shutdown
[46.419s] [ext: omni.usd.config-1.0.0] shutdown
2021-08-10 19:09:40 [46,683ms] [Warning] [carb.tasking.plugin] Leaking 1 carb::tasking::Counter instances!
Shutting Down Complete
Finish writing data…
Done.
