How to move the vehicle to its destination by using A*_search_algorithm
Hello @toni.sm
Thank you from the bottom of my heart for always helping me.
As you said before, the Navigation function in Isaac Sim’s Navigation Sample Applications uses Quintic Polynomials Planner (...isaac_sim-2022.1.0/exts/omni.isaac.demos/omni/isaac/demos/utils/quintic_path_planner.py )
I would like to change Quintic Polynomials Planner to PythonRobotics/a_star.py at master · AtsushiSakai/PythonRobotics · GitHub in python code.
However, I failed many attempts because I had nowhere to get help or advice and had some difficulties.
I’m really sorry to you, but if you don’t mind, could you show me an example of changing the Quintic Polynomials Planner code to A* grid planning?
Thank you always.
Hi @toni.sm
Would you show me an example with the Transporter or Carter, which is built into Isaac Sim’s Navigation Sample Applications?
If you do that, I will change it to my robot after looking at your example.
I’ve tried many things, but it’s too hard to change Quintic Polynomials Planner to A Star Planner.
Hi @gudwnzm
Here you can find a simple and quick integration of the A* algorithm (code from the next blog) with the Isaac Sim Navigation Sample
The modification is done in the simple_robot_controller.py file (...exts/omni.isaac.demos/omni/isaac/demos/utils/simple_robot_controller.py)
simple_robot_controller.py (15.2 KB)
# Copyright (c) 2018-2020, NVIDIA CORPORATION.  All rights reserved.
# NVIDIA CORPORATION and its licensors retain all intellectual property
# and proprietary rights in and to this software, related documentation
# and any modifications thereto.  Any use, reproduction, disclosure or
# distribution of this software and related documentation without an express
# license agreement from NVIDIA CORPORATION is strictly prohibited.
import math
import carb
from pxr import UsdGeom, Gf
from omni.isaac.core.utils.rotations import quat_to_euler_angles
from omni.isaac.dynamic_control import _dynamic_control
import numpy as np
from omni.debugdraw import _debugDraw
from .quintic_path_planner import QuinticPolynomial, quintic_polynomials_planner
from .stanley_control import State, pid_control, stanley_control, normalize_angle, Kp, calc_target_index
# 1. +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
import heapq
import matplotlib.pyplot as plt
from scipy.interpolate import interp1d
grid = np.array([
    [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0],
    [0, 0, 0, 0, 0, 1, 1, 1, 0, 0, 0, 0, 1, 1, 1, 0, 0, 0, 0, 0],
    [0, 0, 0, 0, 0, 1, 0, 0, 0, 0, 0, 0, 0, 0, 1, 0, 0, 0, 0, 0],
    [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]])
distance_per_square = 0.25
def heuristic(a, b):
    return np.sqrt((b[0] - a[0]) ** 2 + (b[1] - a[1]) ** 2)
def astar(array, start, goal):
    neighbors = [(0,1),(0,-1),(1,0),(-1,0),(1,1),(1,-1),(-1,1),(-1,-1)]
    close_set = set()
    came_from = {}
    gscore = {start:0}
    fscore = {start:heuristic(start, goal)}
    oheap = []
    heapq.heappush(oheap, (fscore[start], start))
    while oheap:
        current = heapq.heappop(oheap)[1]
        if current == goal:
            data = []
            while current in came_from:
                data.append(current)
                current = came_from[current]
            return data
        close_set.add(current)
        for i, j in neighbors:
            neighbor = current[0] + i, current[1] + j
            tentative_g_score = gscore[current] + heuristic(current, neighbor)
            if 0 <= neighbor[0] < array.shape[0]:
                if 0 <= neighbor[1] < array.shape[1]:
                    if array[neighbor[0]][neighbor[1]] == 1:
                        continue
                else:
                    # array bound y walls
                    continue
            else:
                # array bound x walls
                continue
            if neighbor in close_set and tentative_g_score >= gscore.get(neighbor, 0):
                continue
            if  tentative_g_score < gscore.get(neighbor, 0) or neighbor not in [i[1]for i in oheap]:
                came_from[neighbor] = current
                gscore[neighbor] = tentative_g_score
                fscore[neighbor] = tentative_g_score + heuristic(neighbor, goal)
                heapq.heappush(oheap, (fscore[neighbor], neighbor))
    return False
# 1. -------------------------------------------------------------------------
def calc_speed_profile(cyaw, max_speed, target_speed, min_speed=1):
    speed_profile = np.array(cyaw) / max([abs(c) for c in cyaw]) * max_speed
    # direction = 1.0
    # # Set stop point
    # for i in range(len(cyaw) - 1):
    #     dyaw = abs(cyaw[i + 1] - cyaw[i])
    #     switch = math.pi / 4.0 <= dyaw < math.pi / 2.0
    #     if switch:
    #         direction *= -1
    #     if direction != 1.0:
    #         speed_profile[i] = -target_speed
    #     else:
    #         speed_profile[i] = target_speed
    #     if switch:
    #         speed_profile[i] = 0.0
    # speed down
    res = min(int(len(cyaw) / 3), int(max_speed * 60))
    # # print("slow", slow, len(cyaw))
    for i in range(1, res):
        speed_profile[-i] = min(speed_profile[-i], speed_profile[-i] / (float(res - i)) ** 0.5)  # / (res))
        if speed_profile[-i] <= min_speed:
            speed_profile[-i] = min_speed
    return speed_profile
class RobotController:
    def __init__(
        self,
        stage,
        dc,
        articulation_path,
        odom_prim_path,
        wheel_joint_names,
        wheel_speed,
        goal_offset_threshold,
        wheel_base,
        wheel_radius,
        self._stage = stage
        self._stage_unit = UsdGeom.GetStageMetersPerUnit(self._stage)
        self._dc = dc
        self._articulation_path = articulation_path
        self._odom_prim_path = odom_prim_path
        self._wheel_joint_names = wheel_joint_names
        self._wheel_speed = wheel_speed
        self._goal_offset_threshold = goal_offset_threshold
        self._reached_goal = [True, True]
        self._enable_navigation = False
        self._goal = [4.00, 4.00, 0]
        self._go_forward = False
        self._wheel_base = wheel_base
        self._wheel_radius = wheel_radius
        self.state = State(wheel_base, x=0, y=0, yaw=0, v=0)
        self.target_idx = 0
        self._debugDraw = _debugDraw.acquire_debug_draw_interface()
        self.cx = []
    def _get_odom_data(self):
        self.imu = self._dc.get_rigid_body(self._odom_prim_path)
        imu_pose = self._dc.get_rigid_body_pose(self.imu)
        roll, pitch, yaw = quat_to_euler_angles(np.array([imu_pose.r.w, imu_pose.r.x, imu_pose.r.y, imu_pose.r.z]))
        # print(roll, pitch, yaw)
        self.current_robot_translation = [imu_pose.p.x, imu_pose.p.y, imu_pose.p.z]
        self.current_robot_translation = [i * self._stage_unit for i in self.current_robot_translation]
        self.current_robot_orientation = [normalize_angle(roll), normalize_angle(pitch), normalize_angle(yaw)]
        self.current_speed = self._dc.get_rigid_body_local_linear_velocity(self.imu).x * self._stage_unit
    def reached_goal(self):
        return self._reached_goal[0] and self._reached_goal[1]
    def get_goal(self):
        return self._goal
    def draw_path(self, step=None):
        if self._enable_navigation and not self._reached_goal[0]:
            for i in range(len(self.cx) - 1):
                # self._debugDraw.draw_line(
                #     carb.Float3(self.cx[i], self.cy[i], 14),
                #     self.y_color,
                #     carb.Float3(self.cx[i] + 20 * math.cos(self.cyaw[i]), self.cy[i] + 20 * math.sin(self.cyaw[i]), 14),
                #     self.y_color,
                    carb.Float3(self.cx[i] / self._stage_unit, self.cy[i] / self._stage_unit, 0.14 / self._stage_unit),
                    self.argb[i],
                    carb.Float3(
                        self.cx[i + 1] / self._stage_unit, self.cy[i + 1] / self._stage_unit, 0.14 / self._stage_unit
                    self.argb[i - 1],
    def update(self, step):
        v = 0
        w = 0
        if self._enable_navigation:
            self._get_odom_data()
            # self.draw_path()
            theta = self.current_robot_orientation[2]
            theta_goal = self._goal[2]
            theta_diff = math.atan2(math.sin(theta_goal - theta), math.cos(theta_goal - theta))
            x_diff = float(self._goal[0]) - self.current_robot_translation[0]
            y_diff = float(self._goal[1]) - self.current_robot_translation[1]
            rho = np.hypot(x_diff, y_diff)
            self.state = State(
                self._wheel_base * Kp,
                x=self.current_robot_translation[0],
                y=self.current_robot_translation[1],
                yaw=self.current_robot_orientation[2] % (2 * np.pi),
                v=self.current_speed,
                rho < self._goal_offset_threshold[0] or self.rotate_only and rho < self._goal_offset_threshold[0] * 5,
                abs(theta_diff) <= self._goal_offset_threshold[1],
            if self._reached_goal[0] and self._reached_goal[1]:
                self.control_command(0, 0)
                return
            if not self.rotate_only:
                ai = pid_control(self.sp[self.target_idx], self.state.v) / step
                di, self.target_idx = stanley_control(self.state, self.cx, self.cy, self.cyaw, self.target_idx)
                self.state.update(ai, di, step)
                v = self.state.v
                w = self.state.w
            if self._reached_goal[0] or self.rotate_only:
                if self._reached_goal[0]:
                    self.rotate_only = True
                v = 0
                if theta_diff > 0:
                    w = min(((theta_diff) * Kp / step), 1)
                else:
                    w = max(((theta_diff) * Kp / step), -1)
            # print(rho, abs(theta_diff), v, w, self.sp[self.target_idx], self.current_speed, self.target_idx)
            kw = 0.5
            # Allow additional steering to use differential drive (backwards spin on one wheel to tighten the cornering radius)
            if not self._reached_goal[0] and v > 0:
                kw = 0.5 + abs((self._wheel_base * w) / v) * (0.5 * Kp / step)
                # print(kw)
            command_left = (v - kw * self._wheel_base * w) / self._wheel_radius
            command_right = (v + kw * self._wheel_base * w) / self._wheel_radius
            # print(command_left, command_right)
            self.control_command(command_left, command_right)
    def control_setup(self):
        self.ar = self._dc.get_articulation(self._articulation_path)
        self.wheel_left = self._dc.find_articulation_dof(self.ar, self._wheel_joint_names[0])
        self.wheel_right = self._dc.find_articulation_dof(self.ar, self._wheel_joint_names[1])
        self.vel_props = _dynamic_control.DofProperties()
        # self.vel_props.drive_mode = _dynamic_control.DRIVE_VEL
        self.vel_props.damping = 1e7
        self.vel_props.stiffness = 0
        self._dc.set_dof_properties(self.wheel_left, self.vel_props)
        self._dc.set_dof_properties(self.wheel_right, self.vel_props)
    def control_command(self, left_wheel_speed, right_wheel_speed):
        # Wake up articulation every move command to ensure commands are applied
        self._dc.wake_up_articulation(self.ar)
        # Normalizes both wheels speed if any speed will be clipped
        if abs(left_wheel_speed) > self._wheel_speed[0]:
            factor = abs(self._wheel_speed[0] / left_wheel_speed)
            right_wheel_speed = right_wheel_speed * factor
            left_wheel_speed = left_wheel_speed * factor
        if abs(right_wheel_speed) > self._wheel_speed[1]:
            factor = abs(self._wheel_speed[1] / right_wheel_speed)
        self._dc.set_dof_velocity_target(self.wheel_left, left_wheel_speed)
        self._dc.set_dof_velocity_target(self.wheel_right, right_wheel_speed)
    def set_goal(self, x, y, theta, sv=0.5, sa=0.05, gv=0.5, ga=0.05, max_speed=2.0):
        theta = normalize_angle(theta)
        self._goal = [x, y, theta]
        max_accel = 1.5  # max accel [m/ss]
        max_jerk = 0.3  # max jerk [m/sss]
        self.target_idx = 0
        x_diff = self.current_robot_translation[0] - x
        y_diff = self.current_robot_translation[1] - y
        if rho / 5.0 > self._goal_offset_threshold[0]:
            # 2. +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
            start = (int(self.current_robot_translation[0] / distance_per_square),
                     int(self.current_robot_translation[1] / distance_per_square))
            goal = (int(x / distance_per_square), int(y / distance_per_square))
            route = astar(grid, start, goal)
            route = route + [start]
            route = route[::-1]
            x_coords = []
            y_coords = []
            for i in (range(0,len(route))):
                x_coords.append(route[i][0])
                y_coords.append(route[i][1])
            points = np.stack((x_coords, y_coords), axis=1)
            distance = np.cumsum( np.sqrt(np.sum( np.diff(points, axis=0)**2, axis=1 )) )
            distance = np.insert(distance, 0, 0)/distance[-1]
            interpolations_methods = ['slinear', 'quadratic', 'cubic']
            alpha = np.linspace(0, 1, len(route) * 50)
            print(alpha.shape)
            interpolator =  interp1d(distance, points, kind="quadratic", axis=0)
            x, y = interpolator(alpha).T
            # plot map and path
            fig, ax = plt.subplots(figsize=(5,5))
            ax.imshow(grid, cmap=plt.cm.Dark2)
            ax.scatter(start[1],start[0], marker = "*", color = "yellow", s = 200)
            ax.scatter(goal[1],goal[0], marker = "*", color = "red", s = 200)
            ax.plot(y_coords,x_coords, color = "black")
            ax.scatter(y, x, color = "red")
            plt.show()
            self.cx = x
            self.cy = y
            self.ck = np.ones_like(self.cx)
            self.cyaw = np.zeros_like(self.cx)
            # self.tt, self.cx, self.cy, self.cyaw, self.ck, s, j = quintic_polynomials_planner(
            #     self.current_robot_translation[0],
            #     self.current_robot_translation[1],
            #     self.current_robot_orientation[2],
            #     sv,
            #     sa,
            #     x,
            #     y,
            #     theta,
            #     gv,
            #     ga,
            #     max_accel,
            #     max_jerk,
            #     1 / 60.0,
            # 2. -------------------------------------------------------------------------
            self.cx = np.array(self.cx)
            self.cy = np.array(self.cy)
            self.sp = calc_speed_profile(np.array(self.ck), max_speed, 0.5, 0.05)
            color = [(0, t / np.max(self.sp), 0) for t in self.sp]
            self.y_color = int.from_bytes(b"\xff\xff\x00\x00", byteorder="big")
            rgb_bytes = [(np.clip(c, 0, 1.0) * 255).astype("uint8").tobytes() for c in color]
            argb_bytes = [b"\xff" + b for b in rgb_bytes]
            self.argb = [int.from_bytes(b, byteorder="big") for b in argb_bytes]
            self.rotate_only = False
        else:
    def enable_navigation(self, flag):
        self._enable_navigation = flag
There are basically 2 changes indicated between +++++ and ------
  1. the A* start algorithm and the grid. The grid is 20x20 and for the integration, I use a mapping of 25cm per grid square side. The obstacles in the grid are fixed and they are there only to showcase
  2. Calling the planer and configuring some variables for navigation. Note that A* is only a path search algorithm. It does not take care of setting the robot velocity setpoints to reach the goal. Current integration set some values required for the last task to 1 or 0 (because the idea is to show the use to the A*)… You have here room for improvement on which to work :)
OFF-TOPIC:
If you want to display the matplotib chart inside Omniverse, as shown in the video you can use the external extension GitHub - Toni-SM/semu.data.visualizer: Display Matplotlib graphics and OpenCV images inside NVIDIA Omniverse apps
And talking about extensions… the following event will take place today
More details here in the Omniverse discord server:
Hi @toni.sm
Thank you very much for answering me.
That’s the answer I’ve been waiting for and looking forward to.
There was a problem with me executing the code you gave me.
The following error occurs.
[Error] [omni.kit.app.impl] [py stderr]: /home/tommy/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.demos/omni/isaac/demos/utils/simple_robot_controller.py:357: UserWarning: Matplotlib is currently using agg, which is a non-GUI backend, so cannot show the figure.
So I installed Matplotlib and pyqt5, but the same error comes out and the visual screen doesn’t come out like you in omniverse Isaac sim.
How can I solve the problem?
Hi @gudwnzm
If you want to display matplotlib charts inside Omniverse you need to install the extension and enable it
install
enable
And that is all. After enabling the extension you can display images and charts inside Omniverse apps
Hi @toni.sm
It’s so cool that you made this.
I downloaded the zip file, but where should I put the path of the extracted file to see the file in my Omniverse extension?
Hi @gudwnzm
You don’t need to extract the extension, just follow the indication shown in the image above and select the .zip file after clicking on “import extension”
Hi @toni.sm
Thank you always for your detailed and kind reply.
I will learn a lot based on the information you gave me.
