TLDR: I am running the pose_generation.py example from Isaac Sim 4.2.0 with no change in code however I did install a few extensions and have added them to app/omni.isaac.sim.python.kit
"semantics.schema.editor" = {}
"semantics.schema.property" = {}
"omni.replicator.character.core" = {}
"omni.replicator.core" = {}
"omni.replicator.character.ui" = {}
"omni.anim.graph.core" = {}
"omni.anim.navigation.core" = {}
"omni.anim.people" = {}
"omni.replicator.isaac" = {}
^^ disclaimer: I am not sure if I have added these lines in the correct place.
Isaac Sim Version
4.2.0
4.1.0
4.0.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Isaac Lab Version (if applicable)
1.2
1.1
1.0
Operating System
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
GPU Information
(base) mona@ada:~/.local/share/ov/pkg/isaac-sim-4.2.0$ cd
(base) mona@ada:~$ uname -a
Linux ada 6.8.0-49-generic #49~22.04.1-Ubuntu SMP PREEMPT_DYNAMIC Wed Nov 6 17:42:15 UTC 2 x86_64 x86_64 x86_64 GNU/Linux
(base) mona@ada:~$ lsb_release -a
LSB Version: core-11.1.0ubuntu4-noarch:security-11.1.0ubuntu4-noarch
Distributor ID: Ubuntu
Description: Ubuntu 22.04.3 LTS
Release: 22.04
Codename: jammy
(base) mona@ada:~$ nvidia-smi
Fri Jan 3 13:56:28 2025
| NVIDIA-SMI 565.57.01 Driver Version: 565.57.01 CUDA Version: 12.7 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA RTX 6000 Ada Gene... On | 00000000:52:00.0 On | Off |
| 30% 54C P0 62W / 300W | 4500MiB / 49140MiB | 23% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 4457 G /usr/lib/xorg/Xorg 551MiB |
| 0 N/A N/A 4609 G /usr/bin/gnome-shell 289MiB |
| 0 N/A N/A 5107 G ...AAAAAAAACAAAAAAAAAA= --shared-files 123MiB |
| 0 N/A N/A 5263 G ...ures=SpareRendererForSitePerProcess 66MiB |
| 0 N/A N/A 7657 G ...irefox/5437/usr/lib/firefox/firefox 270MiB |
| 0 N/A N/A 10267 G ...sion,SpareRendererForSitePerProcess 447MiB |
| 0 N/A N/A 20317 C+G ...hare/ov/pkg/isaac-sim-4.2.0/kit/kit 2627MiB |
(base) mona@ada:~$ nvcc --version
Copyright (c) 2005-2023 NVIDIA Corporation
Built on Tue_Aug_15_22:02:13_PDT_2023
Cuda compilation tools, release 12.2, V12.2.140
Build cuda_12.2.r12.2/compiler.33191640_0
Topic Description
Detailed Description
(Describe the issue in detail, including what you were trying to do, what you expected to happen, and what actually happened)
Steps to Reproduce
(Add more steps as needed)
Error Messages
(If applicable, copy and paste any error messages you received)
Screenshots or Videos
(If applicable, add screenshots or links to videos that demonstrate the issue)
Additional Information
What I’ve Tried
(Describe any troubleshooting steps you’ve already taken)
Related Issues
(If you’re aware of any related issues or forum posts, please link them here)
Additional Context
(Add any other context about the problem here)
I have these extensions in Isaac Sim 4.2.0:
When I run this command I get the error as follows:
(base) mona@ada:~/.local/share/ov/pkg/isaac-sim-4.2.0$ ./python.sh standalone_examples/replicator/pose_generation/pose_generation.py --writer centerpose --num_mesh 1
Warning: running in conda env, please deactivate before executing this script
If conda is desired please source setup_conda_env.sh in your python 3.10 conda env and run python normally
Starting kit application with the following args: ['/home/mona/.local/share/ov/pkg/isaac-sim-4.2.0/exts/omni.isaac.kit/omni/isaac/kit/simulation_app.py', '/home/mona/.local/share/ov/pkg/isaac-sim-4.2.0/apps/omni.isaac.sim.python.kit', '--/app/tokens/exe-path=/home/mona/.local/share/ov/pkg/isaac-sim-4.2.0/kit', '--/persistent/app/viewport/displayOptions=3094', '--/rtx/materialDb/syncLoads=True', '--/rtx/hydra/materialSyncLoads=True', '--/omni.kit.plugin/syncUsdLoads=True', '--/app/renderer/resolution/width=1920', '--/app/renderer/resolution/height=1440', '--/app/window/width=1440', '--/app/window/height=900', '--/renderer/multiGpu/enabled=True', '--/app/fastShutdown=True', '--ext-folder', '/home/mona/.local/share/ov/pkg/isaac-sim-4.2.0/exts', '--ext-folder', '/home/mona/.local/share/ov/pkg/isaac-sim-4.2.0/apps', '--/physics/cudaDevice=0', '--portable']
Passing the following args to the base kit application: ['--writer', 'centerpose', '--num_mesh', '1']
[Info] [carb] Logging to file: /home/mona/.local/share/ov/pkg/isaac-sim-4.2.0/kit/logs/Kit/Isaac-Sim/4.2/kit_20250103_134428.log
2025-01-03 18:44:28 [0ms] [Warning] [omni.kit.app.plugin] No crash reporter present, dumps uploading isn't available.
[0.089s] Failed to solve some dependencies locally, syncing with extension registry...
[0.092s] [ext: omni.kit.async_engine-0.0.1] startup
[0.094s] [ext: omni.client-1.2.0] startup
[0.127s] [ext: omni.kit.registry.nucleus-0.0.0] startup
2025-01-03 18:44:29 [1,134ms] [Error] [omni.ext.plugin] Failed to resolve extension dependencies. Failure hints:
[omni.isaac.sim.python-4.2.0] dependency: 'omni.replicator.character.core' = { version='^' } can't be satisfied. Available versions:
(none found)
Synced registries:
- kit/default : found 447 packages
- kit/sdk : found 320 packages
- kit/community : found 384 packages
2025-01-03 18:44:29 [1,135ms] [Error] [omni.kit.app.plugin] Exiting app because of dependency solver failure...
File "/home/mona/.local/share/ov/pkg/isaac-sim-4.2.0/standalone_examples/replicator/pose_generation/pose_generation.py", line 84, in <module>
kit = SimulationApp(launch_config=config_data["CONFIG"])
File "/home/mona/.local/share/ov/pkg/isaac-sim-4.2.0/exts/omni.isaac.kit/omni/isaac/kit/simulation_app.py", line 214, in __init__
from .utils import create_new_stage, open_stage, set_livesync_stage
File "/home/mona/.local/share/ov/pkg/isaac-sim-4.2.0/exts/omni.isaac.kit/omni/isaac/kit/utils.py", line 17, in <module>
from omni.kit.usd import layers
ModuleNotFoundError: No module named 'omni.kit.usd'
2025-01-03 18:44:29 [1,140ms] [Warning] [carb] Recursive unloadAllPlugins() detected!
There was an error running python
I have also attached my entire app/omni.isaac.sim.python.kit file here:
[package]
title = "Isaac Sim Python"
description = "A trimmed down app for use with python samples"
version = "4.2.0"
# That makes it browsable in UI with "experience" filter
keywords = ["experience", "app", "usd"]
[dependencies]
# Isaac Sim extensions
"omni.isaac.cloner" = {}
"omni.isaac.core" = {}
"omni.isaac.core_archive" = {}
"omni.isaac.core_nodes" = {}
"omni.isaac.cortex" = {}
"omni.isaac.cortex.sample_behaviors" = {}
"omni.isaac.debug_draw" = {}
"omni.isaac.dynamic_control" = {}
"omni.isaac.franka" = {}
"omni.isaac.kit" = {}
"omni.isaac.lula" = {}
"omni.isaac.manipulators" = {}
"omni.isaac.ml_archive" = {}
"omni.isaac.motion_generation" = {}
"omni.isaac.menu" = {}
"omni.isaac.nucleus" = {}
"omni.isaac.occupancy_map" = {}
"omni.isaac.quadruped" = {}
"omni.isaac.range_sensor" = {}
"omni.isaac.scene_blox" = {}
"omni.isaac.sensor" = {}
"omni.isaac.surface_gripper" = {}
"omni.isaac.universal_robots" = {}
"omni.isaac.utils" = {}
"omni.isaac.wheeled_robots" = {}
"omni.kit.property.isaac" = {}
"omni.pip.cloud" = {}
"omni.pip.compute" = {}
# Kit extensions
#"omni.activity.profiler" = {}
#"omni.activity.pump" = {}
"omni.anim.graph.schema" = {}
"omni.anim.navigation.schema" = {}
"omni.usd.schema.omniscripting" = {}
"omni.graph.bundle.action" = {}
"omni.graph.visualization.nodes" = {}
"omni.graph.window.action" = {}
"omni.graph.window.generic" = {}
"omni.hydra.engine.stats" = {}
"omni.importer.mjcf" = {}
"omni.importer.urdf" = {}
"omni.kit.collaboration.channel_manager" = {}
"omni.kit.context_menu" = {}
"omni.kit.hotkeys.window" = {}
"omni.kit.loop-isaac" = {}
"omni.kit.manipulator.prim" = {}
"omni.kit.manipulator.transform" = {}
"omni.kit.menu.common" = {}
"omni.kit.menu.create" = {}
"omni.kit.menu.edit" = {}
"omni.kit.menu.file" = {}
"omni.kit.menu.stage" = {}
"omni.kit.menu.utils" = {}
"omni.kit.primitive.mesh" = {}
"omni.kit.profiler.window" = {}
"omni.kit.property.bundle" = {}
"omni.kit.property.layer" = {}
"omni.kit.renderer.core" = {}
"omni.kit.selection" = {}
"omni.kit.stage_column.payload" = {}
"omni.kit.stage_column.variant" = {}
"omni.kit.stage_templates" = {}
"omni.kit.telemetry" = {}
"omni.kit.uiapp" = {}
"omni.kit.viewport.bundle" = {}
"omni.kit.viewport.menubar.lighting" = {}
# "omni.kit.viewport.ready" = {}
"omni.kit.viewport.rtx" = {}
"omni.kit.widget.cache_indicator" = {}
"omni.kit.widget.extended_searchfield" = {}
"omni.kit.widget.filebrowser" = {}
"omni.kit.widget.layers" = {}
"omni.kit.widget.live" = {}
"omni.kit.widget.timeline" = {}
"omni.kit.window.commands" = {}
"omni.kit.window.console" = {}
"omni.kit.window.content_browser" = {}
"omni.kit.window.cursor" = {}
"omni.kit.window.extensions" = {}
"omni.kit.window.file" = {}
"omni.kit.window.filepicker" = {}
"omni.kit.window.property" = {}
"omni.kit.window.script_editor" = {}
"omni.kit.window.stage" = {}
"omni.kit.window.stats" = {order = 1000}
"omni.kit.window.status_bar" = {}
"omni.kit.window.title" = {}
"omni.kit.window.toolbar" = {}
"omni.physx.bundle" = {}
# "omni.physx.fabric" = {}
"omni.physx.tensors" = {}
"omni.replicator.replicator_yaml" = {}
"omni.resourcemonitor" = {}
"omni.rtx.settings.core" = {}
"omni.stats" = {}
"omni.syntheticdata" = {}
"omni.usd.schema.scene.visualization" = {}
"omni.warp" = {}
[settings]
renderer.active = "rtx"
exts."omni.kit.viewport.menubar.camera".expand = true # Expand the extra-camera settings by default
exts."omni.kit.window.file".useNewFilePicker = true
exts."omni.kit.tool.asset_importer".useNewFilePicker = true
exts."omni.kit.tool.collect".useNewFilePicker = true
exts."omni.kit.widget.layers".useNewFilePicker = true
exts."omni.kit.renderer.core".imgui.enableMips = true
exts."omni.kit.widget.cloud_share".require_access_code = false
exts."omni.kit.pipapi".installCheckIgnoreVersion = true
exts."omni.kit.viewport.window".startup.windowName="Viewport" # Rename from Viewport Next
exts."omni.kit.menu.utils".logDeprecated = false
# app.content.emptyStageOnStart = false
app.file.ignoreUnsavedOnExit = true # prevents save dialog when exiting
# deprecate support for old kit.ui.menu
app.menu.legacy_mode = false
# use omni.ui.Menu for the MenuBar
app.menu.compatibility_mode = false
# Setting the port for the embedded http server
exts."omni.services.transport.server.http".port = 8211
# default viewport is fill
app.runLoops.rendering_0.fillResolution = false
exts."omni.kit.test".includeTests = [ "*isaac*" ]
[settings.app.python]
# These disable the kit app from also printing out python output, which gets confusing
interceptSysStdOutput = false
logSysStdOutput = false
[settings.app.settings]
persistent = false
dev_build = false
fabricDefaultStageFrameHistoryCount = 3 # needed for omni.syntheticdata TODO105 Still True?
[settings.app.window]
hideUi = false
_iconSize = 256
iconPath = "${omni.isaac.kit}/data/omni.isaac.sim.png"
# width = 1700
# height = 900
# x = -1
# y = -1
# Fonts
[setting.app.font]
file = "${fonts}/OpenSans-SemiBold.ttf"
size = 16
# [setting.app.runLoops]
# main.rateLimitEnabled = false
# main.rateLimitFrequency = 60
# main.rateLimitUseBusyLoop = false
# rendering_0.rateLimitEnabled = false
[settings.exts.'omni.kit.window.extensions']
# List extensions here we want to show as featured when extension manager is opened
featuredExts = []
[settings]
# MGPU is always on, you can turn it from the settings, and force this off to save even more resource if you
# only want to use a single GPU on your MGPU system
renderer.multiGpu.enabled = true
renderer.multiGpu.autoEnable = true
# This setting forces all GPUs to copy their render results to the main GPU.
# This legacy setting should not be needed anymore
app.gatherRenderResults = false
'rtx-transient'.resourcemanager.enableTextureStreaming = true
# app.hydra.aperture.conform = 4 # in 105.1 pixels are square by default
app.hydraEngine.waitIdle = false
rtx.newDenoiser.enabled = true
# Enable Iray and pxr by setting this to "rtx,iray,pxr"
renderer.enabled = "rtx"
physics.autoPopupSimulationOutputWindow=false
### async rendering settings
omni.replicator.asyncRendering = false
app.asyncRendering = false
app.asyncRenderingLowLatency = false
### Render thread settings
app.runLoops.main.rateLimitEnabled = false
app.runLoops.main.rateLimitFrequency = 120
app.runLoops.main.rateLimitUsePrecisionSleep = true
app.runLoops.main.syncToPresent = false
app.runLoops.present.rateLimitFrequency = 60
app.runLoops.present.rateLimitUsePrecisionSleep = true
app.runLoops.rendering_0.rateLimitFrequency = 120
app.runLoops.rendering_0.rateLimitUsePrecisionSleep = true
app.runLoops.rendering_0.syncToPresent = false
app.runLoops.rendering_1.rateLimitFrequency = 120
app.runLoops.rendering_1.rateLimitUsePrecisionSleep = true
app.runLoops.rendering_1.syncToPresent = false
app.runLoopsGlobal.syncToPresent = false
app.vsync = false
exts."omni.kit.renderer.core".present.enabled = false
exts."omni.kit.renderer.core".present.presentAfterRendering = false
persistent.app.viewport.defaults.tickRate = 120
rtx-transient.dlssg.enabled = false
app.audio.enabled = false
privacy.externalBuild = true
# Enable Vulkan
app.vulkan = true
# Basic Kit App
app.versionFile = "${app}/../VERSION"
app.name = "Isaac-Sim"
app.version = "4.2.0"
# hide NonToggleable Exts
exts."omni.kit.window.extensions".hideNonToggleableExts = true
exts."omni.kit.window.extensions".showFeatureOnly = false
# Hang Detector
# app.hangDetector.enabled = false
# app.hangDetector.timeout = 120
# RTX Settings
[settings.rtx]
translucency.worldEps = 0.005
# Content Browser
[settings.exts."omni.kit.window.content_browser"]
enable_thumbnail_generation_images = false # temp fix to avoid leaking python processes
# Extensions
[settings.exts."omni.kit.registry.nucleus"]
registries = [
{ name = "kit/default", url = "https://ovextensionsprod.blob.core.windows.net/exts/kit/prod/106/shared" },
{ name = "kit/sdk", url = "https://ovextensionsprod.blob.core.windows.net/exts/kit/prod/sdk/${kit_version_short}/${kit_git_hash}" },
{ name = "kit/community", url = "https://dw290v42wisod.cloudfront.net/exts/kit/community" },
[settings.app.extensions]
skipPublishVerification = false
registryEnabled = true
[settings.exts."omni.kit.window.modifier.titlebar"]
titleFormatString = " Isaac Sim {version:${app}/../SHORT_VERSION,font_color=0x909090,font_size=16} {separator} {file, board=true}"
showFileFullPath = true
icon.file = "${app}/../exts/omni.isaac.app.setup/data/nvidia-omniverse-isaacsim.ico"
icon.size = 256
defaultFont.name = "Arial"
defaultFont.size = 16
defaultFont.color = 0xD0D0D0
separator.color = 0x00B976
separator.width = 1
windowBorder.color = 0x0F0F0F
windowBorder.width = 2
colors.caption = 0x0F0F0F
colors.client = 0x0F0F0F
respondOnMouseUp = true
changeWindowRegion = true
# Register extension folder from this repo in kit
[settings.app.exts]
folders = ["${app}/../exts", "${app}/../extscache", "${app}/../extsPhysics", "${app}/../extsUser"]
[settings.crashreporter.data]
experience = "Isaac Sim Python"
# Isaac Sim Settings
[settings.app.renderer]
skipWhileMinimized = false
sleepMsOnFocus = 0
sleepMsOutOfFocus = 0
resolution.width=1280
resolution.height=720
[settings.app.livestream]
proto = "ws"
allowResize = true
outDirectory = "${data}"
# default camera position in meters
[settings.app.viewport]
defaultCamPos.x = 5
defaultCamPos.y = 5
defaultCamPos.z = 5
[settings.rtx]
raytracing.fractionalCutoutOpacity = false
hydra.enableSemanticSchema = true
mdltranslator.mdlDistilling = false
# descriptorSets=60000
# reservedDescriptors=500000
# sceneDb.maxInstances=1000000
# Enable this for static scenes, improves visual quality
# directLighting.sampledLighting.enabled = true
[settings.persistent]
app.file.recentFiles = []
app.stage.upAxis = "Z"
app.stage.timeCodeRange = [0, 1000000]
app.stage.movePrimInPlace = false
app.stage.instanceableOnCreatingReference = false
app.stage.materialStrength = "weakerThanDescendants"
app.transform.gizmoUseSRT = true
app.viewport.grid.scale = 1.0
app.viewport.pickingMode = "kind:model.ALL"
app.viewport.camMoveVelocity = 0.05 # 5 m/s
app.viewport.gizmo.scale = 0.01 # scaled to meters
app.viewport.previewOnPeek = false
app.viewport.snapToSurface = false
app.viewport.displayOptions = 31887 # Disable Frame Rate and Resolution by default
app.window.uiStyle = "NvidiaDark"
app.primCreation.DefaultXformOpType = "Scale, Orient, Translate"
app.primCreation.DefaultXformOpOrder="xformOp:translate, xformOp:orient, xformOp:scale"
app.primCreation.typedDefaults.camera.clippingRange = [0.01, 10000000.0]
simulation.minFrameRate = 15
simulation.defaultMetersPerUnit = 1.0
omnigraph.updateToUsd = false
omnigraph.useSchemaPrims = true
omnigraph.disablePrimNodes = true
physics.updateToUsd = true
physics.updateVelocitiesToUsd = true
physics.useFastCache = false
physics.visualizationDisplayJoints = false
physics.visualizationSimulationOutput = false
omni.replicator.captureOnPlay = true
exts."omni.anim.navigation.core".navMesh.viewNavMesh = false
exts."omni.anim.navigation.core".navMesh.config.autoRebakeOnChanges = false
resourcemonitor.timeBetweenQueries = 100
renderer.startupMessageDisplayed = true # hides the IOMMU popup window
# Make Detail panel visible by default
app.omniverse.content_browser.options_menu.show_details = true
app.omniverse.filepicker.options_menu.show_details = true
[settings.ngx]
enabled=true # Enable this for DLSS
